What's your favourite work to do for customers ? - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree94Likes
Old 03-20-2019, 10:48 PM   #61
Rewards Points: 178
Lighting upgrades in commercial settings. I ****ing love them. The customer is always happy and you get instant gratification on your results.
(Old post I Know)
I'd like to get into commercial lighting upgrades, but dont really know how to go about doing it.
Thought about cold-calling, but thats likely to end with several doors slammed in my face!
We've got some OK incentives/rebates where I live, but not enough to cover more than 10% of the job price.
How have you gone about getting these types of jobs?
They look like money makers to me!~
Rfreddy is offline   Reply With Quote
Old 09-11-2019, 01:11 PM   #62
Rewards Points: 178
Default John R retired electrician from Fed
Originally Posted by micromind View Post
Me too.
There's a knack to it, some guys are good, most are pretty much lost with controls.
I've always believed that control electricians are born, not made. Either you have it or you don't. Unfortunately, if you're not a natural at it, you'll very likely never be good at it.
I did a lot of control, repairs in the Military years ago. I am no retired and do repair work for a mine company that builds diesel equipment that can go underground. They have a 50 HP boring mill with a table that can move in four directions. It has a tag, that states it was made in 1966. The control panel is about 5 ft high and 3 ft wide, full of starter and contractors and relays, I enjoy working on the old equipment, not the newer ones
micromind and tmessner like this.
John R is offline   Reply With Quote
Old 09-11-2019, 08:53 PM   #63
Rewards Points: 3,358
Most likely they're NEMA starters.......these don't burn up nearly as often as IEC.
Old 09-11-2019, 10:07 PM   #64
Dope-less Hope Fiend
Rewards Points: 762
I love residential service work, especially when it's an easy fix.
Seeing a homeowner grin when the light switch now works...nothing better!
Give me your tired, your poor, your huddled masses yearning to breathe free, the wretched refuse of your teeming shore. Send these, the homeless, tempest-tossed to me, I lift my lamp beside the golden door!
Dan the electricman is offline   Reply With Quote
Old 09-12-2019, 01:05 AM   #65
Switched's Avatar
Rewards Points: 10,332
Didn't re-read through this, so not sure if I posted on it 2 years ago....
I like Dan... Like residential and commercial service. I enjoy going from job to job, meeting people, solving issues, and.... making money!
Old 09-12-2019, 01:43 PM   #66
Rewards Points: 178
Default John R retired electrician from Fed Gov
Had to replace the two starters that control the 50 HP. They had two starters for reversing.Used SD because you can get parts and rebuild them.
Old 09-12-2019, 05:07 PM   #67
Rewards Points: 3,078
Any job where the customer does not ask for a price. They know I won't rip them off, it's based on trust.
Cow, readydave8 and Forge Boyz like this.
Greg
Old 09-12-2019, 05:59 PM   #68
Rewards Points: 178
a
Originally Posted by Cl906um View Post
My favorite is resetting breakers. Or gfi breakers or line gfci that the homeowner didn't know even existed. I hate well pumps. Leave that to a specialist. Especially when there is no way to tell if there is a bad pressure tank. I.e. Saturated. If it has a pressure valve nozzle fine.
I guess you are talking about a tank that has a bladder. Never did like them, worked on a few old style, 30 gal, with sub pumps.
Old 10-09-2019, 12:24 AM   #69
Rewards Points: 28
The side work I used to do on weekends for friends of friends. It was usually something super easy like swapping a breaker or gfi that went bad in kitchen or masterbath. Quick money, but you won't have life if you always do side stuff on the weekends
Jackie1 is offline   Reply With Quote
Old 10-09-2019, 09:21 AM   #70
Cow
Rewards Points: 5,124
My favorite job?
The kind where the customer tells you in advance what's coming down the pipe and is looking for input beforehand. (rare)
Least favorite:
The kind where the customer tells you 5 minutes before they need it done that they need some electrical installed. We point out we could of saved a ton of time and money if we could of done XYZ before ABC was installed. (all the time)
Old 10-09-2019, 09:28 AM   #71
canbug's Avatar
Rewards Points: 2,032
I just did a resi panel change, hadn't done one in years, I really enjoyed it.
Tim.
Old 10-09-2019, 09:53 AM   #72
zac
Rewards Points: 826
Tim.
Was it inspected? Out here in California they give you about 5 hour's to rip existing service out of stucco and set new service in. It's a little stressful when there's only one of you.
Old 10-09-2019, 09:55 AM   #73
canbug's Avatar
Yes sir, permit and inspected. Might sound funny but it was relaxing. Nice non stressful day.
Tim.
Old 10-09-2019, 09:58 AM   #74
zac
Rewards Points: 826
Tim.
Where's your typical service located? Ours here is embedded in stucco on exterior side of house. I don't mind doing them because they're good money. But if I don't prep the day is usually a long one.
Old 10-09-2019, 01:03 PM   #75
canbug's Avatar
We have a mix of old stucco houses like your talking about, some overhead and then some underground, but the job I did was just a panel upgrade. Nice and easy, nobody home, some good temp lighting and music to work to.
Tim.
zac likes this.
Old 10-10-2019, 05:45 PM   #76
220/221's Avatar
Rewards Points: 4,274
I have done hundreds and the stress was the worst part. I used to love it when they showed up at noon.....or not at all I hated to have to stop working long enough to kiss their ass in order to get a green tag.
zac likes this.
Old 10-10-2019, 05:55 PM   #77
Small Potatoes
flyboy's Avatar
Rewards Points: 4,265
I remember when it was like that. Now I have inspectors and inspection agencies kissing my ass, for my business.
220/221 likes this.
Old 10-10-2019, 08:06 PM   #78
zac
Rewards Points: 826
When I was younger I would do everything in one day. Ground rods, cold water, tear out panel etc. It took a lot outa of me because I did them alone. I still can't believe I got the meter released on a few of them.
Then I got smart and did the ground's earlier and cut the stucco all out before the big day.
Old 10-10-2019, 08:43 PM   #79
MTW
Rewards Points: 11,496
Old 10-10-2019, 09:10 PM   #80
Small Potatoes
flyboy's Avatar
Tags
business, customers, income, jobs, revenue
So you want to become an apprentice in Canada... Vintage Sounds Electrician Apprentice Forum 52 08-07-2017 03:59 PM
Work in SW Virginia andytheham Looking For Work 0 03-19-2016 04:43 PM
Looking for Entry Level Electrical work in Blacksburg Roanoke VA area. andytheham Looking For Work 1 03-09-2016 06:59 PM
