Wirenuts in motor - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree45Likes
Old 11-25-2016, 12:22 PM   #21
Rewards Points: 3,106
I use cheap tape, like 1700, sticky side out, then 130C then 88.
This way, as noted above, when the splice needs to be taken apart, simply slit it with a knife and it'll peel right off. Nothing is stuck to the wire or terminals.
glen1971 and splatz like this.
Old 11-25-2016, 12:56 PM   #22
LuckyLuke's Avatar
Rewards Points: 546
Regular preventive and predictive maintenance is the best solution in my opinion.
It's not that I am afraid to die, I just don't want to be there when it happens.
LuckyLuke is offline   Reply With Quote
Old 11-25-2016, 02:35 PM   #23
Rewards Points: 226
To really go old school how about sticky cambric turned sticky side out for first few turns, (there was a time when cambric did not have a sticky side btw) then rubber, then 33 and finally friction tape?
I still have a roll of friction tape downstairs somewhere. lol
Jhellwig and splatz like this.
Old 11-25-2016, 06:27 PM   #24
Rewards Points: 1,192
Old 11-25-2016, 10:20 PM   #25
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
That is how I like to do it on bolted lugs. I have it down to second nature and can go fast. Use the right width of tape and pile the tape on the end before you wrap around it.
I have seen people mess it up though. Taping it loosely without stretching the linerless is a pain to get off. Use lots of cambric to round it up and tape it tight. Only put one strip of linerless in the crotch. It doesn't need any more.
If you do it right it should pull itself off the connection when you cut it unless it has been baked on there for 10 years.
John Valdes likes this.
Old 11-26-2016, 02:02 PM   #26
Rewards Points: 226
I had a call late one night about a big motor not running. Got to the plant and found a blown fuse.
Replaced it and bang another fuse gone.
Megged it and found a dead short. Opened the peckerhead and found the split bolts taped with no more than two layers of 33. Nothing more.
Turns out they let a mechanic connect it that day instead of calling me.
glen1971 and Jhellwig like this.
Old 11-27-2016, 10:13 PM   #27
Cl906um's Avatar
Rewards Points: 1,206
The dude from this video surely must be dead by now.
Old 11-28-2016, 12:09 PM   #28
Rewards Points: 2,070
lucky there was not vfd, it would probably have failed also
Old 11-28-2016, 01:55 PM   #29
Rewards Points: 226
If it was on a VFD, highly unlikely it would have had motor fuses.
Old 11-28-2016, 10:45 PM   #30
Going_Commando's Avatar
Rewards Points: 1,540
Holy crap. You can tell he works for the manufacturer considering how much fricken tape that dude is using!
Terminal Wiring 30hp 3phase Compressor Motor Dirk MGirk General Electrical Discussion 8 11-05-2016 01:10 PM
motor calculations... stonewhite NEC Code Forum 4 06-02-2016 02:13 AM
Single phase motor wont start murph7489 PLCs, VFDs, Motors and Controls 41 05-09-2016 11:16 PM
how to replace dc motor with ac motor power calculation waff PLCs, VFDs, Motors and Controls 10 03-31-2016 03:47 PM
Motor overload setting katwalatapan Canadian Electrical Forum 9 01-26-2016 04:18 PM
