Type of box for this 6-50R? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By Canaduh
  • 1 Post By HackWork
  • 2 Post By trentonmakes
Old 09-19-2017, 10:33 AM   #1
Rewards Points: 330
Default Type of box for this 6-50R?
What type of box would you use for this receptacle? https://www.homedepot.ca/en/home/p.5...000423315.html
I'm thinking a 4-11/16 with a single device plaster ring and finish it with a utility cover of appropriate size. It's for an ev charger.
Any suggestions?
Navyguy likes this.
Canaduh is offline   Reply With Quote
Old 09-19-2017, 04:28 PM   #2
Rewards Points: 21,896
Any suggestions?
Surface mount or flush mount ??
If surface I would use hard raised cover.,
flush mounted try to get pretty deep ringcover but watch the drywall or whatever thickness to make it flush.
Old 09-19-2017, 04:41 PM   #3
Rewards Points: 1,153
If you're flushing mounting it in drywall, I would do what you suggested.
Support the box VERY well since a lot of force is used to insert and remove large plugs like that.
frenchelectrican likes this.
Old 09-19-2017, 04:43 PM   #4
That part I do agree with that and it the same way with surface mounted too make sure you hit something good and soild.
there will be some gorllia grunts will be wresting with it.
Old 09-19-2017, 04:44 PM   #5
Rewards Points: 330
Just realized I can go with a surface mounted welder receptacle instead. Much cheaper and less work.
Old 09-19-2017, 04:45 PM   #6
Rewards Points: 330
EV charger needs a disconnect as well but amirite in assuming that the receptacle technically is a disconnect right?
Old 09-19-2017, 04:46 PM   #7
Yeah, I like the surface mounted ones that can be used outdoors. I usually use the 14-50R though.
Old 09-19-2017, 04:49 PM   #8
I don't know Canadian code on this. In the US, a 50A charger wouldn't require a disco. But when a disco is required, the cord&plug isn't counted as one.
FWIW, they make the outdoor surface mounted discos with breakers in them if you need a disco.
Or you can just say it's for a welder
Old 09-19-2017, 04:49 PM   #9
trentonmakes's Avatar
Rewards Points: 138
Kind of ran into this today with mudrings and lousy drywallers.
The outlets were recessed way too much. Several of these things between outlets and box solved the issue.
Texting and Driving
frenchelectrican and HackWork like this.
Non-Contact DC (not AC) Detector Pen type zillah General Electrical Discussion 20 09-02-2017 06:07 PM
SO Type Cords That Do Not Fall Apart After Years? Jerome208 General Electrical Discussion 23 06-06-2016 09:52 AM
Mr16 halogen problems gu7 base type dham206 Commercial Electrical Forum 1 05-18-2016 08:40 PM
Looking for a fixture type wy2ak Lighting Design 9 04-14-2016 12:39 AM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 09:09 PM
