Typical nut sizes for pole bases? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree28Likes
Old 06-08-2019, 05:50 PM   #1
Rewards Points: 1,070
Default Typical nut sizes for pole bases?
Up until recently, I've always been a helper and have had to use whatever the Journeyman throws at me for tightening and loosening the bolts at pole bases for lights that you see in parking lots and what not. It's always been a giant adjustable wrench with a cheater bar or a giant pair of channellocks. Now that I have a van, I'm looking to invest in some sockets instead. I was just wondering what size nuts you typically see at light pole bases? The poles I work on are typically something like 30ft - 40ft poles give or take. Sometimes less, sometimes more.
I'm just going to buy a set online, I just don't know what sizes to buy. Thanks for your help!
Old 06-08-2019, 07:56 PM   #2
Small Potatoes
flyboy's Avatar
Rewards Points: 3,498
If memory serves me, they are 3/4 to 1". I think.
Old 06-08-2019, 09:44 PM   #3
RSE Master Electrician
Incognito's Avatar
Rewards Points: 632
I was on a service van for many years and bought my own sockets and cheater bar for light posts. These were individual sockets, not in a set. I still have them and just looked, they are 1”1/8 and 1”1/4
MikeFL likes this.
2018 Ontario Electrical Code
Old 06-08-2019, 09:44 PM   #4
Thanks, I think you're pretty spot on. I forgot that I could basically search "anchor bolt" and it seams like 1" and 3/4" are just about what is used. Appreciate the help!
Edit: Awesome thanks Incognito. Will make sure I have those as well!
Old 06-08-2019, 09:50 PM   #5
Incognito's Avatar
Rewards Points: 632
I’m sure many post bolts are 1” and smaller as well, which come in most socket sets, but I definitely bought those individual ones for posts at one time because my set only went up to 1” and I needed them.
Old 06-08-2019, 09:53 PM   #6
Modrateur
Rewards Points: 16,780
I have work on parking lot luminaires abit so I am famuair with the size
typically one inch or larger nuts so expect that the shorter poiles will use 7!8 or one inch nuts but larger one use 1 1!8 or 1 1!4 but few I ran into are inch and half but once a blue moon you will slam into metric verison ( common in my area ) useally 25 or 30mm is norm to use it.
get them in 3!4 inch socket driver they will hold up better than common half inch socket driver. I have both 3/4 and inch drivers on hand so I can deal some pretty big arse units.
JasonCo likes this.
Old 06-08-2019, 10:14 PM   #7
Perfect, thanks! I was looking at some sets on Amazon that come in a 3/4" drive, and then I noticed a set that was 1"... I'd go with the overkill but they are like $250+. The 3/4" I'm looking at is $137 with crazy good reviews
https://www.amazon.com/TEKTON-4-Inch...ct_top?ie=UTF8
Old 06-08-2019, 10:41 PM   #8
Modrateur
Check out the Habor Fright or one of tool supply centre they should have them on hand with reasonable price.
Make sure you get the cheater or breaker bar along with that. ( you will use the breaker bar more often to get them loosen up )
and the toqure valve to lock them down typically 350 plus footpounds check the specs on the achor bolts and size of them that will change a bit.
that why I use 3/4 inch driver often. I just got done with one not too long ago with 12 meter pole that need almost 500 ft lbs toqure to lock it down.
flyboy likes this.
Old 06-08-2019, 10:48 PM   #9
Rewards Points: 2,582
Generally speaking, the nut on a 3/4" bolt will be 1 - 1/8". If it's a 'heavy' nut (fairly common on light poles) it'll be 1 - 1/4"
For a 7/8" bolt, standard would be 1 - 5/16". Heavy is 1 - 7/16"
A 1 " bolt will be 1 - 1/2". Heavy is 1 - 5/8".
Sometimes, for smaller poles, you'll see 5/8" bolts. The nut size here is 15/16" and 1 - 1/16".
Old 06-08-2019, 10:54 PM   #10
MikeFL's Avatar
Rewards Points: 2,714
This guy just learned more than he wanted to about nut sizes.
Ouch!
https://www.foxnews.com/sports/seatt...-ball-to-groin
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 06-08-2019, 11:36 PM   #11
Ouch!
Damn, he suffered a ruptured testicle and basically brushes it off and gets ready for the next pitch lol, wtf... This is why I'll never be a pro at any sport.
@micromind Damn good information, thanks!
The Following User Says Thank You to JasonCo For This Useful Post:
micromind (06-09-2019)
Old 06-09-2019, 05:32 AM   #12
Small Potatoes
flyboy's Avatar
It's obvious you guys are just "nuts".
Old 06-09-2019, 06:05 AM   #13
460 Delta's Avatar
Rewards Points: 686
With a few exceptions, a utility size nut is 1 1/2 x the diameter of the bolt. A heavy or 2H nut is 1 1/2 x the diameter + 1/8.
The Following User Says Thank You to 460 Delta For This Useful Post:
splatz (06-09-2019)
Old 06-09-2019, 08:05 AM   #14
Rewards Points: 3,726
Same here, the inability to disregard testicle injury is what kept me out of the big leagues. That, and the lack of athletic talent.
JasonCo and CoolWill like this.
Old 06-09-2019, 08:20 AM   #15
CoolWill's Avatar
Rewards Points: 2,016
This guy ruptured his nut in the 3rd inning and stuck it out four more innings... What a wimp. He should have just walked it off and finished the game. If he loses that nut, he can always buy a Sprinter and start hanging ceiling fans.
macmikeman and splatz like this.
I'm With Her! Hillary 2016
splatz (06-09-2019)
Old 06-09-2019, 08:31 AM   #16
Rewards Points: 465
Originally Posted by coolwill View Post
this guy ruptured his nut in the 3rd inning and stuck it out four more innings... What a wimp. He should have just walked it off and finished the game. If he loses that nut, he can always buy a sprinter and start hanging ceiling fans.
Old 06-09-2019, 08:58 AM   #17
I did not know that! That's a lot easier than searching the internet to look it up every time.
To the OP - my advice would be, unless you are pretty sure you are going to use all these sizes regularly, maybe don't buy the set, just buy quality stuff in the size or sizes you need now, add the others later.
If you need to be ready on the spot when the need arises for all the sizes, yes, buy the set.
But, you buy the set and find out something's metric, or you find your set skips 1-7/16 and that's what you need, or etc., and you still wind up buying or borrowing singles.
If it's not something you need the same day, singles are usually not that bad to buy on the internet. Unless you can borrow them, which I usually can. At the local industrial supply, you might as well just leave your wallet in your pants and give them your pants if you have to buy singles. But it's still way ahead of buying a set full of stuff you never use.
I have too many "sets" I bought that 10 or more years later, all but two sizes still have the factory dust on them, never been used. And that's if they don't get lost, stolen, or permanently borrowed.
CoolWill likes this.
Old 06-09-2019, 12:34 PM   #18
Modrateur
The other item you will need it often is wire brush wheel cuz you will have to knock some rust off the threads before you remove the nuts off the bolts that will make a big difference on the time you save.
micromind and JasonCo like this.
Old 06-09-2019, 12:55 PM   #19
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 310
Wire brush...or a can of brake clean and a blow torch to burn the crud off.
frenchelectrican likes this.
When in doubt, run in circles, scream and shout.
TheLivingBubba is online now   Reply With Quote
Old 06-09-2019, 03:09 PM   #20
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 5,456
Just go big
But they are pricy..
