What's the largest residential service you've ever put in? - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 08-05-2012, 01:34 AM   #41
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Originally Posted by yrman View Post
I want to know what these people do or did for a living. Always wonder that about super big homes.
Probably beat down electricians on price.
Replies based on NEC 2014
Old 08-05-2012, 03:00 AM   #42
Rewards Points: 1,000
yrman is offline   Reply With Quote
Old 08-05-2012, 08:13 AM   #43
Nosparxsse's Avatar
Rewards Points: 150
800 AMP
Total electric home, 5 furnaces/a/c's, heated indoor pool, hot tub, steam room, etc.. CT metered at transformer Underground service to house.
and on this one we had to build a special ladder carrying jig to service the lights in and above the rainmaker.
What's the largest residential service you've ever put in?-pool-room-rainmaker-.jpg
Nosparxsse is offline   Reply With Quote
The Following User Says Thank You to Nosparxsse For This Useful Post:
mcclary's electrical (08-05-2012)
Old 08-05-2012, 08:45 AM   #44
God-fearing Volt-head
janagyjr's Avatar
Rewards Points: 536
Originally Posted by Nosparxsse View Post
800 AMP
wow....
Owner, Trinity Electrical and Handyman Services
All original content licensed via the OWL (
) from date of post.
janagyjr is offline   Reply With Quote
Old 08-05-2012, 04:27 PM   #45
Originally Posted by MDShunk
Forgot I had these pics. They are in the basement on a new resi build in 2008:
Damn is that in central pa? Where they work doctor or higher up for Hershey, or there some big pays up there guys with deep pockets and long arms power ball money damn
coon88 is offline   Reply With Quote
Old 08-05-2012, 05:57 PM   #46
1600a single phase. 20,000 sq ft. 50 tons of geo all electric back up heat. ct cab in electrical room and meter outside
D-Bo is offline   Reply With Quote
Old 08-05-2012, 08:47 PM   #47
Davethewave's Avatar
Rewards Points: 158
My largest was 600 Amps.single phase 200 for pool house and equipment, 400 Amps. for 12,000 sq. ft. house. Homeworks and all the other BS. Doesn't really hold up to all the east coast monsters, but I was itching to get my 100th post.:-)
Davethewave is offline   Reply With Quote
Old 08-06-2012, 02:15 AM   #48
Rewards Points: 21,898
The largest one I know in Wisconsin for a single family resdentail home is 800 amp 208Y120 volt system.
The POCO put a cap on single phase service but they can go over 800 but it have to be approved by engineering department for order a correct transfomer. Normally they will try to use triphase much as possible if you are near by the local triphase grids.
Merci,
Marc
Old 08-06-2012, 02:42 AM   #49
BEAMEUP's Avatar
Rewards Points: 26
Mine was 1800 amp Single phase, 30,000 sq ft home with a 2 lane bowling alley in the basement and a FAA spec'd heli pad in the back yard. Wish I had taken some pictures it was quite impressive.
BEAMEUP is offline   Reply With Quote
The Following User Says Thank You to BEAMEUP For This Useful Post:
janagyjr (08-06-2012)
Old 08-06-2012, 08:25 PM   #50
The Omega Member
Corn_Fed's Avatar
400A while being self employed
Corn_Fed is offline   Reply With Quote
Old 08-06-2012, 09:27 PM   #51
The Omega Member
Corn_Fed's Avatar
what was the sq. footage of this monstrosity deamed a "house"
Old 08-09-2012, 12:22 AM   #52
Rewards Points: 158
What did they use for lighting control?
Old 08-10-2012, 10:27 PM   #53
Rewards Points: 256
Residential the biggest I have done has been a 600 amp single phase.
The biggest house in our area according to an inspector I know who has done quite stops there during construction stages. Had a 3 phase 480 volt 4000 amp service. The ats was so big you could walk around inside of it. Apparently the utility pole primary fuses had blown at one point in time, the homeowner did not know the two catapillar remote generators had been running for a month or so before finally running out of fuel! The utility company had to rework the grid just for this home! Forgot to mention there is a 54 car garage there!
123electric is offline   Reply With Quote
The Following User Says Thank You to 123electric For This Useful Post:
Vintage Sounds (08-12-2012)
Old 08-10-2012, 10:28 PM   #54
Rewards Points: 2,002
A 60 amp service with a Wadsworth fuse panel and Anchor meter socket.
The Following 2 Users Say Thank You to user4818 For This Useful Post:
mcclary's electrical (08-12-2012), socalelect (08-11-2012)
Old 08-10-2012, 11:48 PM   #55
Hope there was a 57 Chevy
Old 08-11-2012, 09:57 AM   #56
cog
stuiec's Avatar
Rewards Points: 1,400
Reminds me of this thread http://www.electriciantalk.com/f29/p...ghlight=yillis
Post #56 has some good pics of an 800A resi electrical room
Old 08-12-2012, 01:58 AM   #57
BEAMEUP's Avatar
Rewards Points: 26
I cant remember the brand ( it was 15 years ago) but this one is almost identical to the one we put in.
http://www.heliportlighting.com/airp....3/3.3.3H.html
Old 08-13-2012, 09:08 PM   #58
Rewards Points: 158
Very cool. I don't think I will be installing a heliport on my rooftop any time soon :-)
800 amp residential service goooch Services and Service Equipment 39 08-13-2015 01:07 AM
Residential service i b e w N PHILLY KID Union Topics 6 08-04-2012 03:20 PM
Largest service you have built..... JacksonburgFarmer General Electrical Discussion 34 12-25-2011 11:57 PM
residential service calculation sparky1423 Residential Electrical Forum 3 07-19-2011 09:14 PM
residential service changes liverstos General Electrical Discussion 8 07-07-2008 06:07 PM
