What specs to beef up, or upgrade, the Bridge Rectifier on my electric lawn mower?? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree25Likes
Old 07-16-2017, 10:15 AM   #21
Rewards Points: 3,062
Originally Posted by Suncoast Power View Post
Well then just buy a couple of goats.
Tried that route.
They are far too slow and picky.
Old 07-16-2017, 10:31 AM   #22
Southeast Power's Avatar
Rewards Points: 8,728
Tried that route.
I guess you spent too long on a float as a young Marine to be allowed to have sheep.
Old 07-16-2017, 10:40 AM   #23
Lol!
Had a friend drop off a trailer of his goats to graze in my back yard after SS Sandy had washed in and grown all kinds of odd greens back there.
They ate what they liked and left the rest, it looked like a ******ed haircut.
Old 07-16-2017, 10:41 AM   #24
Rewards Points: 1,360
Tried that route.
And you have to watch out for the local Chicken Steve. Damn goats can eat grass if their lower digestive tract is swollen shut...
Old 07-16-2017, 10:44 AM   #25
I'll keep that in mind but I'd say this area is pretty safe for livestock with relative certainty.
Old 07-16-2017, 12:47 PM   #26
Rewards Points: 3,130
Any bridge rectifier with specs exceeding the original will do. You could even use two in parallel, or individual diodes.
If it's just a basic bridge rectifier, simply replace it with one that has a higher current rating. Higher voltage won't help but it doesn't hurt either.
If there's a heatsink involved, use heatsink compound when bolting the diodes/rectifier to the heatsink or it'll overheat.
brian john and RePhase277 like this.
Old 07-16-2017, 01:53 PM   #27
Rewards Points: 12
Originally Posted by drsparky View Post
I didn't read were you tested the bridge, put a meter across it before you throw parts at it.
I tested it with a tick tracer by isolating a group of parts at a time, and seeing which group of parts tried the breaker. Long story, short.... switch works fine and doesn't trip the breaker until plugged directly into isolated rectifier. Looks like one of the pins were bent... thinking that's a symptom rather than the cause.
That's what I would've guessed, but I don't really like guessing when it comes to electrons. I guess I'll go with the 50 A, 1000 V certain then... Since it seems to be the cheapest available.
And yes, I will definitely make sure there's plenty of heatsink compound.
Thanks for the help!!
grndslm is offline   Reply With Quote
Old 07-16-2017, 03:03 PM   #28
Bird dog's Avatar
Rewards Points: 982
A bridge is 4 diodes tied together, an ohm meter will read conduction in one direction only, read across each lead. Will read open or shorted, swap the leads, will measure reverse of first reading.
IIRC You want them to be 2 times PIV (Peak Inverse Voltage).
Old 07-16-2017, 03:30 PM   #29
Band Member
emtnut's Avatar
Rewards Points: 2,018
If that motor doesn't have a thermal shutoff, I'd go OEM on the part.
Cheaper than replacing the motor.
Wait ... Nothing ... I don't wait 3 or 4 weeks to cut my grass , and even if I did, I have a Man's lawnmower
wildleg and RePhase277 like this.
Old 07-16-2017, 10:00 PM   #30
Rewards Points: 1,512
[QUOTE] Those look to be at least 30amp rated. [QUOTE]
No chance those diodes are 30A !
at best 8A.
if you want 30A you will need a bridge arrangement
micromind likes this.
Old 07-16-2017, 10:51 PM   #31
[quote=dmxtothemax;4132866]Attachment 109138
at best 8A.
Actually, those are regular 1 amp diodes. I just have tiny, tiny hands
Old 07-17-2017, 10:10 AM   #32
Rewards Points: 12
But the motor should be able to handle that grass no problem... Even if I haven't cut it in 8 to 12 months!! I think it really has been closer to a year since that backyard's been cut.
The mower with the shorted rectifier was a newer 13 amp Black & Decker. I ended up using a 30+ year old, 8 amp Black & Decker model (called the Flip something or another) to finish the job, even after it had rained!!! What likely burnt up the 13 amp rectifier was not using the side discharge attachment since it was elsewhere. Mulching was definitely not smart.
But anyway.. you can keep your man's mower. I don't ever have to go get gas or oil, never have to worry about cleaning carburetors, air filters, choking, unchoking, ripping off the pull string, or having to store it outside since it smells like gas. Too much trouble when the corded mowers virtually always JUST WORK.. and even if one component does fail, they are easier to diagnose and of the 2 or 3 parts that fail, they are also easier and cheaper to replace usually, than a carb rebuild kit for example.
Mowing with a cord is really not all that difficult. I just cut in a back and forth pattern that starts closest to the receptacle and moves away so that cord stays between the receptacle and the mower deck. It also helps to hold a loop of cord in each hand to help whip it from time to time, plus it allows you to know how much slack you have.
Batteries and gas can suck my mower's grASS!
Old 07-17-2017, 12:45 PM   #33
Importantly, a large cord is need for those mowers.
Old 07-17-2017, 02:48 PM   #34
cuba_pete's Avatar
Rewards Points: 3,007
Thanks, but us barefoot cousin humpers in 'Bamy don't believe in that there Ebay. That's for the devil. We roll our own bridge rectifiers in these hills:
I find it hard to believe that there are that many electric bushhogs out in the sticks...
It is almost as if destiny does not believe in reality, and resists fate and her injustices
Old 07-17-2017, 02:50 PM   #35
A large cord beats a short one hands down!
Old 07-17-2017, 03:42 PM   #36
I'm not the OP.
Old 07-17-2017, 03:44 PM   #37
Rewards Points: 1,986
And a lawn service beats them all hands down been 10 years since I mowed grass.
The Following 2 Users Say Thank You to brian john For This Useful Post:
Bird dog (07-24-2017), Southeast Power (07-18-2017)
Old 07-18-2017, 12:09 AM   #38
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 256
Tried that route.
Don't feed them but do stake them out on a chain, they'll eat a rope.
They also fertilize as they go.
Cowboy words of wisdom.
Old 07-24-2017, 04:35 PM   #39
Its not going to 'help' your mower mow any more if you uprate the BR it will however last longer. As long as voltage is the same and your curremt is as high or higher than you are fine.
Sent from my SM-N910P using Tapatalk
bigbigjon is offline   Reply With Quote
Electric Company Service Drop Upgrade MustangRider6688 Services and Service Equipment 12 07-11-2016 06:03 PM
