Transfer Switch - Electrician Talk - Professional Electrical Contractors Forum
Old 07-26-2013, 08:46 AM   #1
Rewards Points: 304
Default Transfer Switch
How does transferswitch work? I know like if there are two sources of power and if they are interlock. When one power goes out it switches it to another but in between time doesn't the power goes out for like a short period of time?
Ninjazx916r is offline   Reply With Quote
Old 07-26-2013, 08:57 AM   #2
Retired Account
Rewards Points: 14,650
How does what kind of Tswitch work Ninja...? a 3w switch could be a Tswitch....~CS~
Old 07-26-2013, 09:26 AM   #3
8V71's Avatar
Rewards Points: 2,900
Yes, you loose power for a short time. Do you have a different application in mind where you need to switch something without loosing power?
8V71 is offline   Reply With Quote
Old 07-26-2013, 01:21 PM   #4
Rewards Points: 14
You can't predict for outages, if you could than a transfer switch would be completely different. If you lose utility, there is usually time delays for starting the engine, transferring to the alternate source etc. there is time the load will not be served, but is mostly dependent on how long it takes your alternate source to be accepted.
Boostinsteve is offline   Reply With Quote
Old 07-26-2013, 03:08 PM   #5
Rewards Points: 2,950
Thus the need for a good UPS to allow for the lag between utility power and generator power, both when utility power fails and again when it is restored.
Old 07-26-2013, 04:30 PM   #6
zap
tates1882's Avatar
Rewards Points: 1,072
That would depend on the transfer switch. Some are break the make, some make then break. The later requires a sink control and is rarely seen unless its a self contained site. Most common switches you will see will be break then make, the utility's really don't like the second type.
tates1882 is online now   Reply With Quote
Old 07-26-2013, 04:44 PM   #7
Rewards Points: 14
Need to know what the real question is. Are you talking about the short time during the transition of an open transition switch? Or are you talking about when the power goes out and you are waiting for the generator to start. I am a service rep for ASCO, and can tell you more if you want to know. I can go pretty in depth talking about different types of switches.
Transfer Switch Badabing Commercial Electrical Forum 8 03-07-2013 09:34 AM
Transfer Switch acebradley NEC Code Forum 3 02-28-2013 01:49 AM
Generac EZ switch (transfer switch) Gamit General Electrical Discussion 33 02-27-2012 10:26 PM
transfer switch ratrod56 General Electrical Discussion 21 10-31-2011 06:08 PM
Transfer Switch 2towbot General Electrical Discussion 5 01-23-2009 02:44 PM
