Voltage leakage - Electrician Talk - Professional Electrical Contractors Forum
Old 02-10-2015, 07:58 AM   #1
Rewards Points: 44
Default Voltage leakage
Dear Senior.....
Today i found a little bright light from indicator lamp , which the indicator lamp are not running , when i used multimeter to test the voltage is about 20V flow on the lamp , is that call voltage leaking ? how to i ensure for this troubleshoot ? and repair ??
1) change the cable ?
2) change the relay ?
Thanks for advise ..
Powertrans is offline   Reply With Quote
Old 02-10-2015, 08:00 AM   #2
Rewards Points: 2,950
Hire an electrician.
Old 02-10-2015, 10:23 AM   #3
I own stock in FotoMat!
Rewards Points: 6,520
English may not be the OP's native language.
Old 02-10-2015, 10:33 AM   #4
wendon's Avatar
Rewards Points: 54
Originally Posted by Powertrans View Post
Dear Senior.....
Loose neutral?
Old 02-10-2015, 10:45 AM   #5
Bad Electrician's Avatar
Rewards Points: 4,969
Check for phantom/ghost voltage first.
Check the power source, what feeds this equipment?
You could be feeding through a load.
need to check the wiring.
Old 02-10-2015, 11:12 AM   #6
gnuuser's Avatar
Rewards Points: 1,528
also use an analog meter or inductive tester.
more information would be helpful in determining what is happening.
induced voltages can cause some problems but more than a few headaches.
check wiring to see if you have loose neutrals. close proximity to large motors,
if using shielded power cables make sure the shield/drain wire is bonded at one end only(preferably at supply end) and not at both ends
Drywall over GEC? And leakage? mwr General Electrical Discussion 21 04-29-2014 08:26 PM
earth leakage on transformer systems aussielecky General Electrical Discussion 16 06-17-2012 07:38 AM
Leakage protection for more than 2 D/Bs tomatina General Electrical Discussion 1 12-09-2011 09:34 AM
transformer leakage? EvilBunny General Electrical Discussion 12 03-02-2011 09:48 AM
SE Cable leakage (pics) Magnettica General Electrical Discussion 72 09-22-2009 11:22 PM
