Troubleshoot this - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree30Likes
Old 04-25-2019, 03:37 PM   #21
Russian Bot
Helmut's Avatar
Rewards Points: 3,755
Sounds like grease and gunk are on the heat elements, It doesn't trip on start up, right?
I'd guess the elements are covered, and when it heats up and melts it off, it shorts out. Cools down, you reset it, heats up more gunk gets on them, and short.
Or maybe not.....
Alright, Alright, Alright... I'll tell you what to do. Go that way, reeeeeeeeeally fast. If something gets in your way......turn.
Old 04-25-2019, 06:25 PM   #22
86 45 20
Southeast Power's Avatar
Rewards Points: 7,878
I have two 208V appliances in a restaurant (recent build) on 30 amp breakers. Both breakers tripped a couple of times over the last couple of weeks. Yesterday they tripped five times.
I am getting 22.5 amps on each with a clamp meter. I have been here for an hour and nothing has changed. What now, gurus?
Something changed.
Did they just clean them?
Is there a weight issue, Is the motor binging up?
I believe the breakers tripping 5x times in one day is a short and not an overload.
Old 04-25-2019, 06:37 PM   #23
CoolWill's Avatar
Rewards Points: 2,012
I had a machine recently that was tripping the breaker after being on for a while. It was confounding. I finally watched the heater with the cover off. Turns out one of the ceramic supports for an element was missing and the element would get hot and sag, touching the machine frame.
readydave8 and MikeFL like this.
I'm With Her! Hillary 2016
Old 04-25-2019, 06:51 PM   #24
Rewards Points: 3,726
If the breakers tripped a couple times in a couple weeks, you're wasting your time sitting there watching your meter, you'd expect to sit there a week to catch it in the act.
If you don't have a clamp meter with min-max-average, go buy one today, IMO it's a must for troubleshooting. You have to rig something up that's safe to leave it there but you can check it periodically and see what's going on. You might find that it's getting overloaded regularly just doesn't quite trip. Could be that something binds up and the motor draw spikes, depending on how bad it's bound, the bound part might give first or the breaker might give first.
99cents, glen1971, telsa and 3 others like this.
Old 04-25-2019, 07:50 PM   #25
Rewards Points: 834
I'm with the suggestions on grease / moisture / gunk in the electrical connections. More times than not, I've found this to be the culprit in these environments. I'm not sure how the load can be resistive if it is turning a motor. You also specified that they aren't starting/stopping. Either a) you have having issues with ambient heat or b) you need to pop open the equipment cord / plug and figure out what is going on / check for signs of arcing.
Old 04-25-2019, 08:05 PM   #26
stiffneck's Avatar
Rewards Points: 788
Could be a breaker issue. There was a dummy (me) who shorted them out during finishing. Maybe weakened the breakers?
Yes you did sparky nothing more fun than letting the factory smoke and sparks out and I've done it too. Most recently for me was a 480V 100A HVAC unit that Climate control boys said they fixed. The heating elements where still completely shorted together, when I reset that breaker which was the second time it cleared that fault. My fault for not doing my job and checking the branch circuit myself 1rst. I would have found that their equipment was still faulted. Blew one of the covers off the unit and half way across the street. Inside, wicked black smoke and sparks came out at me from the panel. The next breaker upstream on the switch board tripped and the closed transition switch gear briefly had a hissy fit. Really let my guard down on this one. Now TWO BREAKERS needed to be replaced instead of ONE.
Whether you shorted it to ground or phase, the breakers need to be replaced. Overloads can be reset again and again, but not fault clearing.
99cents likes this.
In Bred Electrical Worker
The Following User Says Thank You to stiffneck For This Useful Post:
Wiresmith (04-27-2019)
Old 04-25-2019, 10:12 PM   #27
Rewards Points: 11,469
I replaced the breakers. So far so good.
I like threads like this. Always a learning experience. Thanks, dudes.
Superman (04-26-2019)
Old 04-26-2019, 02:11 AM   #28
Rewards Points: 2,346
are you using time lag breakers ?
inductive loads like electric motors
are better off running on time lag breakers.
this allows for start up surges
normal breakers do not !
Old 04-26-2019, 09:25 AM   #29
MikeFL's Avatar
Rewards Points: 2,712
In a restaurant it's always (often) the grease!
In the mechanical and life safety codes we call it "grease laden vapors" which means it gets everywhere air gets. It accumulates and hinders heat dissipation causing everything to run hotter and fail sooner than it otherwise would.
As others have said, that grease also warms up and does funny things.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 04-26-2019, 09:18 PM   #30
Rewards Points: 1,496
Normal circuit breakers in the USA are Thermal, Magnetic, the magnetic allows for inrush and typically is 6-10 times the rating of the CB.
stiffneck likes this.
Old 04-26-2019, 10:35 PM   #31
Rewards Points: 90
If the breaker panel is in the kitchen is it warm in there? Is there any name plate on the equipment?
Eddie702 is offline   Reply With Quote
Old 04-27-2019, 11:32 AM   #32
Vacated
Wiresmith's Avatar
Rewards Points: 2,844
https://www.testequipmentdepot.com/p...atinum%20Tools
or try this out and let me know what you think of it.
Think like a man of action, act like a man of thought. ~Henri Louis Bergson
weird troubleshoot black-neutral 120v n black-black 0v [email protected] Residential Electrical Forum 13 09-25-2018 12:24 PM
Troubleshoot question (Ohm's law?) JasonCo General Electrical Discussion 17 09-20-2018 09:00 AM
Troubleshoot question (Odd problem...) JasonCo General Electrical Discussion 17 09-14-2018 04:43 PM
Troubleshoot this 220/221 General Electrical Discussion 14 06-01-2018 02:20 PM
Troubleshoot WronGun Residential Electrical Forum 25 05-09-2017 08:30 PM
