Work Vehicle / Show your work vehicle - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 11-22-2016, 11:47 PM   #1
Rewards Points: 6
Default Work Vehicle / Show your work vehicle
So i'm looking to work for myself. Just me for now. Im having trouble deciding between a van or something like a mercedes sprinter. I like the idea of being able to stand straight up inside. Im only 5'8" but I always hated being hunched over in a mini van or a full size 3/4 ton van.
Maybe this should be a "show your work vehicle" thread.
I tried searching for a thread like this on here but came up empty.... Maybe im searching wrong
Thanks
Roundy is offline   Reply With Quote
Old 11-23-2016, 12:08 AM   #2
I happen to really like my KUV covered service body on an Express 3500 chasis cab.
Sent from my SM-N920V using Tapatalk
John Valdes, Frank Mc and Jhellwig like this.
a.k.sperry is offline   Reply With Quote
Old 11-23-2016, 12:13 AM   #3
Rewards Points: 6
Thanks AK,
Thats a nice looking set up. How secure are the outer doors? I live in the city and park on the street.
Old 11-23-2016, 12:25 AM   #4
The outer doors on the Knapheide brand are pretty tough. This particular one has keyless entry for all the bin doors that is also matched to the chassis cab key fob. The other style has a mechanical bar that you padlock at the rear of the service body. I liked the idea of ind. locked doors instead of just having to cut off one lock.
The Following User Says Thank You to a.k.sperry For This Useful Post:
Southeast Power (11-23-2016)
Old 11-23-2016, 12:45 AM   #5
Rewards Points: 6
This thread can be removed. I found a few just like it on here.
Old 11-23-2016, 12:49 AM   #6
zac
Rewards Points: 822
No Roundy it's too late, I've just called the cops!
LuckyLuke and Roundy like this.
Old 11-23-2016, 12:54 AM   #7
Mensa Player
Rewards Points: 219
Roundy, I can't see any reason to buy a normal van when almost all of them have $1,500-2,500 options for a higher roof.
Being able to walk into your van is a night and day difference. Plus the extra height gives you extra shelf space.
Roundy likes this.
Old 11-23-2016, 01:59 AM   #8
Rewards Points: 26,360
No kidding.
Old 11-23-2016, 02:02 AM   #9
zac
Rewards Points: 822
Standing is overrated. What happens when you need to go to a lower shelf? Back on your knees!
Nah will look at one when Betsy dies.
Old 11-23-2016, 07:32 AM   #10
daveEM's Avatar
Rewards Points: 2,382
Regular size van has difficulties in parkades.
Depends on the work you do I guess.
I like perfect.
Old 11-23-2016, 07:51 AM   #11
Southeast Power's Avatar
Rewards Points: 8,514
My KUV is just about 7'3" and once in a while I hit something. I would buy another one right now if they were 6'7".
I dont need to go inside of it very much. ALL OF THE GOOD STUFF IS ON THE OUTSIDE! That's the point of a service body.
I really think I could keep a few ladders, a couple rolls of MC, and take everything else out of the middle inside, put in a fold down bunk, use one of the pipe chutes as a pantry and live in it.
Old 11-23-2016, 08:53 AM   #12
zac
Rewards Points: 822
I don't have a problem with much rain. How do you reconcile that? Seams to me the exterior would be an issue for you?
Old 11-23-2016, 08:58 AM   #13
Mensa Player
Rewards Points: 219
I can get to everything on the bottom shelves or the floor underneath by bending over, I never kneel.
Old 11-23-2016, 09:06 AM   #14
Mensa Player
Rewards Points: 219
I was going to get a KUV before I got the Sprinter. There are issues with that. The biggest is snow, I have to park on the street next to a high snow pile often, which means the entire left side of cabinets is blocked. The other issue is that often times you will need things out of 3,4,5, or 6 cabinets. That could be a pain, filling your arms up with tools and material and needing more. I like being able to step into the van and have everything available right there. I keep 2 shelves empty to put the material for the job I am working on, it also allows me to fabricate things right there. Plus, when doing service work, I would need access to a lot more material so I would need to get into the back of the KUV anyway. If you have to get in, that negates the easy access of the outside cabinets.
Just my opinion based on my style of work and working area. You are probably pulling onto construction sites most of the time while I am parking on the street and would be dodging passing cars when getting into the cabinets on the driver side.
Old 11-23-2016, 10:24 AM   #15
Rewards Points: 2,172
Problems at home lil buddy?
Old 11-23-2016, 10:30 AM   #16
Thanks AK,
Close to bullet proof, most bad guys don't carry cordless grinders:
Old 11-23-2016, 07:54 PM   #17
Senior Moment
drsparky's Avatar
Rewards Points: 40
This is my work ride. I spend a lot of time off the pavement towing. 3/4 ton, 4x4 lots of dry cargo space.
Jhellwig likes this.
Old 11-23-2016, 09:15 PM   #18
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 412
Mech have you seen these?
https://www.slicklocks.com
Work Vehicle / Show your work vehicle-img_0536.png
When in doubt, run in circles, scream and shout.
TheLivingBubba is offline   Reply With Quote
Old 11-23-2016, 10:25 PM   #19
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,481
I use the same thing but mine is a 95. I want a service truck but being able to haul 4 kids around without changing vehicles works good.
How do you organize tools in the back? I am thinking of getting a tool chest top box to sit in the back door.
Old 11-23-2016, 10:39 PM   #20
No I haven't, they must be newer than my retiring. Look interesting.
So you want to become an apprentice in Canada... Vintage Sounds Electrician Apprentice Forum 52 08-07-2017 04:59 PM
Work in SW Virginia andytheham Looking For Work 0 03-19-2016 05:43 PM
