Window openers 230 to 240? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By HackWork
  • 1 Post By MechanicalDVR
  • 1 Post By dmxtothemax
  • 1 Post By MikeFL
Closed Thread
Old 07-18-2016, 05:36 PM   #1
Rewards Points: 6
Default Window openers 230 to 240?
I am installing some hopper windows which are high up off of the ground and equipped with motorized openers. The windows and the openers are German made. The openers are 230V/50HZwhich is causing some concern on the jobsite. Has anyone used a transformer to deal with an issue like this?
Bartmando (new guy)
Bartmando is offline
Old 07-18-2016, 05:39 PM   #2
Rewards Points: 1,275
Hi mr carpenter.
Majewski likes this.
HackWork is online now
Old 07-18-2016, 05:42 PM   #3
Rewards Points: 6
Hi Hackwork. I should add I'm not doing the wiring myself, just already installed the windows w the openers on them and trying to help figure out if this is a doable thing or if they are coming out (which would be a terrible thing).
Old 07-18-2016, 05:45 PM   #4
Rewards Points: 6
this is the unit.
http://www.geze.com/geze/products/rw...9035f8a414b33c
Old 07-18-2016, 05:56 PM   #5
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Ibtl
Majewski is offline
Old 07-18-2016, 06:05 PM   #6
Rewards Points: 3,006
Don't they have a 24v motor available?
IBTL
MechanicalDVR is offline
Old 07-18-2016, 06:10 PM   #7
triden's Avatar
Rewards Points: 382
Cannot use a transformer to change frequency.
triden is offline
Old 07-18-2016, 07:50 PM   #8
Rewards Points: 1,508
Originally Posted by Bartmando View Post
I am installing some hopper windows which are high up off of the ground and equipped with motorized openers. The windows and the openers are German made. The openers are 230V/50HZwhich is causing some concern on the job site. Has anyone used a transformer to deal with an issue like this?
Bartmando (new guy)
Two problems - 230v instead of 240v,
should not be a problem as they allow for a tolerence.
50Hz instead of 60Hz,
As the motors only operate for short periods
it may not be a problem.
But if your concerned, make recommendations
and let someone higher up make the decisions.
dmxtothemax is offline
Old 07-18-2016, 08:00 PM   #9
MikeFL's Avatar
Rewards Points: 600
If those motors are rated 230V/ 50Hz and you run them at 230V/ 60Hz they're going to turn 20% faster. That may or many not cause a problem when they reach their limit.
The url you provided has a phone number if you click "References" in the top right, but it's going to cost you because it's international. If you purchased them domestically, I suggest you contact the supplier. If he says you're ok and there is a problem, it will be on him.
PS welcome to the forum.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
MikeFL is online now
Old 07-18-2016, 08:03 PM   #10
Rewards Points: 416
Default Get Mfr Reco
I agree with dmx:
If you have time in the morning, you can ask the manufacturer yourself. Their contact page is http://www.geze.com/geze/contact.html, it has their contact form and (even better) their phone number.
I would ask their tech support / engineer to give me a go / no go, and to please send me a short email saying so. Then give that to the client for warrantee purposes...
philipdybel is offline
Old 07-18-2016, 08:04 PM   #11
Rewards Points: 3,106
From the 'product features' section, it looks like they are 24 volts and if needed, a separate AC adaptor can be used.
This means that most likely, the 24AC is converted to 24DC which is used for both the controls and motor.
If so, then it'd work on either a 50 or 60HZ system. A remote transformer (120V - 24V) would need to be installed nearby and there'd be no need for the factory 230 volt mains adaptor.
micromind is offline
Old 07-18-2016, 08:36 PM   #12
Speedy Petey's Avatar
Rewards Points: 600
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
Speedy Petey is offline
Closed Thread
Tell Me About Electric Gate Openers A Little Short General Electrical Discussion 17 07-02-2016 09:29 AM
Two Garage Door Openers A Little Short General Electrical Discussion 53 06-29-2016 04:35 PM
Up in smoke, or....... Sunshine came softly thru my , Window today do do do. macmikeman General Electrical Discussion 14 05-23-2016 12:17 PM
usable wall space under a window nmackintosh Canadian Electrical Forum 16 04-21-2016 08:09 AM
