Welded Wire Mesh Grounding - Electrician Talk - Professional Electrical Contractors Forum
Old 10-25-2013, 07:28 AM   #1
Rewards Points: 342
Default Welded Wire Mesh Grounding
Working on a job that has welded wire mesh instead of rebar in every concrete pad for switchgear and transformers, etc. The wire only has a diameter of .192" inches. It has to be bonded to the ground ring (4/0) and I'm trying to figure out what type of lug or crimp to use.
Having trouble finding something that matches that wire range. Any suggestion appreciated
NJWVUGrad is offline   Reply With Quote
Old 10-25-2013, 08:35 AM   #2
Going_Commando's Avatar
Rewards Points: 1,638
I don't have a code book in front of me, but I thought concrete encased electrodes had to be of a certain size (3/8 or 1/2" maybe?) and have 20 linear feet within the concrete. Don't think you have to bond wire mesh.
Old 10-25-2013, 08:50 AM   #3
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
I'm guessing this is a job spec. I agree with you it is not an NEC requirement.
Pete
Old 10-25-2013, 09:14 AM   #4
Rewards Points: 342
Yes Pete your correct, it is a Job Spec
Old 10-25-2013, 09:22 AM   #5
crispy critter
green light's Avatar
Rewards Points: 1,026
Have you looked into cad weld?
I'm old enough to know better, but too young to care.
green light is offline   Reply With Quote
The Following User Says Thank You to green light For This Useful Post:
nolabama (10-26-2013)
Old 10-25-2013, 09:25 AM   #6
Cow
Rewards Points: 5,262
I would use an Ilsco IK-250. They're grounding/bonding and db rated.
I've used hundreds of IK-6's to tie #8 Cu to wire mesh for equipotential bonding.
https://www.platt.com/CutSheets/Ilsc...atalogPage.pdf
Old 10-25-2013, 10:24 PM   #7
Senior Moment
drsparky's Avatar
Rewards Points: 410
Harger is the "king" of that type product. http://www.harger.com/
Old 10-26-2013, 08:41 AM   #8
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
I see these split-bolts are rated:
"For use with copper conductor types: Solid, Compact,
Compressed, Concentric"
....I don't see where it says for steel mesh/rebar.
Am I reading it wrong?
póg mo thóin
Old 10-26-2013, 09:58 AM   #9
rrolleston's Avatar
Rewards Points: 1,134
I would think if the OP could use a split bolt it would have to be one made out of brass with the spacer or the connection would fail.
Old 10-26-2013, 10:05 AM   #10
Cow
To be honest, I never looked into it any further. Our inspector here only required grounding/bonding and db rated. These seemed to fit the bill and he approved them.
If someone knows of something else that specifically states it's for wire mesh I'd be interested in knowing as well.
Old 10-26-2013, 10:46 AM   #11
Rewards Points: 250
Maybe something like a Weaver clamp? This is what the phone and cable companies used to bond their strands to the pole's ground.
http://www.ai-supplies.com/clamp-bon...lt-2125k1-box/
someonespecial is offline   Reply With Quote
The Following User Says Thank You to someonespecial For This Useful Post:
Celtic (10-26-2013)
Welded? BBQ General Electrical Discussion 50 10-11-2013 11:16 PM
Welded on purpose denny3992 General Electrical Discussion 18 10-05-2013 09:46 AM
Wire Mesh Cable Tray from Legrand LARMGUY Structured Wiring 1 08-02-2013 01:18 AM
CSST with wire mesh Hotlegs NEC Code Forum 2 12-30-2012 12:35 AM
My welded cable caddy, Finally!! Josue Tools, Equipment and New Products 36 03-09-2011 02:53 PM
