Todays service call - Electrician Talk - Professional Electrical Contractors Forum
Old 03-26-2012, 08:29 PM   #1
Default Todays service call
No Resi work today.
Got my first Angie's List Call today! I pulled 4 wires from the panel. (3Ph high leg.) Existing pipe and greenfield. It felt good to hookup the motor connections and check the starter connections. It's been a while!
This place was full of exotic cars. (No Pics) They said they will do a review for me and have me scheduled for more work already in may. Thanks for looking.
Island Electric is offline   Reply With Quote
The Following 2 Users Say Thank You to Island Electric For This Useful Post:
guest (03-26-2012), Magnettica (03-26-2012)
Old 03-26-2012, 08:42 PM   #2
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Good to hear Angie's List is working for you. I'd have to look in my Ugly's book to wire any motor from leads only. Never did much of this work at all.
Replies based on NEC 2014
Old 03-26-2012, 08:45 PM   #3
Off the top of my head it was (T1-T7 Line 1) (T2-T8 Line 2) (T3-T9 Line 3) (Then T4-T5-T6 splice together by themselves)
The Following User Says Thank You to Island Electric For This Useful Post:
Old 03-26-2012, 10:01 PM   #4
french connection!!'s Avatar
Rewards Points: 250
were you out of straps
french connection!! is offline   Reply With Quote
The Following 6 Users Say Thank You to french connection!! For This Useful Post:
BurtiElectric (03-28-2012), CADPoint (03-26-2012), Grounded-B (03-26-2012), nolabama (04-16-2012), sstlouis03 (04-16-2012), Whatevva (04-16-2012)
Old 03-26-2012, 10:10 PM   #5
MaxFuse's Avatar
Rewards Points: 150
The first thing I noticed too.
MaxFuse is offline   Reply With Quote
Old 03-26-2012, 11:12 PM   #6
IET
RobRoy's Avatar
Rewards Points: 1,008
I would have used seal tite, but I work for an oil company.
Here is the link to my "A Typical Day In The Life Of An Oilfield Electrician" Compilation. You know you want to click here.
RobRoy is offline   Reply With Quote
Old 03-26-2012, 11:18 PM   #7
Jlarson's Avatar
Rewards Points: 4,264
I wouldn't have wasted any new straps on it either, what's the worst thing that can happen, the flexible raceway flexes around a bit?
The Following User Says Thank You to Jlarson For This Useful Post:
76nemo (03-27-2012)
Old 03-27-2012, 03:37 AM   #8
Rewards Points: 21,898
I would put couple straps in there to keep the noise down you know how much viberation the compressours will run.
The other thing is the disconnect switch is in sight of this unit ?
Merci,
Marc
Old 03-28-2012, 12:17 AM   #9
Great way to keep your skills sharp until you can grab another short call.
CheckinShorts is offline   Reply With Quote
Old 04-03-2012, 03:00 PM   #10
Default offsets
[quote=Island Electric;677896]No Resi work today.
They dont have offset benders or straps in chicago
bmac8052 is offline   Reply With Quote
Old 04-16-2012, 07:18 AM   #11
Rewards Points: 250
I usually recommend the pre-packaged IR compressors. The motor starter, and air cooler is built in.
noarcflash is offline   Reply With Quote
Old 04-16-2012, 03:06 PM   #12
If you look closely the bottom EMT has an offset, and get real, is it really necessary to bend offsets in a 6" and 10" piece of EMT?
I do agree that the flex should be strapped down better, no need for so much of it to be hanging in the air.
Old 04-16-2012, 03:29 PM   #13
Nice work
Shame no pics of the cars; what kind were there?
Jtt123 is offline   Reply With Quote
Old 04-16-2012, 03:38 PM   #14
sstlouis03's Avatar
Its fuctional but I believe you could have made it look alot better.
sstlouis03 is offline   Reply With Quote
Old 04-16-2012, 05:39 PM   #15
jza
Mad as Hell Member
jza's Avatar
Rewards Points: 2,318
Seriously. Looks terrible.
jza is offline   Reply With Quote
Service Call Right NOW! Cletis General Electrical Discussion 56 12-18-2011 10:50 PM
Todays service call mcclary's electrical General Electrical Discussion 41 04-15-2011 09:43 AM
Todays 100 amp service Shockdoc Services and Service Equipment 39 12-09-2010 06:41 PM
Todays service call... tates1882 General Electrical Discussion 18 12-08-2010 11:44 PM
Service call mattsilkwood General Electrical Discussion 13 08-17-2010 10:45 AM
