Whole panel circuit protector question - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By macmikeman
  • 1 Post By The_Modifier
  • 2 Post By Navyguy
  • 2 Post By wcord
Closed Thread
Old 03-03-2019, 03:26 PM   #1
Rewards Points: 16
Default Whole panel circuit protector question
So I've got this panel I'm doing new work on, and I have to put a whole panel protector on it. I've accepted that I'm going to have to put a hole in the wall, but, in the end I want it to look nice. So, what type/style of whole panel protector should I use such that its status is visible at/on the wall and it's somewhat easy to replace should the need arise.
I've looked at a few devices, but nothing I've seen so far is both visually appealing and does the required job. I'd prefer if the device either was flush mounted or didn't stick out too far as this panel is mounted in a small hallway. Oh, and I can't use an in-panel device unless it's a screw-in mount (not snap in). I've not yet found an in-panel device which is a screw-in type - otherwise I'd have it installed already. :P
Jarod997 is offline
Old 03-03-2019, 03:33 PM   #2
CoolWill's Avatar
Rewards Points: 3,976
What brand of panel? Several manufacturers now have SPDs that fit in a couple of breaker spaces. Some even have built-in breakers so that you don't lose those spaces.
CoolWill is online now
Old 03-03-2019, 03:42 PM   #3
Rewards Points: 16
Siemens EQ424225 -- which translates into:
  • Siemens EQ Loadcentre
  • 4 wire
  • 24/48 circuits
  • 225 amp
(I like it when manufacturers have meaningful product numbers ).
Sorry, would have posted a photo, but I'm still too new here.
Jarod997 is offline
Old 03-03-2019, 03:50 PM   #4
Rewards Points: 17,781
You can put them into a flush mounted junction box located below your panel if you are concerned about looks. Like an 8x8x4 indoor pull box. Go to the same family friendly hardware store Hacks goes to that has the slogan "Ace is the place" and get an offset nipple for the leads from the surge protector to the panel where you put the 2 pole breaker into. Shorter leads are better, but nobody is really going to know except you. If the lights are critical to see all the time, you can cut an acrylic plastic clear cover for it and throw away the cover that came with the box.
Jarod997 likes this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
macmikeman is online now
Jarod997 (03-03-2019)
Old 03-03-2019, 03:54 PM   #5
Rewards Points: 16
Ya, that thought occurred to me today. And no, I don't care if I have to open a door to check, just as long as it's easily accessible. It's going in an existing church panel which has all their sound equipment on it. They've been having some issues with various pieces of equipment lately and this is a relatively cheap/easy item to install. Getting the speakers off the ceiling, that was fun.
Jarod997 is offline
Old 03-03-2019, 04:21 PM   #6
Rewards Points: 16
Ya, but not that will fit in a bolt-in panel - at least not that I've found yet.
Jarod997 is offline
Old 03-03-2019, 05:31 PM   #7
CoolWill's Avatar
Guess I didn't read it all.
Old 03-03-2019, 07:35 PM   #8
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 264
@Jarod997 are you a licensed electrician? Just curious.
About Jarod997
Professional Biography
I do mainly repairs and small installations (single item, not whole residence)
What is your electrical related field/trade:
Engineer, manufacturing technologist
Bird dog likes this.
The_Modifier is offline
Old 03-03-2019, 10:39 PM   #9
Rewards Points: 4,962
  • 4 wire
  • 24/48 circuits
  • 225 amp
4 Wire panel? 3 phase? Need more then a double pole breaker.
Cheers
John
splatz and CoolWill like this.
Navyguy is offline
Old 03-04-2019, 07:53 AM   #10
wcord's Avatar
Rewards Points: 1,626
in a separate enclosure
splatz and Jarod997 like this.
wcord is online now
Old 03-05-2019, 04:59 PM   #11
Rewards Points: 16
@The_Modifier I am not a licensed electrician, no. The term "new work" that I've heard refers to retrofitting or performing work after the project has been completed - such as adding a new receptacle box in an existing wall. All my electrical work I've done so far has been inspected and passed though, and I know where to draw the line as far as what I'm comfortable doing.
@Navyguy - Yes, you're correct. But there isn't 3 phase going into that box, just your standard phase per side type thing. I'm not happy with that panel, but it's what I have to work with.
Jarod997 is offline
Old 03-05-2019, 06:49 PM   #12
Rewards Points: 7,493
That's a 3 phase panel. And you have single phase feeding it? ("phase per side type thing") Is there a neutral, and a ground bus in it? I can tell you right now, that won't pass inspection.
joebanana is offline
Old 03-05-2019, 08:18 PM   #13
Rewards Points: 1,666
I can't help it if I'm lucky
Dennis Alwon is offline
The_Modifier (03-05-2019)
Closed Thread
Splice in Panel NDC Canadian Electrical Forum 20 08-24-2018 10:17 AM
Working on panel - safety instructions for Gen Mgr conclavicus General Electrical Discussion 24 05-19-2018 11:43 PM
Need advice for mouting a pony panel NDC Canadian Electrical Forum 10 04-05-2018 03:52 PM
Converting a 3 wire 3 phase aux panel to 4 wire Elec Trix Commercial Electrical Forum 10 01-13-2018 07:33 AM
Sub Panel or main panel Agewon Residential Electrical Forum 12 09-06-2017 10:53 PM
