Where can I find a socket for this? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree52Likes
Old 03-27-2019, 09:28 PM   #1
Default Where can I find a socket for this?
I've done mostly resi work in the past, but a friend of mine bought a gas station a while back and someone backed into a j-box and took out the canopy lights. I need a square recessed plug socket. Where do I find them? Supply house I deal with doesn't stock explosion proof RMC fittings. Any ideas?
Wiredmikey is offline   Reply With Quote
Old 03-27-2019, 09:33 PM   #2
gnuuser's Avatar
Rewards Points: 1,524
grainger.com for one but any larger supply house should have them.
you wont find them in hardware stores unless you have them order them for you.
Old 03-27-2019, 09:34 PM   #3
cog
stuiec's Avatar
Rewards Points: 954
set of 12 point sockets is good for square nuts
oops, didn't look close enough, not nuts at all.
Old 03-27-2019, 09:41 PM   #4
Rewards Points: 2,158
I have been doing industrial work for almost 40 years and I have never seen a socket that fits those plugs. Go to Fastenal and get a piece of square stock and use Crescent wrench on the stock.
If they are poured they may not come out. Then you have to crack them with 2 ball pein hammers.
If you are lucky you might find a 12 point socket that will fit on the stock.
LC
Old 03-27-2019, 11:18 PM   #5
Rewards Points: 17,452
Did you try a 3/8" ratchet?
Old 03-27-2019, 11:28 PM   #6
Ctsparky93's Avatar
Rewards Points: 12
Or 1/2 inch. The ones I have done in the past were 1/2 ratchet. But those look smaller
Ctsparky93 is online now   Reply With Quote
Old 03-27-2019, 11:54 PM   #7
Rewards Points: 3,528
On an EYS, it's a 1/4" drive on the small "pour" plugs, 1/2" ratchet on the XP plug in the vertical.. To me those look like 1/2" ratchet..
I'll ask a dumb question... What do you expect to do IF you can get the plug out? They are a poured fitting that has the equivalent to cement in them. You won't be adding or repulling conductors without cutting the seal apart.. Even with STL on the threads, when they are poured properly, they are typically a b!tch to get out afterwards.
Old 03-28-2019, 01:55 AM   #8
daveEM's Avatar
Rewards Points: 2,372
Yep.
I like perfect.
Old 03-28-2019, 05:23 AM   #9
Semper Fi
Southeast Power's Avatar
Rewards Points: 7,374
I think you have a decent chance of finding a cheated pour at a gas station. A couple of hits with a beater screwdriver might get you there.
I thing I remember opening them with a 1/2" rachet or maybe being disappointed it didn't fit.
Its much better to smash them and not let the chunks fall into the pipe.
Old 03-28-2019, 05:49 AM   #10
Rewards Points: 2,782
See the attachment. What a pain in the ass it was to get this, even their product engineers struggled to find it. It should be available on their web site within ten clicks. Another disaster of a consolidated web site.
It's a 3/8" drive for 1/2" fittings, 1/2" drive for 3/4" and 1", 3/4" drive for 1-1/4" and 1-1/2", then 7/8" for 2" and up from there. The part number for the plug is PLGx - PLG1, PLG2, etc.
The only 1/2" to 3/4" adapter I could find locally was a Harbor Freight impact rated. I use regular 3/8" and 1/2" breaker bars and extensions and that adapter to open up to 1-1/2" which is as big as I've had to go.
Beyond that my plan is to buy 18" of the square stock and put a big wrench on the square stock.
The unpleasant surprise is that once you get the thing open, the worst part begins. If you're taking the whole thing apart, smashing them up sounds better.
MechanicalDVR and circuitman1 like this.
The Following 2 Users Say Thank You to splatz For This Useful Post:
MechanicalDVR (03-28-2019), Southeast Power (03-29-2019)
Old 03-28-2019, 07:19 AM   #11
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,328
I'd always look inside first, 'round these parts it's prolly 50/50 that the chico was ever even poured.
splatz and Southeast Power like this.
Good work aint cheap and cheap work aint good.
Old 03-28-2019, 07:23 AM   #12
Good morning all. Thanks for all the replies. Honestly, I thought the fittings were just spun in and sealed with gas proof yellow pipe tape. It's 3/4 RMC. I'm just going to replace the entire assembly, fittings and all. If there isn't enough slack in the lines that were cut, I'll re-pull them.
MikeFL likes this.
Old 03-28-2019, 07:34 AM   #13
50/50 is betting odds for me. I'm in central Connecticut if that matters. This would be the third time a car has ran into something at the gas station in the past 3 months. Hartford drivers....
Old 03-28-2019, 07:58 AM   #14
What all is damaged? In the first pic it looked like just the JB. If that is just a metal WP JB and maybe a broken nipple, that would be all I'd be replacing. If you start replacing conductors and an underground conduit is damaged, that could become a huge can of worms.
Old 03-28-2019, 08:18 AM   #15
Several of the nipples are bent. The jb is trashed, and the power feed lines for the canopy lights have been completely severed. I megged the other lines and they're good. Oddly enough, this box is outside of a class 1 location.
circuitman1 likes this.
Old 03-28-2019, 08:49 AM   #16
Connecticut drivers....down here we call them something a little different by adding an 'N' in there.
They speed, pass on the shoulder, run lights/stop signs...so hitting a fixed object like a building seems par for their skill level.
Old 03-28-2019, 08:52 AM   #17
I've only come across one odd ball plug that wasn't a standard ratchet drive size and it looked like an 8 pointed star.
Old 03-29-2019, 06:55 AM   #18
Sentimental Mental
Think there bad down there? Try 3.5 million of 'em
Old 03-29-2019, 07:18 AM   #19
CoolWill's Avatar
Rewards Points: 634
Grab me one of those blunt wraps while you're there. I have some "cigars" to roll.
I'm With Her! Hillary 2016
Old 03-29-2019, 08:21 AM   #20
I can only imagine.
They are easy to spot down here, normally seen on the shoulder passing somebody or just pulled over getting a ticket.
I'm sure they tell all their friends "Virginia is just a speed trap"!
CTshockhazard likes this.
Wrench and socket organizing paulengr Tools, Equipment and New Products 15 10-14-2018 12:57 AM
Trying to find a socket glen1971 Tools, Equipment and New Products 26 09-18-2018 08:02 AM
Proximity of Hot Tub to Meter Socket Navyguy Canadian Electrical Forum 20 04-03-2018 10:07 AM
What socket set do you use? JoeKan Tools, Equipment and New Products 82 02-08-2018 10:57 AM
Where can I find electricians that really want to make the money? inphaze New Member Introductions 44 12-02-2016 01:33 PM
