Transformer - Backfeeding - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 4 Post By JRaef
  • 2 Post By wildleg
Old 02-02-2018, 11:52 AM   #1
Muneeb's Avatar
Default Transformer - Backfeeding
Is it possible that a transformer work in forward and reverse simultaneously?
I have 4 transformers. Suppose I provide 3.2MW through a secondary TAP in at one of the transformers. In case my load.connected the same transformer for any reason reduce to zero. My 3.2MW is supposed to flow backwards to the 11KV end and then flow through other transformers. It is possible? What can be the complications?
Muneeb is offline   Reply With Quote
Old 02-02-2018, 12:07 PM   #2
Rewards Points: 7,615
If your load was reduced to zero, it would become a conductor.
Old 02-02-2018, 12:09 PM   #3
Muneeb's Avatar
Lemme rephrase. If the load is disconnected
Old 02-02-2018, 02:15 PM   #4
I would think slight vaiations in impedance would throw the transformers out of phase with each other.
hansonmaster is offline   Reply With Quote
Old 02-02-2018, 02:31 PM   #5
Rewards Points: 1,972
I assume you mean you lose the primary source you want to feed through the secondary to pick up the three other transformers. But depending on the type of transformer wye/wye or delta/wye there could be some issues MAYBE.
Old 02-02-2018, 03:01 PM   #6
Rewards Points: 26,558
What you're describing is known as network analysis... in the transmission// transformer world.
It's a totally different art than field wiring -- which is what this site is all about.
It is EXTREMELY complex.
You want a site that's dedicated to EE issues.
Old 02-02-2018, 07:59 PM   #7
Rewards Points: 332
I agree. It's possible, but very complex.
Are you and Electrical Engineer? Because ANYTHING involving Medium Voltage should NOT be undertaken by anyone who is unfamiliar with the myriad of issues involved, and the fact that you had to ask the question in the first place indicates you are immediately disqualified. Turn this over to someone with experience.
Old 02-02-2018, 08:01 PM   #8
Rewards Points: 1,510
Whilst it may be possible for a back EMF pulse to get thru
I don't think any continuous flow would
i can only go one way at any one time.
both ways continuous is not possible.
Old 02-03-2018, 09:10 AM   #9
Muneeb's Avatar
Yes I am an electrical engineer. Just a thought come to mind. I know it would be very tough. But I was wondering that I might be able to pull this off.
Old 02-03-2018, 09:42 AM   #10
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
I say go for it.
Be sure to post pics.
CTshockhazard and EB Electric like this.
Transformer Wire Sizing HeretoHear Canadian Electrical Forum 9 04-02-2017 04:12 PM
Backfeeding Delta-Y Transformer to Y-Delta petedrt Services and Service Equipment 15 07-02-2016 05:07 PM
Transformer neutral bond sizing (paralleled secondary) haltonelectrician Canadian Electrical Forum 27 06-19-2016 07:21 PM
Transformer Bonding CES Services and Service Equipment 25 04-23-2016 12:54 AM
