What happens to breakers when they are tripped too often? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree42Likes
Old 01-09-2017, 11:10 AM   #21
Rewards Points: 14,127
Originally Posted by chadnodine View Post
Eventually the breaker will need to be replaced. I can't stand it when customers use there breaker box for everyday switching. Typically its restaurant owners switching their signs or exterior lighting off and on at the breaker which is not designed for multiple switching on a daily basis. Oh well, they always pay!
Although turning a breaker on and off a few times on a regular basis prevents them from getting stiff.
Old 01-09-2017, 08:29 PM   #22
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
It varies by frame size and often the larger the frame the more severe the test conditions are the breaker must endure, but in general a UL489 breaker needs to be able to:
- Close and open a 600% overload a couple dozen times.
- Operate under bolted fault 3 times.
- Withstand thousands of mechanical operations both under normal current and de-energized.
Always wear your gloves.
frenchelectrican (01-09-2017)
Old 01-09-2017, 09:06 PM   #23
Rewards Points: 3,010
ITE Blueline its easy they get really hot then trip, if tripped to many times
Thermal temperature readings on breakers Sparky Mcgregor General Electrical Discussion 5 10-22-2016 01:35 PM
GFCI Breakers Tripping Simultaneously robmix General Electrical Discussion 15 08-18-2016 06:37 PM
What do you do with tripped GFCI's and tripped breakers? carryyourbooks Business, Marketing, and Sales 44 05-28-2016 03:51 PM
Non-U.L.-Certified Breakers in obsolete Panels? Karl in NY General Electrical Discussion 43 05-18-2016 11:41 PM
Handle Ties on breakers JasonCo NEC Code Forum 6 02-15-2016 04:31 PM
