Wiring Method - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
  • 1 Post By Forge Boyz
  • 5 Post By Dennis Alwon
  • 10 Post By Dennis Alwon
  • 1 Post By MTW
Old 07-25-2018, 06:10 PM   #1
Brm2290's Avatar
Rewards Points: 8
Default Wiring Method
Hey guys! So, i started a new job with a company in SC and i am working with another co worker. We were roughing in a switch leg with the feed in the ceiling box. He asked me to make the connections in the ceiling box and first thing i did was put black tape on the white wire that goes to the switch, and join it with the black feed. My co worker saw what i did and said he doesn't do it that way and to join the black feed with the black going to the switch. Well, being from PA that is how i was taught so, i don't know if that's something they do in the south or what but in my opinion that way is incorrect. I ended up doing it his way so there was no arguement or debate on who's right.
Brm2290 is offline   Reply With Quote
Old 07-25-2018, 06:32 PM   #2
Rewards Points: 52
So he would end up with 2 white wires for the fixture? That doesn't make sense.
Sent from my Moto Z (2) using Tapatalk
matt1124 likes this.
Old 07-25-2018, 06:41 PM   #3
Rewards Points: 554
There is no right or wrong (or code) way to do that. Just mark any white that is used as a hot.
John M. is offline   Reply With Quote
Old 07-25-2018, 07:25 PM   #4
Rewards Points: 1,830
Sorry but that is incorrect. The white wire must be used as the hot not the return.
I can't help it if I'm lucky
Old 07-25-2018, 07:30 PM   #5
I should have given the reference
200.7 (C) Circuits of 50 Volts or More. The use of insulation that is
white or gray or that has three continuous white or gray stripes
for other than a grounded conductor for circuits of 50 volts or
more shall be permitted only as in (1) and (2).
(1) If part of a cable assembly that has the insulation permanently
reidentified to indicate its use as an ungrounded
conductor by marking tape, painting, or other effective
means at its termination and at each location where the
conductor is visible and accessible. Identification shall
encircle the insulation and shall be a color other than
white, gray, or green. If used for single-pole, 3-way or
4-way switch loops, the reidentified conductor with white
or gray insulation or three continuous white or gray
stripes shall be used only for the supply to the switch, but
not as a return conductor from the switch to the outlet
The Following 5 Users Say Thank You to Dennis Alwon For This Useful Post:
John Valdes (07-25-2018), MikeFL (07-25-2018), pjholguin (07-25-2018), splatz (07-25-2018), Wirenuting (07-25-2018)
Old 07-25-2018, 08:40 PM   #6
Rewards Points: 554
Thanks for that info. I was wrong.
Old 07-25-2018, 09:05 PM   #7
Brm2290's Avatar
Rewards Points: 8
Dennis did you find that in NEC 2017? Can you tell me what page? Thanks!
Old 07-25-2018, 09:20 PM   #8
Rewards Points: 7,633
2014 NEC, page, 70-50, or article 200.7 (C) (1).
Old 07-26-2018, 10:10 AM   #9
Brm2290's Avatar
Rewards Points: 8
Ok i can confirm. I opened NEC 2017, article 200.7 and it says same thing you're saying. Pics below in thumbnails.
Wiring Method-20180726_090232_1532610542377.jpg   Wiring Method-20180726_084650_1532610562951.jpg   Wiring Method-20180726_084657_1532610584103.jpg
Old 07-26-2018, 09:03 PM   #10
Magic Smoke Remover
Rewards Points: 1,966
How are you providing a neutral at the switch box?
Old 07-26-2018, 10:27 PM   #11
MTW
Rewards Points: 10,292
People actually do that?
readydave8 likes this.
Old 07-26-2018, 10:57 PM   #12
Rewards Points: 1,369
I usually mark it with a red sharpie at both ends, but I won't run a lot of switch legs these days. You never know what kind of fancy dimmer they might want down the line and it doesn't make sense break up the rhythm to bring out a spool of 14/3 just for switch legs.
Pool Wiring Method From SubPanel Kaffeene NEC Code Forum 6 08-14-2018 07:07 PM
Line voltage and control wiring in same JB katwalatapan Canadian Electrical Forum 10 10-21-2017 09:00 AM
Attic wiring, is this code compliant? NDC Residential Electrical Forum 38 04-06-2017 01:07 AM
Damaged wiring inside a water heater - questions Islander General Electrical Discussion 14 01-01-2017 05:37 AM
NPLFA circuit wiring khfiei General Electrical Discussion 5 02-06-2016 12:03 AM
