TYCO Romex Splice Kit - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree68Likes
Old 08-25-2017, 08:05 PM   #41
neutral member
readydave8's Avatar
Rewards Points: 566
Re-reading my post #7, I'm not convinced that if it had been in response to something I said, that I would have taken it as a personal attack
Dave Ruth
Old 08-25-2017, 08:11 PM   #42
neutral member
readydave8's Avatar
Rewards Points: 566
Even though there are NEC rules that I knowingly break (for example, I'm still stapling romex under joists in crawls instead of drilling),
I don't like buried boxes
Or the kit in question
Only ones I've ever seen are in mobile homes
Dave Ruth
Old 08-26-2017, 12:48 AM   #43
Rewards Points: 286
Yup and in that case they fit right in with the other half-assed wiring methods and devices.
readydave8 (08-26-2017)
Old 03-10-2019, 10:26 AM   #44
I am new here but been doing this for about 25 years. I have recently seen these splice kits and feel the same as some others on here; They do not look reliable. I try not to splice in a wall, but we all know that sometimes it needs to be done. Whenever I have had to do it, I use a box, solder my splices, cap with wirenuts, and tape around the wirenuts. I don’t see how that cannot be better than one of those junk splice kits.
earle310 is offline   Reply With Quote
Old 03-10-2019, 11:17 AM   #45
Rewards Points: 7,520
Originally Posted by earle310 View Post
I try not to splice in a wall, but we all know that sometimes it needs to be done. .
No it doesn’t. It can always be done properly, there never has to be splices in the walls, it just takes more work. In Canada we can not use these, no splicing in walls allowed yet we manage to still get the job done.
MechanicalDVR (03-11-2019)
Old 03-10-2019, 03:57 PM   #46
Rewards Points: 846
I am not sure code if changed regarding them....but i used they TYCO ones in a factory built housing job ....the houses came in pre- finshed, pre-wired,pre-plumbed sections,
Had to connect labeled romex wires between sections.
Old 03-10-2019, 06:58 PM   #47
Rewards Points: 3,712
OK BITCHES FOR ONCE AND FOR ALL I AM ABOUT TO SETTLE THIS CONTROVERSY
I have some bad news for some of you.
Here are the instructions for the device:
http://www.te.com/commerce/DocumentD...df%7F1116377-2
Here is the Application Specification:
https://www.te.com/commerce/Document...df%7F1116377-2
Look at section 3.3 on page 2 of the Application specification.
3.3. Installation
A. Factory
Type NM-1 and NM-2 devices must be factory installed on the free end of a nonmetallic sheathed cable. The
Type NM-3 device is must be factory installed anywhere along a nonmetallic sheathed cable. The cable
must be prepared (cut, stripped, and formed) to allow the device to be assembled in only one position (to
maintain the integrity of the polarity arrangement). The conductors and stripped cable jacket are completely
within the enclosure and strain-relief cover. When used to connect expandable or dual-unit mobile homes,
the connector ends are to be located where they are protected from moisture and physical damage during
transport to the mobile home lot.
B. Building Site and Dwelling Site
The separate modules of a building or dwelling assembled on location are to be connected electrically by the
simple plug-in connection (including a mechanical latch) of mating pairs thereby providing circuit continuity.
The connected pairs may or may not be fastened in place. The connected pairs may or may not be
concealed by the installation.
AS SOME MAGNIFICENT BASTARD MAY HAVE MENTIONED THIS IS FOR USE WITH MANUFACTURED / MODULAR HOMES
and by hacks and Home Depot Demons every weekend.
File Type: pdf Application Specification 114-10045.pdf (755.4 KB, 55 views)
TGGT and lighterup like this.
The Following 3 Users Say Thank You to splatz For This Useful Post:
telsa (03-10-2019), TGGT (03-10-2019), wmbettsjr (03-11-2019)
Old 03-10-2019, 07:55 PM   #48
Rewards Points: 1,874
Good to know. I've used them before. They suck, I'd rather hide a wire nut in the wall than that thing.
Old 03-10-2019, 10:12 PM   #49
Rewards Points: 1,175
Yep, I'd think splices in an all steel handy box would be a lot less dangerous than one of these.
JoeSparky, MTW and splatz like this.
Old 03-11-2019, 09:28 AM   #50
Now that I think about it, levernuts are perfect for burying and should be listed to do so.
Old 03-11-2019, 10:14 AM   #51
Rewards Points: 421
I love lever nuts, but I would never use them on a buried splice.
John Valdes likes this.
Old 03-11-2019, 03:21 PM   #52
I like the handi box idea. I normally try to get it under the house or into the attic. Another idea I have been using is to locate the junction box behind the mirror in the bathroom if it's removable. I do a LOT of bathrooms lately.
Thank you Splatz for the info on those damn plugs. I was under the impression that they were listed for use in the wall but never looked into it because they seemed like a bad idea
Sent from my SM-S327VL using Tapatalk
wmbettsjr is offline   Reply With Quote
Old 03-11-2019, 05:00 PM   #53
They seem like sturdy splices. It's the kind of mechanism I think UL listed device for covering up would be perfect for.
Old 03-11-2019, 05:20 PM   #54
Rewards Points: 421
For normal stuff I think they are great. But if I want to bury a splice I want to use the best method possible. I think twisting two wires together and using a good quality wire nut is better.
MTW likes this.
Old 03-11-2019, 10:44 PM   #55
zac
Rewards Points: 816
Kearney split bolt that splice!
Old 03-11-2019, 11:22 PM   #56
Government Services
Have had thse fail in modular rental buildings used for temporary quarters on several jobs Often there is ot enough slack in the cable to replace them with a standard junction but you need to add some cable and use two boxes.
MCasey is offline   Reply With Quote
Old 03-12-2019, 08:23 AM   #57
Can't Remember
Rewards Points: 864
When I was an apprentice and was doing modulars, we’d cut those off and splice in nail ons and four squares.
Old 03-12-2019, 09:45 AM   #58
sbrn33's Avatar
Rewards Points: 3,248
There is no need for twisting the wires together.
zac and readydave8 like this.
Old 03-12-2019, 10:03 AM   #59
Rewards Points: 421
Of course there is. Wirenuts twist the wires together, which makes a great connection.
electricguy likes this.
Old 03-12-2019, 10:38 AM   #60
Rewards Points: 2,956
rewriting the code for your own convenience does not seem professional to me.
Romex Connectors for Oil Resistant Cable sparkiez NEC Code Forum 6 09-27-2017 04:44 PM
Running romex underneath cabinets NDC Canadian Electrical Forum 52 08-16-2017 10:34 AM
Romex in Channel : Wood Cabinet onilozay General Electrical Discussion 11 12-28-2016 04:29 AM
Romex in conduit Incubus311 General Electrical Discussion 38 12-27-2016 06:16 PM
Splice VS insulation repair psgama General Electrical Discussion 2 09-20-2016 10:01 PM
