Wattage limiters. - Electrician Talk - Professional Electrical Contractors Forum
Old 02-15-2015, 02:22 PM   #1
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
Default Wattage limiters.
How many of you have pulled these pieces of junk out of ceiling fans?
This one was a dimmer module also. I have had to pull a few of these out before. I had to pull one out of another fan in my house that was the non dimming fuse looking one. I am so glad the government mandated we have these things that blow everything a bulb burns out.
Old 02-15-2015, 02:33 PM   #2
Light Emitting Decoration
Electric_Light's Avatar
Rewards Points: 1,820
That's not a wattage limiter. 300W is the maximum you're allowed to load it. Not that it limits whatever you put onto it at 300W.
Electric_Light is offline   Reply With Quote
Old 02-15-2015, 02:43 PM   #3
MTW
Rewards Points: 10,228
I removed them from the last fans I put up.
Old 02-15-2015, 02:50 PM   #4
Jhellwig's Avatar
They used to be built into them. I was confused by the 300 watts because the limit is 190 watts.
http://www.hansenwholesale.com/ceili...fan-lights.asp
Old 02-15-2015, 02:57 PM   #5
Rewards Points: 1,810
I only have removed them when they go bad. With led and cfl I am surpised themwatt limiters are even be used
Chris1971 (02-15-2015)
Old 02-15-2015, 03:22 PM   #6
Jhellwig's Avatar
I had debated leaving them in. This one had started buning out bulbs left and right then quit.
Old 02-15-2015, 03:54 PM   #7
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
How can a wattage limiter burn out bulbs?
Old 02-15-2015, 04:31 PM   #8
ponyboy's Avatar
Rewards Points: 709
What's inside a paddle fan that would make the bulbs turn off and on again repeatedly in a blinking fashion
Old 02-15-2015, 07:13 PM   #9
Jhellwig's Avatar
I have no idea but every one of the dimmer kind that burns up starts burnning out bulbs left and right before it pops a bulb bad enough to short out. I can't explain it but it isn't the first time it has happened. I had to take one out of a fan because they said the bulbs wouldn't last a week.
Old 02-15-2015, 09:14 PM   #10
evil bastard
Rewards Points: 746
A remote thats not rated for cfls?
Old 02-15-2015, 09:23 PM   #11
ponyboy's Avatar
Rewards Points: 709
No remote. Incandescent in the sockets and its a semi new fan. I've never seen it happen before. It just blinks and blinks and blinks. It's not my fan or I would've torn it apart by now
Old 02-15-2015, 09:41 PM   #12
evil bastard
Rewards Points: 746
The part pictured in post one would be the only thing I can think of. Did they put too large of bulb in?
Old 02-15-2015, 09:51 PM   #13
ponyboy's Avatar
Rewards Points: 709
It's possible. They looked liked 40s to me though which I thought would still be appropriate
Old 02-15-2015, 09:56 PM   #14
Rewards Points: 310
Limiting switch. Put some lower wattage bulbs in it and it should go away
bkmichael65 is offline   Reply With Quote
Old 02-15-2015, 10:15 PM   #15
Rewards Points: 804
Are you at the strip club again?
Old 02-15-2015, 10:51 PM   #16
ponyboy's Avatar
Rewards Points: 709
If it is a limiting switch it must have failed bc I was told these bulbs have been in it for some time
Old 02-15-2015, 10:51 PM   #17
Rewards Points: 1,702
Make sure that bulbs put in fans are ratted for Fan Duty ...
Pete
pete87 is offline   Reply With Quote
Old 02-16-2015, 08:18 AM   #18
Rewards Points: 1,464
I wouldn't remove something that's part of the products' testing certification.
Old 02-16-2015, 08:37 AM   #19
ponyboy's Avatar
Rewards Points: 709
Congratulations
Old 02-16-2015, 09:00 AM   #20
Jhellwig's Avatar
It failed and you cannot get a new one. Hunter wants you to buy a new fan if the wattage limiter fails.
Using lower wattage lamp with higher wattage ballast wkd3703 New Member Introductions 12 11-18-2013 09:21 PM
baseboard wattage ponyboy General Electrical Discussion 23 04-03-2013 01:15 PM
Track lighting / Current limiters Bob Badger General Electrical Discussion 12 12-15-2011 05:39 AM
Voltage Limiters in New Ceiling Fans? redcx9 General Electrical Discussion 5 09-17-2009 05:08 PM
Figuring Wattage Auggie56 Services and Service Equipment 7 10-04-2008 08:25 AM
