viewing prints on a flat screen tv - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2012, 11:18 AM   #1
Eccles Electric
Default viewing prints on a flat screen tv
I am trying to view prints on my tv but not having much luck. I have a 60 inch and thought I should be able to view a full sized sheet at a time. but the notes are still not readable without enlarging
anyone else have any luck viewing prints digitally?
James Eccles is offline   Reply With Quote
Old 02-17-2012, 12:44 PM   #2
Slave to the grind
CopperSlave's Avatar
Rewards Points: 630
You might try clicking on your start tab and going into you computer's control panel, find the appearance folder and, adjust your screen resolution. Lowering the resolution will make things on the screen larger.
CopperSlave is offline   Reply With Quote
Old 02-17-2012, 01:33 PM   #3
Rewards Points: 1,022
Make sure the PC is set to input the TV screen. Go to "personalization" and with the TV connected, click the "Find Device" button. It should find the TV and output to fit the screen.
It is the same window where you adjust the computers resolution.
Old 02-17-2012, 04:21 PM   #4
Eccles Electric
yeah I tried messing with the resolution on the computer and the tv with no luck
Old 02-17-2012, 05:29 PM   #5
Bababoee
captkirk's Avatar
Rewards Points: 2,030
what kind of cord do you have going from the tv to the computer..? oh scratch that, didnt realize you were talking about resolution size.... Did you try to enlarge it first..?
Full time Bovine Scatologist.
Old 02-17-2012, 05:53 PM   #6
Rewards Points: 150
Does your computer have a magnifier in accessories
ptcrtn is offline   Reply With Quote
Old 02-17-2012, 09:04 PM   #7
Electricity is Amazing!
thoenew's Avatar
Rewards Points: 538
Func+F8
thoenew is offline   Reply With Quote
Old 02-17-2012, 09:28 PM   #8
Rewards Points: 2,122
is a 1080p tv. what kind of resolution you send to it you need to send 19201080 signal via dvi or hdmi (no vga or component since most tv doesn't support full hd with those analog signals)
Old 02-18-2012, 12:50 PM   #9
Eccles Electric
I am using an hdmi cable ? but when I was adjusting the resolution the best I could get was like 1420 x 1080 and that was the best I could get it was not an option to go up to 1920? its a brand new tv ??
Old 02-18-2012, 01:15 PM   #10
Not the resolution, the monitor choice/selection. Same window. You have the option to use a separate monitor. This will be your TV. On my Vista OS, it shows two monitors with the one not being used blacked out. You need to use the optional second monitor for your TV. I also have my TV connected with HDMI.
I use my wifes laptop with win7 OS. On hers you just open the "personalization" window and with the HDMI plugged into the TV I just hit the "Find Device" button. Once it finds the device, it should switch to that output as soon as you insert the HDMI cable next time you want to use the TV.
Old 02-18-2012, 04:56 PM   #11
thats the problem you are trying to display a 4:3 image into a 16:9 tv so it doesn't give clear text you could try 1366 x 768 also
can you adjust the resolution on the computer at 1920 x 1080? maybe the video card form computer isnt powerful enough
Old 02-18-2012, 05:08 PM   #12
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,540
If your using a laptop and you only extend your desktop to the TV, the pictures you open should not be stretched to fit. Once your screen size is set, any program window should look fine.
Just remember to drag your program back to your normal laptop window before disconnecting or it might become "lost" on the extended desktop.
Flat screen installation rate Sky Seattle Business, Marketing, and Sales 62 02-06-2012 11:08 PM
Hanging flat screen tv's jwjrw General Electrical Discussion 46 07-12-2010 04:25 PM
Flat Screen TVs NolaTigaBait Off Topic (Non Trade) 48 03-23-2010 05:12 PM
flat screen paul d. Off Topic (Non Trade) 43 02-06-2010 08:32 PM
receptical for flat screen johnny911 NEC Code Forum 11 12-16-2007 07:02 PM
