Underground Comm Conduit - Electrician Talk - Professional Electrical Contractors Forum
Old 02-26-2015, 04:44 PM   #1
Rewards Points: 3,118
Default Underground Comm Conduit
I need to get a cat 5 cable through a 2 inch conduit. the run is about 225 ft there is a CATV RG11 cable and a 25 pair telco cable in it. I have never "blown" a string into a conduit before. Can this be done ?
Thanks
Old 02-26-2015, 04:49 PM   #2
halfamp's Avatar
Rewards Points: 516
What's wrong with your fishtape?
halfamp is offline   Reply With Quote
Old 02-26-2015, 04:51 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
If this were me, I'd tie onto that catv , and pull in two with it.
The Following 3 Users Say Thank You to mcclary's electrical For This Useful Post:
John Valdes (02-27-2015), pete87 (02-26-2015), Spunk#7 (02-26-2015)
Old 02-26-2015, 05:19 PM   #4
RG 11 is expensive and fairly rigid my 200 ft fish tape is probably 150 ft by now or less
Old 02-26-2015, 05:32 PM   #5
Rewards Points: 374
I would try a jet line and a plastic bag with a shop vac and if it did not go quick and easy then I would tie on to the RG11 with two lines. one for the new cable and one to pull the RG11 back in afterwards.
Hawkrod is offline   Reply With Quote
The Following User Says Thank You to Hawkrod For This Useful Post:
samgregger (02-26-2015)
Old 02-26-2015, 05:33 PM   #6
360max's Avatar
Rewards Points: 1,234
Walmart plastic shopping bag, string, tie string thru handles of shopping bag and vacuum it in.
Old 02-26-2015, 05:46 PM   #7
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 192
You can blow it or use the vacuum side with a plastic bag. Just make sure the "pig" moves easily through the pipe and fills the void completely.
Cowboy words of wisdom.
Never approach a bull from the front, a horse from the rear, or a fool from any direction.
Old 02-26-2015, 05:55 PM   #8
Rewards Points: 27
It will probably be tough to suck a bag thru that pipe. Know how many 90's? That's where the bag will get stuck in those cables. Best bet is to tape up the vacuum tube to the conduit and cables to get the best seal. Can you pull one of the cables out? Tie a string to the end you pull out and remember to tie another string on when you pull your cables back thru! It would probably be easier to pull the 25 pr out versus that rg11.
LoVolt134 is offline   Reply With Quote
The Following User Says Thank You to LoVolt134 For This Useful Post:
glen1971 (02-26-2015)
Old 02-26-2015, 06:01 PM   #9
The 25 pair is direct burial type and is connected, it is a motel.
Old 02-26-2015, 06:04 PM   #10
evil bastard
Rewards Points: 746
I've never vacuumed a line in with wires. I always use one existing as a pull line.
The Following 6 Users Say Thank You to mcclary's electrical For This Useful Post:
Cow (02-26-2015), five.five-six (02-26-2015), glen1971 (02-26-2015), John Valdes (02-27-2015), pete87 (02-26-2015), Vintage Sounds (03-03-2015)
Old 02-26-2015, 06:11 PM   #11
Rewards Points: 1,702
You can repul in the RG11 cable if you like , if a line is used when pulled out .
Pete
pete87 is offline   Reply With Quote
The Following User Says Thank You to pete87 For This Useful Post:
electricguy (02-26-2015)
Old 02-26-2015, 06:46 PM   #12
Cow
Rewards Points: 34
I'd buy a new 240' fishtape to try before I did anything else. If yours is only 150' now, it sounds like you needed another fishtape about 90' ago.
The Following 3 Users Say Thank You to Cow For This Useful Post:
crazyboy (03-02-2015), electricguy (02-26-2015), five.five-six (02-26-2015)
Old 02-26-2015, 07:08 PM   #13
Yeah it is an Ideal one that I bought maybe 25 years ago, replaced the handle and the tape over the years
Old 02-26-2015, 07:16 PM   #14
evil bastard
Rewards Points: 746
Why bother to try and get through the pipe, when there is already something going through the pipe?
Old 02-26-2015, 07:53 PM   #15
Rewards Points: 27
Being a motel they probably don't want you to take the phone and cable down for any length of time. I would go and get a new fish tape. Are both cables direct burial? You might want to get your hands on a 1/4" flat tape.
Old 02-26-2015, 08:06 PM   #16
Cow
Rewards Points: 34
Because it literally takes less than 10 minutes to try with a fishtape.
I'm willing to waste that much time if need be before I tug a coax out just to find out the compression connector on the end pulled off underground when it snagged on a poorly glued 90 giving me something else to deal with.
Old 02-26-2015, 08:21 PM   #17
evil bastard
Rewards Points: 746
I would never never ever ever pull a Metal fish tape through a conduit with existing wires in it. Are you crazy? You can rub through a catv in a few feet, let alone pulling 200' of tape around an elbow that already has wires in it. .....
Old 02-26-2015, 08:34 PM   #18
Rewards Points: 10,226
I don't know about never ever, but it's toward the bottom of the list of ways to get the job done. Damage one of those cables and you are replacing everything
Use the RG11 to pull in a rope, use the rope to pull the RG11, a pullstring and whatever you are adding back in. Use lots of soap.
The Following User Says Thank You to five.five-six For This Useful Post:
shocksystems (02-26-2015)
Old 02-26-2015, 10:01 PM   #19
Cow
Rewards Points: 34
Yes, I'm thinking clearly.
I've shoved fishtapes in LOTS of conduits with wires in them and I've yet to rub through a SINGLE wire. Maybe it's your technique, although I don't think it takes any to push a fishtape in...
I wouldn't shove a fishtape into a packed conduit, I usually just use the ground as a pullstring. But, a 2" LV conduit with a 25 pair and a coax? That's not exactly stuffed.
It sounds like you can stick to pulling one wire out and back in every time you need to add one. I'll continue to take my chances and fish when I can and pull one out when I can't. To each their own.
Old 02-26-2015, 10:20 PM   #20
Rewards Points: 27
Pushing and pulling a metal fish tape will be fine. Especially if both have a direct burial jacket. Even if they were just cmr, pull slow, with some yellow 77 and your not going to burn thru the jacket. Just make sure the eye on the end of your fish tape is taped up good too.
electricguy (02-27-2015)
PVC as underground conduit xcursion88 General Electrical Discussion 7 05-07-2014 06:32 AM
Conduit in Slab or Underground? onilozay General Electrical Discussion 10 06-21-2013 03:20 AM
Underground conduit pull JacksonburgFarmer General Electrical Discussion 22 10-23-2012 06:58 AM
Underground conduit Antmc22 Commercial Electrical Forum 25 10-23-2011 11:50 PM
NM-B in conduit underground bluemoonshine General Electrical Discussion 6 02-23-2011 05:50 AM
