Type CH Eaton/Cutler Hammer CB's - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 3 Post By RePhase277
  • 1 Post By frenchelectrican
  • 3 Post By backstay
Old 01-31-2017, 07:28 PM   #1
Rewards Points: 1,972
Default Type CH Eaton/Cutler Hammer CB's
Do not tell me to google this I did a quick search so I am going to the electrical knowledge boys and girls
What is the largest 2-pole Eaton/Cutler Hammer CB made. I found a two pole 100
that takes 2 spaces and I have a 80 that takes 4 spaces.
Old 01-31-2017, 07:32 PM   #2
Rewards Points: 1,360
125 amp is the largest they make that snaps on the bus, I think.
brian john, jw0445 and samgregger like this.
Old 01-31-2017, 07:51 PM   #3
Can't Remember
Rewards Points: 502
If you are talking CH probably 125 amp two pole. They do have a larger frame snap in that I've used in 400 amp panels in rest to feed 200 amp panels. Forget the series.
Old 01-31-2017, 08:24 PM   #4
sbrn33's Avatar
Rewards Points: 3,508
They used to make a 125 not so sure if they do now though. I buy 100's all the time.
Old 01-31-2017, 09:41 PM   #5
backstay's Avatar
Rewards Points: 296
125 CH is the biggest I've ever seen.
Old 01-31-2017, 09:45 PM   #6
Rewards Points: 21,896
The CH breaker I know the biggest one I did install was CH2150 it is four pole verison and keep in your mind some of the older CH breaker do have bumpout front of the breaker housing to prevent to install any breaker across the bussbar. Note: I think the modern verison can able fit in pretty good but limited to 20 amp across the larger breaker as I posted above.
However .,, the 125 and 150 2 pole breaker they are used in 400 amp or larger panels but only quirk is the dammed three phase panel you may have to flip the crossbar if needed to but I doubt because it did come with interal jumper bar plus the conductor termation is not at 90° at all more like about 50° angle from the breaker mounting.
The reason why it bend the mounting location due the larger conductor bending radius.
brian john likes this.
Old 01-31-2017, 09:51 PM   #7
Can't Remember
Rewards Points: 502
CH2125 looks to be the largest two pole listed in the catalog.
Old 01-31-2017, 10:08 PM   #8
backstay's Avatar
Rewards Points: 296
150 amp plug in.
https://m.platt.com/Products.aspx?pid=9997
Old 01-31-2017, 11:16 PM   #9
That's nuts! Are the bus stabs even rated for that?
Old 01-31-2017, 11:24 PM   #10
Ya .,, but only on 400 amp panels or largers but not on run of mill 200 amp panels. due the main bussbar is not very large compared to 400 amp verison.
Old 02-01-2017, 12:14 AM   #11
Rewards Points: 18,161
I don't know about the CH line so much but if it is the BR line, 150 amp, takes 2 spaces, special order usually not stocked at supply houses cause they don't sell many , and &&&&&&&&&&&&&&&&&&&&&&&&&&&&&
I'd like to see one breaker panel or meter/main socket that will accept it not mechanically, it fits just fine like a 2 pole 100, but the panel labeling states 125 amp max breakers in this can on all the Eaton panels and main sockets I ever looked at. But anyway, you can get yourself a 2 pole 150 amp BR thru your supply house guy. My buddy Brian the Electrician out here just got himself one a few months back and it saved the day for him on some job , cause the inspector doesn't know what macmike knows- the can is not listed for a 150 amp clip in breaker. He called me in a panic (as usual) asking if I knew if they made one. Got him fixed up at ''One Source Distribution"".
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 02-01-2017, 06:00 AM   #12
backstay's Avatar
Rewards Points: 296
I don't see that in the spec sheet. It does say "loadcenter". This is a four space breaker, not the normal two. The page says residential and light commercial.
The Following 2 Users Say Thank You to backstay For This Useful Post:
frenchelectrican (02-01-2017), telsa (02-01-2017)
Old 02-01-2017, 09:16 AM   #13
Backstay.,,
I understood what you are saying on the words but I know as I mention earlier on the posting as I did mention before it is a 4 space verison.
I did remember some of my installment sheet what I have but unforetally I do not have it with me now but it did not mention too much on that part.
Yes I am aware that is used common in residential and light commerical useage.
Old 02-01-2017, 09:34 AM   #14
sbrn33's Avatar
I know Siemens makes a sub feed lug kit. No fusing at all just slips on the buss. I have used it before for a large sub panel set up.
Need to know what type of math will be on the aptitude test. thespark Electrician Apprentice Forum 27 10-31-2019 03:31 PM
Bosch SDS-MAX Inline Demo Hammer *New* mark35 Electrician Swap 14 12-12-2016 11:49 AM
Hammer Drill for tight place Twigman Thomas Tools, Equipment and New Products 15 11-16-2016 08:37 AM
what is the best sized hammer for residential work? hatsgoods Tools, Equipment and New Products 59 07-29-2016 06:57 PM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 09:09 PM
