What is a swedge coupling - Electrician Talk - Professional Electrical Contractors Forum
Old 08-20-2013, 09:01 AM   #1
Never Used Scotchkote
JoeKP's Avatar
Rewards Points: 2,032
Default What is a swedge coupling
Stole the pic from sparky970
I have seen these a few times but thought they were just a different design for a regular coupling. Do they have some special purpose?
Don't believe me? too bad....
JoeKP is offline   Reply With Quote
Old 08-20-2013, 09:49 AM   #2
360max's Avatar
Rewards Points: 1,234
isn't it a reducer coupling?
edit: just saw that they have 2"in- 2"out, so they are also made to not reduce. Good question!
Old 08-20-2013, 10:02 AM   #3
JoeKP's Avatar
I've seen them only as same size to same size.
Old 08-20-2013, 12:15 PM   #4
Rewards Points: 874
Good question Joe. I do not know what they are for either.
Old 08-20-2013, 02:53 PM   #5
Rewards Points: 185
More for changing type of conduit like fiberglass which has a greater ID then the internal ridge makes a smooth transition.
EC2253 is offline   Reply With Quote
Old 08-20-2013, 02:54 PM   #6
360max's Avatar
that makes sense
Old 08-20-2013, 04:46 PM   #7
Rewards Points: 546
Is that what call a "Swedgie"?
Spunk#7 is offline   Reply With Quote
Old 08-20-2013, 06:49 PM   #8
220/221's Avatar
Rewards Points: 4,274
Maybe that ridge in the middle is designed to fill the apace between the conduits so the wire/fish won't get hung up?
Old 08-20-2013, 07:01 PM   #9
ANY MONKEY CAN RUN!
piperunner's Avatar
Rewards Points: 1,000
Well the center is because its a reducer coupling we use them when we tunnel bore across a street it connects 5 inch to 6 inch or 5 inch to a 4 inch its just for PVC conduit 40 80 it also is a style type of coupling with longer bells ends then standard better and comes in any size even same sizes .
We use slip ons for tuff ducts coming in two directions there great also when you in a jam or like to make life easyer .
ONE TIME ONE LINE
piperunner is offline   Reply With Quote
Old 08-20-2013, 07:16 PM   #10
Rewards Points: 262
Swedge couplings generally have a longer body on them. PGE out here in CA. Requires them on all PVC installs because you get more contact with the pipe and lessens the likelihood of the pipe pulling apart.
It's basically an oversized coupling. Instead of the 2" of bite a standard coupling gives a swedge coupling gives anywhere from 3-4" of bite on the pipe.
qckrun is offline   Reply With Quote
The Threadless Coupling Option Chris1971 Residential Electrical Forum 17 11-08-2012 09:38 AM
coupling capacitor? JS_Electric General Electrical Discussion 3 09-20-2012 12:32 PM
Threadless coupling/connector Gamit General Electrical Discussion 2 07-01-2011 04:40 PM
New type of rigid coupling Mulder Code Violation Discussion 22 04-06-2011 08:12 AM
Ever seen a $100 two inch coupling? Chris Kennedy Off Topic (Non Trade) 17 02-12-2011 12:27 PM
