TYCO Romex Splice Kit - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree68Likes
Old 03-12-2019, 02:28 PM   #61
Going_Commando's Avatar
Rewards Points: 1,372
There is no need for twisting the wires together.
I don't understand why you would make an inferior splice by not pre-twisting before applying the wirenut. I can twist wires together with my linemans far better than a wirenut can. Heck, just a couple weeks ago I did a service call for lights and outlets not working, and found where a wire had pulled out of a wirenut 10 years after it was installed, because they didn't pre-twist their wires together, and trusted the wirenut to do it for them. I twisted the wires together properly, put on a new wirenut, and now the splice is good for 50+ years.
Old 03-12-2019, 02:43 PM   #62
Rewards Points: 1,875
If you could get a good grip on the wires, hold them even, twist on the wire nut and really torque it down, then it will be a pretty damn good splice. It will also usually twist the wires together. But its a lot of work to keep twisting that wire nut, some people even use a tool to do it, so its easier just to give the wires a couple twists with your lineman pliers before hand.
It depends on the situation, if I was looking to make a bullet proof splice I would definitely twist the wires together
shocksystems likes this.
Old 03-12-2019, 03:04 PM   #63
zac
Rewards Points: 812
Takes less time. I will wrap a stranded wire around a solid wire but I don't twist solids.
The wingnut is sufficient enough. I always pull my wires too to see if there snug.
If like Hack says it needs to be bullet proof, I'm twisting them doggies.
trentonmakes likes this.
Old 03-12-2019, 03:40 PM   #64
sbrn33's Avatar
Rewards Points: 3,136
If you look at the facts and studies, there is more surface to surface area when you do not pretwist.
Old 03-12-2019, 03:42 PM   #65
Can you link to these studies?
How do you keep the wires straight? How do you prevent the wirenut from twisting them together when you install it?
Old 03-12-2019, 03:47 PM   #66
Here is an example that 220/221 posted a long time ago:
That is (4) #12's. I'm sure with less #12's or #14's the hand twisted conductors would be even more twisted.
So that is bad, according to the facts and studies? Should we stop twisting wirenuts on and just push them down onto the wires?
Old 03-12-2019, 05:46 PM   #67
zac
Rewards Points: 812
Attachment 133058
The facts are as I've studied my experiences, twisting wire takes longer and is a pain to break apart the wires when troubleshooting... especially fun when it's hot! Must be an East coast thing because its rarely done around here.
Old 03-12-2019, 05:50 PM   #68
I was just messing with Sabrina about his facts and studies
sbrn33 likes this.
Old 03-12-2019, 05:52 PM   #69
zac
Rewards Points: 812
I figured that...i just needed to let that off my chest. I've encountered service upgrades where they made one huge dreadlock with the ground...... killing me!
Old 03-12-2019, 06:35 PM   #70
MTW
MTW's Avatar
Rewards Points: 6,992
So it's ok to use a junky Tyco connector buried in the wall of a modular or manufactured home. But you can't make a bulletproof splice in a box and bury it in a wall. Yes, I know one is subject to workmanship and one is not. But I know I can make a bulletproof splice and bury it and be totally fine with it lasting 100 years trouble free, just like all the K&T out there.
sbrn33 and trentonmakes like this.
Old 03-12-2019, 06:50 PM   #71
trentonmakes's Avatar
Rewards Points: 138
This is exactly how I feel after learning more about those tyco connectors.
Technically, they are only to be used to repair wiring anyways.
I think a splice in a carlon box and blank plate is much better if your going to bury a splice.
Old 03-12-2019, 07:50 PM   #72
Rewards Points: 2,828
https://www.electriciantalk.com/f2/t...3/#post5174226
Old 03-12-2019, 07:57 PM   #73
I am a magnificent bastard.
Old 03-13-2019, 06:01 AM   #74
Rewards Points: 138
334.40 (B) Devices of Insulating Material. Self-contained switches,
self-contained receptacles, and nonmetallic-sheathed cable interconnector
devices of insulating material that are listed shall be
permitted to be used without boxes in exposed cable wiring and
for repair wiring in existing buildings where the cable is concealed
Old 03-13-2019, 06:28 AM   #75
Doesn't that mean it has to be listed for the purpose when used according to the device's instructions? I can't see this being a rule giving you permission to bastardize a device listed for something else.
Old 03-13-2019, 08:10 AM   #76
Rewards Points: 138
Yes, but there are others besides tyco
I have a couple in my truck, I'll look and see what brand they are.
The code leads me to believe some are listed for that use.
Old 03-13-2019, 03:06 PM   #77
Rewards Points: 17,496
Originally Posted by nrp3 View Post
When I was an apprentice and was doing modulars, wed cut those off and splice in nail ons and four squares.
It would be nice if everyone did that.
Old 03-13-2019, 03:14 PM   #78
Snopes says: partially true!
Old 03-14-2019, 10:58 AM   #79
Rewards Points: 138
The ones I had are TE Connectivity
Old 03-14-2019, 11:00 AM   #80
The ones I had are Tyco Electronics Connectivity
Romex Connectors for Oil Resistant Cable sparkiez NEC Code Forum 6 09-27-2017 04:44 PM
Running romex underneath cabinets NDC Canadian Electrical Forum 52 08-16-2017 10:34 AM
Romex in Channel : Wood Cabinet onilozay General Electrical Discussion 11 12-28-2016 04:29 AM
Romex in conduit Incubus311 General Electrical Discussion 38 12-27-2016 06:16 PM
Splice VS insulation repair psgama General Electrical Discussion 2 09-20-2016 10:01 PM
