undervoltage - Electrician Talk - Professional Electrical Contractors Forum
Old 02-18-2015, 06:01 PM   #1
HTTR
Jack Legg's Avatar
Rewards Points: 804
Default undervoltage
would overloading a Generac 8kw cause an undervoltage 1902 alarm and shutdown
or would the main ckt breaker on the genny just trip?
Jack Legg is offline   Reply With Quote
Old 02-18-2015, 06:06 PM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
I've seen overloading cause that. And also low gas pressure. Do you have a manometer?
Jack Legg (02-18-2015)
Old 02-18-2015, 06:31 PM   #3
HTTR
Jack Legg's Avatar
Rewards Points: 804
no I don't have a manometer, we don't service generacs either
we did a 8kw with the essential ckt switch and the service guy said we shouldn't have put the water heater on the gen (he said it uses too much on startup)
with the 10 ckt switch we just transferred like ckts from the main panel
I think it was 1- 2pole 30, 1- 2pole 20, 3 each 1pole 15's and 20's
Old 02-18-2015, 08:10 PM   #4
Can't Remember
Rewards Points: 544
I watched a 10kw that was out of balance, 33 amps on one leg, slow down and die. Fixed the imbalance and all was well. I wouldn't have put the water heater on there either. 11kw isn't much more money. Put a load shed module on the water heater and life is good.
Old 02-18-2015, 08:29 PM   #5
HTTR
Jack Legg's Avatar
Rewards Points: 804
you can shed load using the 10 ckt essential load transfer switch?
Old 02-18-2015, 08:38 PM   #6
Can't Remember
Rewards Points: 544
Knowing that I had an electric water heater to run, but needed to keep things relatively cheap, I would have chosen the non service entrance rated switch, small subpanel and had load shedding. Water heater is a great candidate for it. Soon independent load shed modules that you can use without the need for the board in the switch will be available. Next month supposedly.
Old 02-19-2015, 03:56 AM   #7
Rewards Points: 1,510
Yeah !
Ya gotta watch out for those start up surges
On water heaters !
There killers.
Undervoltage 3xdad Residential Electrical Forum 9 06-01-2014 10:12 PM
Undervoltage release in GE rms circuit breaker blinkers General Electrical Discussion 15 12-18-2012 05:59 AM
120V single phase undervoltage relay erics37 PLCs, VFDs, Motors and Controls 4 10-13-2012 02:09 AM
