well control box caps - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2013, 07:54 AM   #1
mbednarik's Avatar
Rewards Points: 1,126
Default well control box caps
It is a pretty common thing around here for just a capacitor to go out of a well control box. Rather than replacing the whole box, I would like to have capacitors on hand. I mostly see 3/4 and 1 hp 230v well pumps. Does anyone have a chart of what size cap for what size pump?
Old 02-27-2013, 09:20 AM   #2
JohnR's Avatar
I looked, but there is a chart for aluminum case caps, and one for plastic case caps. Which are you using? It depends on what the motor is, efficiency, HP, etc. You don't always have that info when dealing with an UG well pump.
This is from a refridgeration guy,
This is not a FIX all but a rule, a basic method for motor capacitors.
(2650 x Full load amps ) divided by supply Voltage = MFD
Example 2650 x 8amps = 21200 divided by 240volts = 88.33 MFD
Plus or minus say 10% so call it 95 MFD it will not be correct but will get you out of a hole and the kit back working if that is the real fault and the capacitor has not failed due to other factors etc.
The Following User Says Thank You to JohnR For This Useful Post:
Semi-Ret Electrician (02-27-2013)
Old 02-27-2013, 05:23 PM   #3
Jlarson's Avatar
Rewards Points: 4,296
What brand motors/controls? Franklin Electric?
Old 02-27-2013, 07:07 PM   #4
mbednarik's Avatar
yes, franklin control boxes. These are start caps, they do not contain any runs on the stuff I have seen.
Old 02-27-2013, 07:32 PM   #5
Jlarson's Avatar
Look up their AIM manual with google. They have charts for all their control boxes plus a bunch of other good info.
I've had a print copy forever since I was doing wells all the time with a motor shop.
Fire mats/caps vinroc General Electrical Discussion 3 10-23-2012 05:15 PM
Federal Contractor Pay Caps Wirenuting Off Topic (Non Trade) 4 12-02-2011 08:01 PM
Ford Ranger Truck Caps pjmurph2002 Tools, Equipment and New Products 16 10-28-2010 08:35 PM
CAPS and lower case brian john Off Topic (Non Trade) 6 11-15-2009 02:30 PM
Receptacles and Attachment Plugs (Caps ) guschash NEC Code Forum 14 06-14-2009 01:36 PM
