Why is there paper in romex? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree56Likes
Old 01-20-2019, 11:20 PM   #21
Rewards Points: 10,131
There is no paper in Romex in first world countries.
Old 01-25-2019, 10:29 PM   #22
Nutmegger777's Avatar
Rewards Points: 382
It must be to reduce the friction between the sheath and the conductors. That way, when you pull the cable and it snags, the sheath may get nicked or just keep gliding past whatever imperfection snagged it, all without transferring the friction to the conductors in the cable.
Nutmegger777 is offline   Reply With Quote
Old 01-26-2019, 06:26 AM   #23
Rewards Points: 1,520
As others have said, the paper is a filler, but the paper also prevents the jacket from bonding to the conductor insulation in the extruding process. Yes, the cable could be manufactured without the filler material, but would be more expensive to make and to install.
varmit is online now   Reply With Quote
Old 01-26-2019, 08:02 AM   #24
Rewards Points: 7,520
How much does a roll of paper romex cost? I want to compare it to our romex that does not have the paper.
Also, can you explain why it would be more expensive to install without the paper?
Old 01-26-2019, 08:25 AM   #25
Just going to the HD site, they pay about the same as us when you adjust for currency.
I bought a pair of those strippers once that are supposed to score NMD and it stunk (maybe it was my complete lack of manual dexterity). I think theyíre designed for American Romex.
Old 01-26-2019, 08:49 AM   #26
Rewards Points: 382
i accept your premise, but I reject the conclusion
By preventing the jacket from sticking to the conductors they achieve a greater flexibility of the whole assembly, plus lesser degree of snagging on rough edges.
Old 01-26-2019, 09:18 AM   #27
Trust me, paperless Romex is super easy to install.
Old 01-26-2019, 09:26 AM   #28
For sure. Also easier to strip. You can grab the bare ground and just pull it even. It easily cuts through the sheath
99cents likes this.
Old 01-26-2019, 09:31 AM   #29
CoolWill's Avatar
Rewards Points: 634
A 250 foot roll of 12-2 at Home Depot costs $72.97, American. A 75 meter roll of 12-2 at Home Depot Canada costs $93.04, American. So you pay $20 more per roll and get 4 feet less.
Old 01-26-2019, 09:50 AM   #30
Chief Flunky
Rewards Points: 308
Must be Canadian import charges in there. Just checked local big box (Lowes here...HD gave up on North Carolina East of 95) and it's $69.98 for a 250 foot roll. At HD in Knightdale (Raleigh), the closet HD to me at about 100 miles away (that's 160 km for Canookistanis), it's $70.47. Basically the same price.
Don't know about NM-B as I'm mostly industrial and the only NM-B I ever mess with is in my house but once in a while we get industrial cables that don't have the little layers of what looks like mylar that I was told are called separating tapes, or paper in them where the jacket adheres to the insulation, kind of like UF, and it's total crap. It's almost impossible to strip it apart without nicking the insulation. The price is usually almost the same with or without it.
CoolWill likes this.
Old 01-26-2019, 09:52 AM   #31
MTW
MTW's Avatar
Rewards Points: 6,872
"Meter"
Old 01-26-2019, 09:52 AM   #32
Rewards Points: 17,452
Not worth the extra $20 a roll for the 'paperless' experience to me.
Old 01-26-2019, 09:56 AM   #33
Rewards Points: 2,782
This pisses me off. Why 70m? Why not 76m which is 249' 4"? Why not 75m which is a nice round number and 246'? Canadians get shorted again.
Old 01-26-2019, 09:59 AM   #34
Band Member
emtnut's Avatar
Rewards Points: 420
"Meter"
"Metre"
electricguy and CoolWill like this.
Old 01-26-2019, 09:59 AM   #35
MTW
MTW's Avatar
He said it was a 75 meter roll.
Old 01-26-2019, 10:00 AM   #36
"Meter"
Yeah, you know, the far superior way things are measured in every country on the planet except for a couple of third word countries.........and the US
Old 01-26-2019, 10:01 AM   #37
The $20 is not because itís paperless, we pay more for many things here.
Look up a roll of single conductor cable and you will see we pay about $20 more for it too
Old 01-26-2019, 10:02 AM   #38
Thank you I feel better now.
Old 01-26-2019, 10:05 AM   #39
Band Member
emtnut's Avatar
Rewards Points: 420
Par for the course up here. Take just about any item, add the exchange rate, and it's still more up here.
Smaller market, higher delivery charges etc...
eddy current and CoolWill like this.
Old 01-26-2019, 10:07 AM   #40
If I was up there I'd be paying $20 more than what I get down here.
Using white romex for 240 volt circuits Canaduh Canadian Electrical Forum 26 12-01-2017 11:00 PM
Romex Connectors for Oil Resistant Cable sparkiez NEC Code Forum 6 09-27-2017 04:44 PM
Romex (NMD) in conduit XCasper Canadian Electrical Forum 18 04-30-2017 09:18 PM
Romex in Channel : Wood Cabinet onilozay General Electrical Discussion 11 12-28-2016 04:29 AM
The Incredible Shrinking Toilet Paper LARMGUY Off Topic (Non Trade) 14 03-29-2016 11:41 PM
