Under slab - Electrician Talk - Professional Electrical Contractors Forum
Old 05-25-2019, 08:51 PM   #1
mpcxl's Avatar
Rewards Points: 60
How do you all like doing under slab work ? Any good methods or techniques you enjoy using ?
mpcxl is offline   Reply With Quote
Old 05-25-2019, 10:23 PM   #2
Rewards Points: 226
Did that work for years. Early days.
Work looks great. Strip mall?
Old 05-27-2019, 01:20 AM   #3
Rewards Points: 1,361
It's great until an overzealous concrete finisher shears your stubs off with a power trowel
Old 05-27-2019, 03:23 AM   #4
canbug's Avatar
Rewards Points: 1,874
I've done my share but not a lot really. I always looked forward to see if I actually put them where they belong. I'd say I was 99% correct?
The last one was a 30, 4inch duct bank into one of our Field Electric Centers.
Tim.
Old 05-27-2019, 07:06 AM   #5
Southeast Power's Avatar
Rewards Points: 8,682
This is our Carvana job. We are trying to get as much in the slab as possible, The power in the foreground, server room in the background.
This not well shown is the 4" for the utility or the 3- 4" for the data. The Statement amount for the job this month for PVC is over $5,000
Server room looking towards the electric room.
Old 05-27-2019, 09:08 AM   #6
Rewards Points: 1,230
Use spacers and tie wire the conduit to it.....4 inch spacers are fine for large jobs that will have conduit from 4 inch down to 1/2 inch
http://www.alliedeg.us/pvc/duct-spacers/
bostonPedro is offline   Reply With Quote
Old 05-27-2019, 09:38 AM   #7
MTW
Rewards Points: 10,168
I've never done this work so I'm curious about a few things - how do you go about the measurements? Do you have to measure the entire foundation first to verify that it's built to plan, then go from there? Are measurements for conduits shown on drawings, or do you just go by wall locations from the framing plan? And how do you do that actual measurements? Obviously I know about the old school way of using long metal tape measures and checking from both directions but are there new ways with digital surveying equipment?
Old 05-27-2019, 09:59 AM   #8
Drawings differ but usually they just have the conduit top location by that I mean where it 90's up and a distance off a set object. More detailed drawings as I saw on a very large tunnel project have more information and detail and looked more like the drawings of pipefitters which are damn impressive to say the least. A newer method is to use a Trimble which uses global satellites to pinpoint exact locations( they do however have to be recalibrated which many companies forget to do)
Old 05-27-2019, 10:27 AM   #9
mpcxl's Avatar
Rewards Points: 60
Conduit locations are decided upon where we think good locations are to “pick up” a lot of circuits easily.
I believe the walls of the hotel were gps allocated and marked by GC.
From there, we use architectural measurements and or scale arch. prints.
Old 05-27-2019, 10:38 AM   #10
Rewards Points: 1,760
In residential work we have to measure from the plans and hope they don't move walls. That is why we try and come up in the outside walls. It is a bit scary but we have always come up in the correct places.
On our jobs we usually have the stone in place since we only have a few runs and we just rake the stone out of the way. The builders like using a bobcat inside the foundation so we don't install it until the stone is down.
I can't help it if I'm lucky
Old 05-27-2019, 11:11 AM   #11
MikeFL's Avatar
Rewards Points: 598
Read the specs!
I've seen transformers blow up when guys don't follow the specs. And under a slab is a very expensive place to make changes after the slab is in. If the plans don't have enough detail to absolutely know the location is correct, do an RFI so you have something in writing.
For in-slab work pay particular attention to location, spacing and concrete cover for structural reasons. You don't want to be the reason there's failure in the structural work.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Can I run romex below a plywood subfloor above a concrete slab? BearMormont General Electrical Discussion 3 10-10-2018 04:47 PM
8 Volts from water in hot tub to concrete slab with power disconnected from house oldsailordbf General Electrical Discussion 9 07-27-2018 08:09 PM
Calling on foremen, slab experts, and people with an opinion haltonelectrician General Electrical Discussion 4 05-20-2018 08:55 PM
pvc in slab and cmu wall d1rek Commercial Electrical Forum 11 08-19-2017 03:53 PM
Conduit through concrete slab - cap ailment2084 General Electrical Discussion 1 06-17-2016 03:11 PM
