Thermal temperature readings on breakers - Electrician Talk - Professional Electrical Contractors Forum
Old 10-20-2016, 10:44 AM   #1
Rewards Points: 72
Default Thermal temperature readings on breakers
I read recently that using a thermal temperature reading is a good way to find bad circuit breakers in panels. I believe it said to get a reading off of the input and out put terminal and that a difference of more than a few degrees should be investigated. I went though my note to get the specifics but unfortunately I can't remember where I read this. I checked the temperature for the breakers in the panel today and found a difference of roughly 10 degrees F from the input to the output on the breakers for the safety interlock. Since I can't find the source of this information I'm not really sure if I found something worth noting or not. Does anyone have any experience using this technique for panel troubleshooting or PM's that could offer me some more details on this?
Sparky Mcgregor is offline   Reply With Quote
Old 10-20-2016, 08:09 PM   #2
backstay's Avatar
Rewards Points: 296
I think breaker type, application, terminals would all work into the mix.
Sparky Mcgregor (10-21-2016)
Old 10-20-2016, 08:13 PM   #3
Rewards Points: 386
Thermal imaging can help find loose terminals or heavily loaded breakers but it is most effective In a long term pm situation. It can really help locate miss balenced panels
Anathera is offline   Reply With Quote
The Following User Says Thank You to Anathera For This Useful Post:
Old 10-20-2016, 08:18 PM   #4
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
For temperature difference on a common component or between similar components we use a scale developed by EPRI:
0-10C Minor
11-35C Moderate
36-70C Severe
>70C Critical
Always wear your gloves.
Old 10-22-2016, 11:17 AM   #5
Rewards Points: 142
10 degrees Fahrenheit should be investigated? I find that hard to believe. Pretty much everything I have ever looked at with the thermal imaging cam would have to be investigated. Maybe that's lab specs or something, in the real world you'd be chasing your tail imo
Flyingsod is online now   Reply With Quote
Old 10-22-2016, 12:35 PM   #6
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
This is where an experienced thermographer is valuable: The cameras are a dime a dozen and anyone can point them at something. But knowing what is an issue and what is not is where your value is to the customer.
I would very likely not waste the time or ink to report a 10 delta-T on a breaker unless I had reason to believe it was the beginning of a more serious problem.
GE Breakers Dying ppsh General Electrical Discussion 3 09-11-2016 10:01 PM
GFCI Breakers Tripping Simultaneously robmix General Electrical Discussion 15 08-18-2016 05:37 PM
Oxidation on breakers Anathera General Electrical Discussion 58 06-28-2016 12:17 PM
Non-U.L.-Certified Breakers in obsolete Panels? Karl in NY General Electrical Discussion 43 05-18-2016 10:41 PM
Handle Ties on breakers JasonCo NEC Code Forum 6 02-15-2016 03:31 PM
