Who knows their CH panels? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2014, 10:43 PM   #1
Rewards Points: 1,250
Default Who knows their CH panels?
And what is the likelihood of this one accepting twins?
Realtor sent me the pic, I can't get out there for a couple days.
Old 02-27-2014, 11:30 PM   #2
Is the panel listed to accept the tandem breakers? Who knows?
120/208 is offline   Reply With Quote
Old 02-27-2014, 11:38 PM   #3
yes, that was the question
Old 02-28-2014, 12:05 AM   #4
Rewards Points: 340
A miniature realtor with a miniature camera taking miniature photos.
FrunkSlammer is offline   Reply With Quote
Old 02-28-2014, 12:15 AM   #5
Rewards Points: 81
Call the realtor and ask them for a better picture that has the label clearly shown. It should have a list of all the breakers the panel is approved for. Which is not to say others may not physically fit, but they aren't listed/approved.
jigs-n-fixtures is offline   Reply With Quote
Old 02-28-2014, 12:19 AM   #6
J. Temple's Avatar
Rewards Points: 79
It looks pretty old. Most of the older panels are listed for tandem breakers. It's the newer ones that are CTL (circuit total limitation). I believe prior to 1965 all panel could have tandem breakers. How old is the building? Is the sub-panel original? Hope this info makes sense and is helpful.
J. Temple is offline   Reply With Quote
Old 02-28-2014, 02:48 AM   #7
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
It's a CHCH panel and those are the only breakers you'll be fitting in that panel. IMO that's the benefit of a CH or QO.
Replies based on NEC 2014
Old 02-28-2014, 05:51 AM   #8
Southeast Power's Avatar
Rewards Points: 9,240
Those tan handle CH types plug in like a QO breaker.
This is what you will need.
http://www.lowes.com/pd_151343-82364...ductId=3014062
I have this load center in my house.
Old 02-28-2014, 07:00 AM   #9
Can't Remember
Rewards Points: 1,528
Looks like a couple of empty spaces. Unless you are planning on adding some, you are all set even if not listed for twins. Go forth, make money.
Old 02-28-2014, 07:03 AM   #10
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 992
Looks like it already has a couple
The Following User Says Thank You to sparky970 For This Useful Post:
220/221 (02-28-2014)
Old 02-28-2014, 08:32 AM   #11
You may be right, my eyes aren't that good.
Old 02-28-2014, 08:33 AM   #12
Home inspector said no more room so I have to assume there are no bus stabs behind those two KOs
Old 02-28-2014, 08:34 AM   #13
Thanks, the building is 1960
Old 02-28-2014, 08:35 AM   #14
Thanks jrannis, just the kind of response I was looking for.
Old 02-28-2014, 09:20 AM   #15
MattHelm's Avatar
Rewards Points: 89
Is that a main lug only load center? If so, is one of the DP breakers being used as the disconnect?
MattHelm is offline   Reply With Quote
Old 02-28-2014, 10:56 AM   #16
Fond of three phase
Rewards Points: 928
The panel doesn't look that old. It also looks like there's a tandem used already. Best thing to do is pull the cover and look!
retiredsparktech is offline   Reply With Quote
Old 02-28-2014, 01:17 PM   #17
Rewards Points: 115
Two tandems being used top left and 2nd down on right
guy2073 is offline   Reply With Quote
Sky Panels stuiec Lighting Design 5 10-28-2012 07:11 PM
Sub - panels drumnut08 General Electrical Discussion 8 10-18-2012 09:49 PM
Replacing 50 year old westinghouse panels with newer panels SPINA ELECTRIC Services and Service Equipment 1 08-08-2010 01:20 PM
How many panels do you need now ? MDShunk General Electrical Discussion 33 12-18-2009 12:58 PM
FPE Panels nolabama Services and Service Equipment 5 10-01-2008 11:18 PM
