When do you use SER? - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 12-06-2016, 10:36 AM   #41
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,366
Roger can you please explain what you are saying?
The OP doesn't have to re-route the water pipe conductor to the meter socket in this case. It can be connected to the SER's EGC. The connection in this case would be in the sub-panel.
Most inspectors in our area would allow this connection to be done in the grounding bus bar. If they insisted on an irreversible connection, then that can be done also in the panel.
The Following User Says Thank You to Roger123 For This Useful Post:
HackWork (12-06-2016)
Old 12-06-2016, 10:56 AM   #42
Rewards Points: 1,651
Thanks, I have to look that one up when I get back to the office. It's completely news to me but can help in some situations.
Old 12-06-2016, 11:25 AM   #43
Yeah Toast!!
Roger123's Avatar
Your welcome!
Old 12-06-2016, 12:24 PM   #44
Rewards Points: 90
Lightbulb
Originally Posted by WronGun View Post
This is seriously a horrible situation .... 20' behind a wall , we had to move the panels 20' over from the original spot and pull SEU along with 25 Rolex branch feeds through a very tiny spot and they are taped up in few spots.... I would literally need to pull out everything and start over at least 24 hrs of work ...ahhhhhh
At least 24 hrs of work??? For real? That's more like 8 hrs of work at maximum...
... I will give you a wise advice for when something horrible needs to be started over and you don't have any option than just do it: LESS FORUM CHAT, LESS TALK, LESS FRUSTRATION ABOUT IT, AND MORE WORK, JUST DO IT!!!
Once you know is mandatory to start over and redo everything do not waste not even one minute thinking about it, just do it! It will be way less horrible that way.
If you want or not to follow my advice is your personal prerogative, but if you do, I guarantee you will remember my words.
Jos
JosiQElectrician is offline   Reply With Quote
Old 12-06-2016, 12:36 PM   #45
Old 12-06-2016, 12:42 PM   #46
Originally Posted by Roger123 View Post
Your welcome!
I just looked it up and see that you are definitely correct. I saw some discussion at Mike Holt's about it. I am not sure if I will be able to use it due to sizing like you mentioned earlier. Plus, it might be an issue dealing with inspectors. But it's still good to know!
Old 12-06-2016, 03:22 PM   #47
Going_Commando's Avatar
Rewards Points: 1,542
That's a good thing to know. Never caught that before. Thanks!
Old 12-06-2016, 08:39 PM   #48
Rewards Points: 3,062
Freudian slip ?
May just reflect the charge being incurred.
Old 12-06-2016, 08:42 PM   #49
Originally Posted by inetdog View Post
More likely just Ought To Correct.
That shirt can really pizza a guy off.
readydave8 and telsa like this.
Old 12-07-2016, 07:14 AM   #50
Yeah Toast!!
Roger123's Avatar
I learn about that section a while ago installing a service rated transfer switch and the water bond was on the opposite side of the house and the basement was finished with a permanent ceiling.
Old 12-12-2016, 08:16 PM   #51
WronGun's Avatar
Rewards Points: 686
Amazingly , we changed the wire in 2 hrs ... amazing how what seems like a nightmare turns easy and other things that are so simple turn into train wrecks
The Following 2 Users Say Thank You to WronGun For This Useful Post:
frenchelectrican (12-12-2016), samgregger (12-13-2016)
