will the smart meter send signal to hydro if we pull it out? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree33Likes
Old 08-26-2016, 02:35 PM   #21
Rewards Points: 136
I worked with a lot of this type stuff, but not in this application. How often a meter reports is probably in the meter. The question is, what is the poco monitoring; IE: are they even looking for a "heatbeat" from each meter and in what time frame; once every 4, 6, 8, 12, etc hours?
Unless they're anal about meters being pulled, I doubt most of them monitor them closely. They may look for groups of missing meters and use polling to help locate the source of an outage.
GrayHair is offline   Reply With Quote
Old 08-26-2016, 07:16 PM   #22
Rewards Points: 2,864
I lean toward the thought that the POCO pays more attention in locations that theft is a significant problem.
Majewski likes this.
Old 08-26-2016, 07:20 PM   #23
Very Long Vacation
Rewards Points: 5,262
It depends more on the POCO. Some haul ass when the signal comes in, others ignore it or don't have the resources to catch it. Wish all POCOs were the latter, makes emergency repair a heck of a lot easier and your business reputation remains in all others.
readydave8 and Majewski like this.
Old 08-26-2016, 09:20 PM   #24
nbb
Rewards Points: 516
Do things right and pull a permit like you know you should.
You forgot that you are on ET, and need to blame every mishap on the United States executive branch. I know this is general electric talk, but that doesn't stop anyone else from bringing their controversial talk BS here.
nbb is offline   Reply With Quote
Old 08-26-2016, 09:21 PM   #25
Rewards Points: 1,500
I would tend to agree !
The technology is certainly there for them to detect such things,
but weather they want to, or do so, is another matter.
Old 08-27-2016, 05:52 PM   #26
Rewards Points: 274
As said many times, a lot is going to depend on how the PoCo is set up. Some of the smart meters are communicating periodically once in a great while, some periodically more often, some only when polled (the PoCo sends out a request to the meter, it answers only when asked). Some, like mine, have a wireless network set up wherein your neighborhood has a little repeater node on a pole somewhere nearby, talking constantly to around a dozen or so smart meters on a relatively constant basis to update a memory log, then the PoCo network polls that node periodically to collect the data from that log or send signals (such as "Disconnect" or "Disable HVAC"). If you pull one of those, the network node knows right away, but the PoCo likely doesn't until their system talks to the node. But on some of THOSE, the node sets a "flag" that the network is looking for a lot more often, which is how they detect a downed line.
So bottom line, you will not know without asking and if you ask, they will scold you immediately. Pulling the meter under load can damage it. So in many cases you can just call and ask for a disconnect and they give the command to the meter, it immediately opens the contacts inside of it and then they tell you it's OK to remove the meter. When you are done, you call them and they turn it on again.
Old 08-27-2016, 05:56 PM   #27
Rewards Points: 2,169
That's why you shut the main first.
Have you seen the PoCo call in to have the meter shut itself off before pulling it? They sure as hell don't do that around here.
Voltron and Majewski like this.
Old 08-27-2016, 06:08 PM   #28
Oh aren't we a tad sensitive?
