Is this wrong? - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree105Likes
Old 02-07-2019, 07:04 PM   #41
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,046
I would have put a 3 wire plug in. How is this different from jumping the nutreul to ground on a 120 volt 15 amp receptacle.
when appliances are delivered , they install 4 wire cords....It's
the law here...and yes we do have carry and conceal.
Old 02-07-2019, 07:08 PM   #42
CoolWill's Avatar
Rewards Points: 2,388
Electrically, it's the same, but mechanically, it's quite different. A dryer receptacle won't see as much use as a regular receptacl, therefore less likely to have a connection break or come loose.
Old 02-07-2019, 07:15 PM   #43
lighterup's Avatar
electrically it's the same? what?
the new appliance needs to have an egc run to it , seperate
from the neutral...period...the end...time machine or no time machine
Old 02-07-2019, 07:21 PM   #44
CoolWill's Avatar
Go back and have another look. The question was asked "How is this different from jumping the neutral to ground on a 120 volt 15 amp receptacle?"
My answer is that it isn't different electrically.
Old 02-07-2019, 07:58 PM   #45
Mensa Player
Rewards Points: 1,819
You're not allowed to do that with a 120V 15A receptacle, but you are allowed to bond neutral to ground for a 240V 30A dryer feed.
Old 02-07-2019, 08:02 PM   #46
Mensa Player
That's not the law elsewhere.
When someone buys a dryer they pay for the cord kit. When the dryer is delivered, the driver installs either a 4 prong or 3 prong cord to match the receptacle that the customer has. The dryer comes equipped from the factory with a bonding jumper for the express purpose of bonding neutral to ground when using a 3 wire cord. I am sure that you have seen that in the dryer's instruction manual.
It's perfectly code compliant and within the dryer's listing.
Old 02-07-2019, 09:11 PM   #47
neutral member
readydave8's Avatar
Rewards Points: 634
In that situation I would have normally used 10-2 and a 3 prong outlet,
I really don't see much difference between 3-wire receptacle and 4-wire with neutral jumped to ground, so dodging that,
what's with the 10-2? as others have mentioned, that's never been legal for dryer receptacle
HackWork likes this.
Dave Ruth
Old 02-07-2019, 09:14 PM   #48
Mensa Player
I plead ignorance. My bad.
I probably shouldnít have said what you quoted me saying. As I mentioned later in the thread, I donít really install three prong outlets at all. The situation today was very uncommon.
Old 02-07-2019, 09:26 PM   #49
Rewards Points: 7,520
The NEC allows that? That would not fly here.
Funksparky and jelhill like this.
Old 02-07-2019, 09:35 PM   #50
CoolWill's Avatar
It did allow it. I think it was the 1993 or 1996 NEC that nixed it. You can still repair existing installs.
eddy current likes this.
Old 02-07-2019, 09:39 PM   #51
Here if you touch an old installation you must follow new code. You can replace a broken outlet, but alter the wiring at all, even if you only want to move it an inch, it must be to new code.
lighterup likes this.
Old 02-07-2019, 09:41 PM   #52
Mensa Player
The bond is typically done in the dryer itself, read a post 46 for the explanation.
Old 02-07-2019, 09:57 PM   #53
I’ve done a lot of work in older houses here and never seen a three prong dryer outlet.
Old 02-07-2019, 10:27 PM   #54
CoolWill's Avatar
Iíve done a lot of work in older houses here and never seen a three prog dryer outlet.
Of course not. Outlets dont have prongs silly.
Old 02-08-2019, 07:14 AM   #55
Mensa Player
Iíve done a lot of work in older houses here and never seen a three prong dryer outlet.
It's very common here.
I don't know why they allowed neutral to be bonded to ground in dryers/ranges. I agree with the others who say that it's not a good idea. Just like I think it's silly to allow parallel paths in the service entrance, and I support the Canadian code change to disallow that.
Old 02-08-2019, 07:35 AM   #56
Going_Commando's Avatar
Rewards Points: 1,486
I thought it was compliant to extend a 3 wire circuit?
Even my favorite New Englander does it:
Attachment 132182
We're thru.
CoolWill likes this.
Going_Commando is online now   Reply With Quote
Old 02-08-2019, 07:48 AM   #57
Mensa Player
Originally Posted by Going_Commando View Post
We're thru.
You're in New Hampshire, not the state of New England.
Old 02-08-2019, 10:30 AM   #58
Rewards Points: 16,315
I remember when the code changed and I started having to not use ..................
readydave8 likes this.
Old 02-08-2019, 10:35 AM   #59
Small Potatoes
flyboy's Avatar
Rewards Points: 3,642
I'm going to remember this thread the next time I'm told
"I don't know what I'm doing" and "don't know code"
You don't know what you're doing and you don't know code.
Old 02-08-2019, 10:50 AM   #60
German Spy
Helmut's Avatar
Rewards Points: 3,969
Maybe next time carry a 3 wire dryer outlet, and a 3 wire cord to match, make the bond in the dryer where it's supposed to be, and call it a day.
B-Nabs likes this.
Whats wrong in this picture? :) Whose firing on all 8 cylinders? 847Videos General Electrical Discussion 55 06-10-2018 04:25 PM
Right or Wrong John Valdes Off Topic (Non Trade) 17 05-21-2018 04:33 PM
Homework question that I got wrong? Hmm... JasonCo NEC Code Forum 16 03-06-2018 01:04 PM
Wrong Order! MechanicalDVR General Electrical Discussion 17 07-28-2016 07:34 AM
