Wire Reducing Pin/Adapter - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By splatz
Old 07-10-2019, 12:04 PM   #1
Rewards Points: 226
Default Wire Reducing Pin/Adapter
Some time ago someone posted pictures and links for wire reducing pins. They also posted one for a neutral termination of larger wire than would fit into the neutral terminals.
Set screw is what I am looking for.
Pictures or links appreciated.
Old 07-10-2019, 12:13 PM   #2
Rewards Points: 1,251
You have this kind that has fingers that will fit into a couple of neutral spots:
https://www.homedepot.com/p/Square-D...ANCP/202495831
Then this kind that will screw to the top fo the neutral bar:
https://www.homedepot.com/p/Square-D...ANCP/100115933
But you have to find ones that will work with your particular brand/model. hat are you looking to do and on which panel?
Old 07-10-2019, 12:29 PM   #3
Rewards Points: 226
Thanks Hax. The first link for the neutral is what I am looking for.
The second link is not.
Lets say you have to land 4/0 on a 100 amp breaker for VD. They make an adapter/pin for this. I cannot find a picture or link.
Thanks again.
Old 07-10-2019, 01:04 PM   #4
HertzHound's Avatar
Rewards Points: 1,192
Pin terminal? We used to call the lollipops
https://commerce.ilsco.com/e2wShoppi...197:3100012329
“Why say lot words when few words do trick”
Old 07-10-2019, 01:11 PM   #5
Rewards Points: 226
Thats the one except I need it to be set screw.
Thanks Hound.
Old 07-10-2019, 01:27 PM   #6
Rewards Points: 1,186
I can't remember if I've seen the pin terminals with a set screw.
You may have already thought of this, but you can find a set screw barrel / butt connector that fits both wires, put the big wire in one side, and put a pigtail of the smaller wire in the other.
John Valdes likes this.
Old 07-10-2019, 08:38 PM   #7
Jlarson's Avatar
Rewards Points: 4,074
Burndy makes, or at least they used to, make a set screw pin reducer
Old 07-10-2019, 11:05 PM   #8
Rewards Points: 117
Burndy makes some.
With pin adapters the range will be somewhat limited
http://www.leffelectric.com/featured...l-pin-adapters
ghostwriter is offline   Reply With Quote
The Following User Says Thank You to ghostwriter For This Useful Post:
John Valdes (07-11-2019)
