Two 100amp breakers on same leg? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree25Likes
Old 10-07-2019, 05:13 PM   #1
Rewards Points: 8
Default Two 100amp breakers on same leg?
Hi everyone, I'm a complete novice compared to you all, and I figured you could make quick work of this question:
I'm in the process of identifying/labelling circuits in the house we bought last year, since the old labels aren't overly accurate or descriptive. When opening up the panel, I see that there are two 100amp breakers.. not one on each leg, but on top of each other.
Can anyone here give me a brief description of my setup?
Here is an image of my panel,
https://photos.app.goo.gl/w3XKDoWJyYWiHi176
sl0flyer is offline   Reply With Quote
Old 10-07-2019, 05:52 PM   #2
acro's Avatar
Rewards Points: 998
You need to see an electrician.
The_Modifier likes this.
acro is offline   Reply With Quote
Old 10-07-2019, 05:56 PM   #3
Bird dog's Avatar
Rewards Points: 404
This site is for electrical pros only. Please post on... https://www.diychatroom.com/
The_Modifier (10-07-2019)
Old 10-07-2019, 06:47 PM   #4
Rewards Points: 8
OK well, perhaps someone here is willing to spare 2 minutes to look at the picture. Thanks in advance.
Old 10-07-2019, 06:48 PM   #5
Mensa Player
Rewards Points: 487
I have no idea what is going on.
It seems like someone backfed a 100A breaker to feed a larger sized split-bus panel. The feeder looks newer than the rest of the wiring.
Get an electrician in there to replace the panel.
Old 10-07-2019, 06:50 PM   #6
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 90
While you're trying to upload the picture, please read the user sign up agreement before asking why you can't upload pictures.
99cents and Kevin_Essiambre like this.
The_Modifier is online now   Reply With Quote
Old 10-07-2019, 07:35 PM   #7
joe-nwt's Avatar
Rewards Points: 870
Now I am that much closer to having seen everything.
Signal1 likes this.
joe-nwt is online now   Reply With Quote
Old 10-07-2019, 07:39 PM   #8
Rewards Points: 1,546
For lack of any other explanation I must agree it is a split buss. The wires that go behind the buss must be connected to the lower part of the buss. The main breaker is not really necessary at all- it's redundant in this case
I can't help it if I'm lucky
Old 10-07-2019, 07:40 PM   #9
I will leave it open for discussion purposes
emtnut likes this.
Southeast Power (10-07-2019)
Old 10-07-2019, 08:06 PM   #10
Band Member
emtnut's Avatar
Rewards Points: 1,664
Thanks Dennis ... I'm curious now too. Op is not DIY'ing just wants to map his circuits.
My best guess is a split panel, and the top 100A breaker is just to feed the 40A to the right of it ??
Weird how the 100A (which should feed the buss) is looped around to the top MLO terms.
Old 10-07-2019, 08:14 PM   #11
Mensa Player
Rewards Points: 487
It’s not feeding the lugs at the top. Those conductors coming out of the large 100 Amp breaker Loop up and then back down behind all the breakers to the lower part of the panel. You can see the conductor in the back if you look underneath the large 100 amp breaker. That is the factory way to feed the lower half of the split bus panel.
That small 100 amp breaker is feeding the entire panel.
cdslotz, emtnut and gpop like this.
Old 10-07-2019, 08:18 PM   #12
CoolWill's Avatar
Rewards Points: 3,398
Edit: Hax beat me to it.
emtnut likes this.
I'm With Her! Hillary 2016
Old 10-07-2019, 09:09 PM   #13
HertzHound's Avatar
Rewards Points: 1,062
If the long 100amp breaker was always there with the wires looped around and down to feed the lower buss, and the short 100 amp breaker is now the Main for the whole panel, is it possible that someone came in and didn’t understand how a split buss panel works?
In other words a home inspector or inexperienced electrician saw the original set up and said “this is an illegal setup”. “It needs a main breaker”. Not realizing that the top breakers grouped together were all main service disconnects. By the way, is there anything marked on the cover as a main disconnect? Usually the “Main service disconnect” is a sticker on the breaker, and the circuit directory has the loads description. I only see a furnace sticker.
micromind likes this.
Why say lot words when few words do trick
Old 10-07-2019, 09:10 PM   #14
Band Member
emtnut's Avatar
Your eyes are better than mine ... I had to look 10 times and then I saw the top conductors going behind. I thought it was on the top at first look.
Old 10-07-2019, 09:16 PM   #15
Mensa Player
Rewards Points: 487
Those conductors feeding the panel look new and smaller than what would be run through that pipe. For some reason I have a feeling that the original feed was 150 or 200 A and landed on the main lugs. Then for some reason they changed it to a 100 and feed and backfed the 100 amp breaker.
HertzHound likes this.
Old 10-07-2019, 09:22 PM   #16
HertzHound's Avatar
The other day someone showed a picture of a new Square D generator ready panel. How is that panel legal. It looked like the old split buss panels. I could see if there were two feeds in the panel. But this has one buss being fed from another buss in the same enclosure?
Old 10-07-2019, 11:05 PM   #17
Rewards Points: 26,360
The second DP breaker at the upper right ( poles 6,8) could be omitted if the bottom bus was fed via the top ex-Mains lugs.
Logically, poles (2,4) are being back-fed. They energize the top buss. This includes energizing the MLO bus extension seen at the top.
It's not evident, but I suspect that poles (6,8) are off of a reduced breaker, say 50-60 Amps.
Then the wiring would make sense.
This MLO set-up probably has a disconnecting means up the line.
So the 100 Amp breaker really is redundant -- as noted above.
Old 10-07-2019, 11:53 PM   #18
CoolWill's Avatar
My take is that this is a split bus panel that has been converted into a main breaker panel. Other than being a little confusing to the uninitiated, I think it's a good way to avoid ripping out what is otherwise a functional panel. All the split bus panels I've ever seen had no way to disconnect them besides pulling the meter and needed to be ripped out. This little workaround was a money saver.
Old 10-08-2019, 12:53 AM   #19
Rewards Points: 930
That main breaker looks like a 125A. Anything over 100A on SQ goes to this frame size
Kevin_Essiambre likes this.
cdslotz is offline   Reply With Quote
Old 10-08-2019, 01:56 AM   #20
Rewards Points: 2,932
When this panel was originally installed, anything 70 and higher was the long style.
cdslotz and Kevin_Essiambre like this.
