VFD Vs. Rotary Conversion - Electrician Talk - Professional Electrical Contractors Forum
Old 02-04-2015, 11:57 PM   #1
mr.photon's Avatar
Rewards Points: 78
Question VFD Vs. Rotary Conversion
So i am kind of torn between getting a vfd or rotary converter for 3 phase in my home shop. I need something in the 20-30 hp range. All Advice welcome.
mr.photon is offline   Reply With Quote
Old 02-05-2015, 12:29 AM   #2
Rewards Points: 3,108
It sounds like you're wanting to operate more than one motor, maybe several at once.
If so, a VFD would be a very poor choice. They do not do well with motors coming on and off while it's running.
If a motor is switched on or off while the VFD is producing power, it's very likely to burn up.
If a VFD operates one motor, the starting and breakdown torque will be less than if it were on POCO power, but it'll produce its rated HP once it's running.
A rotary phase converter doesn't care though. It's perfectly happy to run just about any 3 load within its rating. Figure about 80% of rated HP for any motor. And less starting torque.
The Following 5 Users Say Thank You to micromind For This Useful Post:
dronai (02-05-2015), glen1971 (02-05-2015), hardworkingstiff (02-05-2015), mr.photon (02-05-2015), stuiec (09-02-2015)
Old 02-05-2015, 01:14 AM   #3
Rewards Points: 3,090
There are other options, depending on your price range, and what you intend to run in your shop.
Digital phase converters, for example. They can run multiple motors if need be, in the range of hp you are giving.
Never used them, just found them doing a search a few days ago, when someone else asked about running a three phase compressor on single phase.
Borgi
Old 02-05-2015, 09:35 AM   #4
Rewards Points: 2,070
or put a small vfd on each 3 ph motors
The Following User Says Thank You to oliquir For This Useful Post:
AK_sparky (02-05-2015)
Old 02-05-2015, 09:58 AM   #5
wendon's Avatar
Rewards Points: 54
Is your service sized to handle it? Most of the shops I've seen use a rotary phase converter. The biggest issue I've run into is you have to make sure none of the controls are connected to the manufactured leg. Some of the cheaper ones, or the homemade ones, seem to have a higher starting current than the high end ones. How many motors are you going to be running at the same time and what size?
Old 02-05-2015, 12:52 PM   #6
mr.photon's Avatar
Rewards Points: 78
I would like to be running about 6 small motors, around 1-2 HP, on and off regularly, and two 10-15 Hp motors for the compressor and what not. My shop has 200 amp service.
Old 02-05-2015, 12:55 PM   #7
mr.photon's Avatar
Rewards Points: 78
also should i build one or get a stock commercial?
Old 02-05-2015, 01:15 PM   #8
Morning mr.photon:
Your profile states your an Electrical Engineer.
Where is your shop, and what price range are you looking at to set up three phase?
Borgi
Old 02-05-2015, 01:24 PM   #9
mr.photon's Avatar
Rewards Points: 78
I am an electrical engineer, just not in the complete sense. I never finished college for financial reasons so i could not be certified, but i do know alot.
Anyway, I can spend about 2g. It would be located in my home shop(a pole barn on my property). i have 200 amp service.
"Science isn't about why, Its about why not!" -Cave Johnson
The Following User Says Thank You to mr.photon For This Useful Post:
51360 (02-05-2015)
Old 02-05-2015, 01:31 PM   #10
mr.photon's Avatar
Rewards Points: 78
What do you guys think of this one? is it a good price?
http://www.ebay.com/itm/75HP-3-PHASE...-/261752941603
Old 02-05-2015, 02:16 PM   #11
Rewards Points: 2,985
It might worth pricing out individual VFDs, but it sounds like you have quite a few motors. As others have said, VFDs don't like motors coming on and off on the load side of them. They are designed to start and stop the motor themself.
AK_sparky is offline   Reply With Quote
The Following User Says Thank You to AK_sparky For This Useful Post:
Old 02-05-2015, 08:38 PM   #12
wendon's Avatar
Rewards Points: 54
Probably oversized for your application. The converter must be sized to the largest motors you're going operate and other factors. An oversized converter can cause problems. A number of manufacturer's web sites have sizing charts etc.
Be sure to study the appropriate code section to find out what the requirements are.
http://www.phaseconverter.com/rotary-converter.sizing/
The Following User Says Thank You to wendon For This Useful Post:
Old 02-05-2015, 08:52 PM   #13
Lep
THE "BIG RED MACHINE"
Lep's Avatar
Rewards Points: 2,927
What type of operation do you have going in your shop?
"See the ball; Hit the ball."
Pete Rose:Joe Morgan
Lep is offline   Reply With Quote
Old 02-05-2015, 09:10 PM   #14
mr.photon's Avatar
Rewards Points: 78
Well i have a couple drill presses, a large compressor about 15 hp, a garage opener, a lathe. I do repair work on some motors, just some small projects. I do odd jobs for people.
Old 02-05-2015, 10:06 PM   #15
I'm pretty sure the current on this one would be more than 200 amps. A 200 amp service might not even be able to start it.
This one is also a basic ∆ connected motor with the shaft cut off and some capacitors added to get it started. It'll work, but the phase balance won't be as good as a unit designed from the ground up to be a converter.
There's a good chance that you'll need to reduce the sheave size on the motor of the compressor. This will result in less air but the motor might not be able to start the compressor with the factory sheave. And even if it does, it'll very likely trip its overloads within a few minutes because of the voltage imbalance inherent to all rotary phase converters.
As noted, pick one that's closer to your actual loads. It's usually ok to oversize a little, but not a lot.
Old 02-05-2015, 10:08 PM   #16
Lep
Lep's Avatar
Well maybe if you know how to rewind motors start a little motor rebuild ,motor rewind shop.Small fab shop manufacturing gig. Good luck to you.
Old 02-05-2015, 10:09 PM   #17
mr.photon's Avatar
Rewards Points: 78
Ok thanks that explains it well. So should i look for something more like 30 HP? Lower?
Old 02-05-2015, 10:10 PM   #18
mr.photon's Avatar
Rewards Points: 78
Thanks. That is actually what i want to do. I have rewound a couple of motors so i think i can make it work.
Old 02-05-2015, 10:21 PM   #19
Think it would be cheaper to put vfd at each machine or change motors for single phase
51360 (02-05-2015)
Old 02-05-2015, 10:34 PM   #20
mr.photon's Avatar
Rewards Points: 78
So, using your logic, instead of paying around 1500 for a rotary converter, i should pay 500 each for like 6 vfds?
I would if i only had one big motor, but why should i get a vfd for each drill press(for example)?
Rotary Phone Ty Wrapp Structured Wiring 14 05-03-2014 12:51 AM
Article 90: What exactly do "hard conversion" and "soft conversion" mean? owl NEC Code Forum 3 10-07-2013 09:00 AM
Disconnect for VFD - Does it have to be within sight of VFD?? slandau NEC Code Forum 5 08-24-2011 01:31 PM
Rotary tool who uses them? JPRO2 Tools, Equipment and New Products 8 07-28-2011 10:19 AM
Rotary hammers Comingler Tools, Equipment and New Products 11 06-14-2010 12:28 AM
