Voltage induced into locator wire in gas line. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By emtnut
  • 1 Post By emtnut
  • 1 Post By 99cents
Old 09-21-2016, 02:41 AM   #1
Rewards Points: 14,229
Default Voltage induced into locator wire in gas line.
If you have an underground conductor run parallel to a gas line, is it possible to induce voltage into the locator wire in the gas line?
Obviously there's more to this story but I want to hear what you guys think.
Old 09-21-2016, 07:00 AM   #2
Rewards Points: 1,260
I'd think so, why not? It's a long parallel run.
Old 09-21-2016, 07:36 AM   #3
Band Member
emtnut's Avatar
Rewards Points: 2,012
Unless there is a power feed run parallel to it, I'd say no !
I googled it thou .... apparently overhead Tx lines can induce into the gas line, and therefore into the tracer
Majewski likes this.
Old 09-21-2016, 08:46 AM   #4
Is there anything in code about separation of gas and power in underground installations? I know Alberta recommends 300mm separation or a pressure treated 2 X 6 in between.
Old 09-21-2016, 09:38 AM   #5
Band Member
emtnut's Avatar
12" separation ... I think it's referred to in 12-0129(13) ... which states req's are in CSA C22.3 No7 (Underground Systems)
Edit** Thats rule 12-012 (13)
99cents likes this.
Old 09-21-2016, 10:03 AM   #6
Band Member
emtnut's Avatar
I still hate the whole 'mm' thing .... Very non-canuck of me i guess
It's a foot !
Old 09-21-2016, 10:08 AM   #7
It's a foot !
Yep. Box fill in ml? Liters are for milk!
Old 09-21-2016, 10:14 AM   #8
Band Member
emtnut's Avatar
Default Got Milk ?
Found a ref for book 3 (underground)
  • 6.15.18 states that: Where an underground gas pipe crosses another underground pipe or conduit, a minimum clearance of 2 inches (50 mm) shall be provided either above or below the gas line in accordance with the requirements of section 5.15.
  • Part 1 of the Canadian Electrical Code Rule 12-012 (13) states: For installations not covered by the foregoing requirements of this Rule, the requirements of CAN/CSA-C22.3 No. 7, or the applicable standard, whichever is more stringent, shall apply.
  • Part 3 of the Canadian Electrical Code Rule 6.1.11 states: Where communication and/or supply cables and gas distribution pipelines share the same trench, a 300 mm horizontal separation shall be achieved between the pipeline and the cables.
When sharing a common trench, gas distribution lines must maintain a minimum 300mm (12) separation from electrical communication or supply cables installed within the same trench.
Old 09-21-2016, 10:17 AM   #9
Thanks, 'nut .
Wiring Low Voltage Dimmer to LED A Little Short Lighting Design 14 08-01-2016 10:23 AM
Chasing that voltage ~48~ Residential Electrical Forum 15 07-28-2016 01:26 AM
Phantom Voltage? touchtester Residential Electrical Forum 9 04-25-2016 10:20 PM
Line Voltage Thermostat with Terminals splatz Residential Electrical Forum 7 04-10-2016 06:11 PM
Residential main feed voltage fluctuation stackvortex General Electrical Discussion 27 03-14-2016 09:53 PM
