two main panels - Electrician Talk - Professional Electrical Contractors Forum
Old 04-02-2010, 09:20 PM   #1
Default two main panels
1954 House has overhead service, appears to be a 3/0, a main panel / meter combo with a buss bar conductor, a 200 amp breaker, a breaker for the A/C, one for heat and one for the WH. There was another panel in the kitchen with 3/0 Al cable and a 150 amp main. Many other breakers that panel just like any other main panel.
So, how does the cable to the interior panel attach inside of the meter/exterior main and how is that related to the buss bar to service wires?
And, I have always wondered, how this would not be a potential overload for the overhead wires? I know the utility rates their capacity different and they assume that a full load will never be drawn from all devices on the panels at the same time. Just seems odd.
68 Malibu 383 is offline   Reply With Quote
Old 04-02-2010, 09:30 PM   #2
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
potential overload for POCO's conductors - no such thing - cant happen
Old 04-02-2010, 09:30 PM   #3
Licensed Journeyman
nolabama's Avatar
welcome to the forum
Old 04-02-2010, 09:50 PM   #4
Rewards Points: 1,000
Sounds like there is too much service cable in the house. The loaded panel should be a sub-panel if the service is more than five feet in the house.
Old 04-02-2010, 09:52 PM   #5
Licensed Journeyman
nolabama's Avatar
^^^wtf?^^^
Old 04-03-2010, 07:49 AM   #6
I would think a sub panel would be the way to go here. How would you determine if the system were overloaded?
Old 04-03-2010, 09:29 AM   #7
Rewards Points: 2,222
Maybe I am not following this post well but do you have a 200 amp or 400 amp meter/ combo unit? If it is a 200 amp service then I don't think that you legally insert a 150 amp breaker to the buss of the meter combo panel. Most 200 amp units won't allow more than 125 amps to a breaker on the buss.
I can't help it if I'm lucky
Old 04-03-2010, 09:54 AM   #8
Rewards Points: 2,050
Is the 200 amp breaker the main for all or not?
Old 04-03-2010, 02:11 PM   #9
My bad. What I envisioned was one, 200 amp panel within a few feet of the meter and another 150 panel deeper into the house, both being fed by the same meter socket. I have no clue if that is accurate, but another 150 amp main at the meter feeding the 150 amp panel would solve the problem of having too much service cable in the house. I'd probably look hard to see if I could upgrade the 150 amp to a 200 amp fed by a 200 amp main out by the meter socket.
Get the local PUCO to do a "meter survey" before messing with any of it.
Meter Main John Valdes General Electrical Discussion 18 01-20-2010 12:28 AM
With a 125 amp main do I have 125 on each leg??? frank_cali General Electrical Discussion 1 05-16-2009 09:07 PM
UK: Gas main bond Trimix-leccy UK Electrical Forum 6 03-02-2009 08:30 PM
gri main breaker wire monk General Electrical Discussion 0 02-19-2009 07:32 PM
sub main in flats uk largelunchbox UK Electrical Forum 2 07-28-2008 12:34 PM
