world plugs and sockets - Electrician Talk - Professional Electrical Contractors Forum
Old 04-03-2010, 07:52 AM   #1
Senior Moment
drsparky's Avatar
Rewards Points: 294
Default world plugs and sockets
I lived all over the world and have used a bunch of these. Here is a interesting Wikipedia article on world electrical plugs and sockets.http://en.wikipedia.org/wiki/AC_power_plugs_and_sockets
Old 04-03-2010, 02:15 PM   #2
NO high voltage here
Rewards Points: 1,248
i was in london this year... Learned really quick about different plugs. my sister blew some **** up too. i told her 220 wont work
Old 04-03-2010, 05:44 PM   #3
Vintage Sounds's Avatar
Rewards Points: 4,004
I visit family in India fairly regularly. India is a god damn electrical nightmare. Just about every place you look the wiring is sloppy or dangerous, although the standard is rising in building ~10 years and newer. High voltage boxes routinely left wide open on the street. Cables dangling all over the place, sometimes unterminated. Voltage potential between shower water and ground sometimes. No GFCIs. No electrical code that I could find. Extremely sloppy coreline-like stuff sticking out of concrete in some places. No concept of bending pipe but PVC conduit does get used for some things. Copper theft is very common as is electricity theft. Ground pins often broken off. Many fluorescent ballasts are cheap, noisy and crappy - good ones are available too but at several times the cost of the cheap ones. Nobody seems to make a distinction between phase and neutral conductors which are all sorts of random colours. Only green is standardised.
3-phase voltage is 415v, otherwise all other loads 240v. They use BS 546 3-pin 5A sockets for normal stuff and a similar looking but larger 15A version for bigger loads. On more professional room AC installations a proper disconnect box with a local circuit breaker is provided and has a different kind of plug/socket, the name of which I haven't been able to find out. For ungrounded loads when the 546 is not used there's a 2-pin 2A ungrounded plug which easily falls out of the socket. I believe every service is three-phase but there generally are no three-phase loads in a house. Central AC is uncommon given the often open construction style used there.
In my grandmother's old house(completed 1969) a surface mounted wiring technique was used. It was obvious this was installed by a true craftsman. A narrow wide strip of wood was nailed to the wall coming out of each room's main switch box, going up to the ceiling onto which the wires were bundled and stapled. It forked when it got to the ceiling and narrower strips of wood took the wires to individual loads. It's a hot country so every room in every house and building has a ceiling fan. In the old days the speed was controlled by a huge variable autotransformer. These were the best. Then resistive coils with multiple taps became popular because they were cheaper. Now they use tiny solid state controls, which are okay, and quiet but, sometimes provide inadequate control.
Sockets and wrenches mattsilkwood Tools, Equipment and New Products 40 07-19-2010 03:34 PM
Electrical Sockets Shubey Off Topic (Non Trade) 0 09-23-2009 07:27 AM
sockets steve c UK Electrical Forum 5 08-17-2009 02:02 PM
Getting a Feet to sockets Gavin Adams UK Electrical Forum 8 11-24-2008 01:32 PM
Sockets with RCD kevruta NEC Code Forum 2 02-26-2007 07:50 AM
