Wacky GFI - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 2 Post By Chris1971
  • 1 Post By MechanicalDVR
Old 06-21-2017, 10:56 PM   #1
Rewards Points: 52
Default Wacky GFI
I ran into something odd the other day. I was working on a circuit that had an old Hubble GFI in it and was getting some weird voltage readings. It turns out that the load terminals on the GFI had no ground reference whatsoever. On the face of the receptacle I had good 120 to ground, but nothing from the screw terminals. I'm​ curious if anyone has ever seen that before.
Old 06-21-2017, 11:04 PM   #2
Rewards Points: 26,610
Please unscramble.
Thanks.
Old 06-21-2017, 11:05 PM   #3
Rewards Points: 804
Sounds like the GFCI went bad.
Old 06-21-2017, 11:07 PM   #4
Rewards Points: 52
It got replaced. I just found it an odd way to fail and was curious if anyone else had ever seen it.
Old 06-22-2017, 02:13 AM   #5
Rewards Points: 3,062
I've seen a couple that had an internal melt down.
five.five-six likes this.
Old 06-22-2017, 09:36 AM   #6
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
That's really weird. As far as I knew the loadside and the receptacle where the same conductors. They are both connected to the lineside via a relay that opens when the GFCI trips.
I don't see how the receptacle holes would actually read different than the loadside. I believe there should always be continuity between them.
Always wear your gloves.
Old 06-22-2017, 10:06 PM   #7
neutral member
readydave8's Avatar
Rewards Points: 142
digital tester issues
Dave Ruth
Old 06-23-2017, 07:38 AM   #8
Rewards Points: 52
I don't think it was tester issues. What actually alerted me to it was that I was changing out a switch to a motion sensor and the sensor was acting goofy. When I replaced the GFI it worked just fine. I think I threw it away or I would crack it open to see what it looks like inside.
Wacky GFCI problem soe General Electrical Discussion 27 03-26-2016 08:47 PM
