Whats my next step? (lamps keep burning up) - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2015, 08:56 PM   #1
mdnitedrftr's Avatar
Rewards Points: 1,131
Default Whats my next step? (lamps keep burning up)
I have a customer who just moved into their new construction home back in October. They have a problem with the recessed lights burning out all over the house within a short period of time. Out of the 140ish recessed lights, Ive had to replace probably 75 lamps already.
Ive checked all the usual suspects. All my connections at the mains, breakers, switches, lights, all checked out fine.
Im not using cheap lamps. Im using 38W Par20 GE. Ive installed thousands of them and never had an issue like this.
I did check their voltage, and to me it seemed a bit high. They were getting 123-124v on each leg. I told the HO to call out the PoCo and have them check things out. They recorded 122v, and thats within their range, so they didn't do anything else.
Where do I go from here?
- Rich
mdnitedrftr is offline   Reply With Quote
Old 02-17-2015, 09:03 PM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Install 130 volt bulbs
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
aftershockews (02-18-2015), MTW (02-18-2015)
Old 02-17-2015, 09:12 PM   #3
Rewards Points: 3,078
Which manufacturer, model # of can & trim.
In insulation or not?
Where the lamps exposed to vibration from construction like blown-in insulation installed in attic or carpet/tlle installed on floor above?
Greg
Old 02-17-2015, 09:16 PM   #4
What's the model # of the GE lamp?
Greg
Old 02-17-2015, 09:23 PM   #5
All cans are Lightolier 2002P1.
House is spray foamed, but none of the cans are near the insulation.
No excessive vibration. We installed the lamps well after the floor was down, and the HO assured me the kids werent jumping around. I believe it because the problem is house wide, not just were the bedrooms are.
GE 69163
- Rich
Old 02-17-2015, 09:26 PM   #6
CADPoint's Avatar
Rewards Points: 1,838
Recessed Lights Recall
Since you think it's the lamp what about the equipment?
If you are even thirsty, you are two quarts low.
Old 02-17-2015, 09:49 PM   #7
Your GE 69163 is rate 1,500 hours
GE 69148 & 69149 are rated 3,000 hours
All GE PAR20 are rated 120 volt.
Sylvania 16116 is rated 4,500 hours
Maybe try a different lamp.
It's possible you got a bad batch. It's happened to me.
Greg
Old 02-17-2015, 10:12 PM   #8
Rewards Points: 1,512
Use Led lamps instead !
Old 02-17-2015, 10:16 PM   #9
140 LED lamps @ $25 each = $3,500.00
That might be a hard sell.
Greg
Old 02-17-2015, 10:23 PM   #10
I dont think LOL is the problem. We've been using them for years and never come across a problem like this.
I know they are only good for 1500hrs*, and that was my original thought, that it was just end of life for them, but Ive had to replace quite a few, multiple times already, in much less time.
The HO actually wants to switch everything to LED (actually an easy sell ), but they are concerned that they will burn out just like the halogens.
- Rich
Old 02-17-2015, 10:34 PM   #11
Are your dimmers LED compatible?
Greg
Old 02-17-2015, 10:46 PM   #12
Yes. The whole house is being switched over to Control4 stuff, which we made sure is compatible with everything.
- Rich
Old 02-18-2015, 08:53 AM   #13
If they can afford that, then LED's are cheap.
GE LED PAR 20 don't have the standard PAR glass. I don't know if that would bother the owner. Maybe they'll like the new higher tech look.
I would get my distributer to send a sales rep with several LED options to show the owner. Discuss the appearance of the lamp, color in ēK, consistency of color from lamp to lamp, brightness, dimming, lamp life, etc. and let the owner choose the lamp. After they decide, change one or two areas and make sure that's what they want before changing 140 fixtures.
Greg
Burning out Lamps Chris1971 General Electrical Discussion 11 01-29-2013 11:15 PM
changed 2k f32t8 lamps to the energy saving 25 watt lamps mbednarik Lighting Design 20 04-24-2012 11:23 PM
Anyone noticing T5 lamps burning out faster than T8's Sky Seattle General Electrical Discussion 10 02-04-2012 01:51 PM
Weird problem: lamps burning out bill39 General Electrical Discussion 52 10-26-2010 03:11 AM
Whats the next step?.. Creb88 New Member Introductions 9 07-16-2010 06:01 PM
