WTF these Arc-fault breakers!! - Electrician Talk - Professional Electrical Contractors Forum
Old 12-08-2009, 06:22 PM   #1
Default WTF these Arc-fault breakers!!
Sorry if this has come up (I'm sure it has) I'm an FNG this is my first post found this site 10 minutes ago.
We are having A LOT of warranty calls about GE combo arc-faults tripping. The circuit is fine until Home owners try and use- new TVs, computers, phone chargers, vacumes, humidifiers, fluorescent lights etc...
We also use square D and have had similar problems but nothing like the GEs. I've called the GE arc-fault hot line and they admit there's potential to trip with these appliances however they are very un-helpful with any suggestions about how to solve the problem.
Anyone else starting to have these problems? We are one of the first in this area (Denver) to go with the 08 code and all the extra ach-faults. That along with working for Richmond homes, who are turning houses out VERY quickly. I'm thinking we are at the tip of the spearhead of a very big problem here.
Any news from anyone about this ...?
Mike Brown is offline   Reply With Quote
Old 12-08-2009, 06:28 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
When you rough the place in, you need to megger out all the circuits. That will identify the problems that may get covered up by the walls, like damaged cables, over-driven staples and the like.
Meg them out again before you start trimming out to make sure someone hasn't driven a nail or screw into the cable.
Then start trimming out.
If you have a circuit that keeps tripping an AFCI, you need to start troubleshooting it. Is it ANY load that trips it, or a specific load? Will that load trip if plugged into another circuit?
Semi-Ret Electrician (12-30-2012), The_Modifier (04-11-2011)
Old 12-08-2009, 06:42 PM   #3
Rewards Points: 1,816
I have used GE for many years and have been installing the combo arc faults for some time and never had a problem.
I seem to recall that sq.D had a big problem in the Denver area and they discovered that the problem was related to the power company signature voltage. Apparently the sine wave was flattened at the top which caused havoc on the arc faults.
I can't help it if I'm lucky
Old 12-08-2009, 06:56 PM   #4
Rewards Points: 2,012
Is this really feasible? ow you must 'complete' the ckt on rough?
How much time (read money) does this add to the already over-tight job?
Great to do do,document,makes back charge a lot easier.
Good Idea,but in practical application?
Old 12-08-2009, 07:10 PM   #5
Florida resident
ampman's Avatar
Location: Florida , if your not here you're somewhere else
Rewards Points: 1,604
megger the circuits that are tripping
ampman is offline   Reply With Quote
Old 12-08-2009, 07:24 PM   #6
hogsmoss's Avatar
Rewards Points: 25
sorry to hear it man. i was helping a guy in boulder finish a custom house that had problems with nuisance tripping on arc faults because of the transformers for the rail lighting in the house. it was a real pain in the butt to re-wire everything.
hogsmoss is offline   Reply With Quote
Old 12-08-2009, 07:29 PM   #7
Oh,I understood that,perfect sense.
I was referring to megger at rough.
There is a variety of problems with the Arc faults.
Most common that I see are motor driven,vacuum etc. mostly,beleive it or not,Smoke detectors.
Perhaps just shoddy mass production issues (smokes).
Old 12-08-2009, 09:03 PM   #8
Rewards Points: 282
When I was in the Navy, we meggered all the motors, topside lighting...etc.
In a residence, do you megger hot to neutral, hot to ground or both?
What voltage do you apply? 250Volt?
What values do you expect on a good install; infinite or do you have a specific minimum number?
Thanks,
Rick
subelect is offline   Reply With Quote
Old 12-08-2009, 09:28 PM   #9
Grimlock's Avatar
Rewards Points: 502
We had trouble with CH arc fault breakers in the past. We found that there was a lot of heat buildup if the AFCI breakers where placed next to each other. By spacing them out the heat was able to dissipate and the majority of the problems went away. Heat could be an issue to consider in your case as well, something to check next time.
Grimlock is offline   Reply With Quote
Old 12-08-2009, 11:27 PM   #10
3rd Generation
MF Dagger's Avatar
Rewards Points: 1,010
I installed a GE 20 amp arc fault breaker today that was literally an exact match for a Siemens except it had a GE sticker on it.
MF Dagger is offline   Reply With Quote
Old 12-09-2009, 03:36 AM   #11
Just Dealing With it....
Shado's Avatar
Rewards Points: 502
BTW....
Welcome to the forum!!!
- Dave ........
Shado is offline   Reply With Quote
Old 12-09-2009, 02:06 PM   #12
Rewards Points: 18,231
Have you got a picture of that breaker? I ask because all the GE ones I ever saw have two paddle rocker test buttons on them and Siemens has two blue push buttons for testing.
I had problems with Cuttler "Combo" ark faults in the past. I say past cause I switched to Siemens panels and no more problems so far.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 12-09-2009, 06:05 PM   #13
3rd Generation
MF Dagger's Avatar
I don't have a picture but i could probably take one at Menards. They had another one that looked the same. The 15 amp arc fault I bought looked like the normal GE one with the paddle it was just the 20 amp that was a Siemens match.
Old 12-09-2009, 06:10 PM   #14
3rd Generation
MF Dagger's Avatar
http://www.homedepot.com/webapp/wcs/...7X-_-100674086
Here's the one I had only it was 20 amp
Old 12-09-2009, 08:24 PM   #15
That Guy
Mr. Sparkle's Avatar
Rewards Points: 2,002
Not that I am accusing the OP of this but I am baffled at the amount of "electricians", and electricians helpers that don't understand that you need to make sure you keep downstream grounded conductors separated. More often than not I bet this is what is causing many of the issues with arc-faults.....speaking of which I am in the middle of estimating my first addition that I will have to use AF breakers and TP recepts. Oh joy.....
Old 12-10-2009, 09:59 AM   #16
Default arcfault problems
Could you elaborate on "keeping down stream grounded conductors seperated" thank's.
snorky is offline   Reply With Quote
Old 12-10-2009, 10:10 AM   #17
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
I'd guess that means, "don't share neutrals with other circuits".
Old 12-10-2009, 01:22 PM   #18
Default arcfault
Thank's,Buzzkill.The reason I had asked is my son told me if any of the grounding conductors made contact with grounded ones that it would trip.I/m talking bare end of conductors,like if too much of neutral was exposed from wingnut and made contact with ground.
Old 12-10-2009, 01:24 PM   #19
That would trip an AFCI.
Old 12-10-2009, 03:19 PM   #20
IBEW 332
RUSSIAN's Avatar
Rewards Points: 150
I believe there is a recall on ge arc-fault breakers, I'm in the process of buying a house and I have to sign something about it with every offer. I can't remember the details so i could be way off. I'll try to find it and post back
RUSSIAN is offline   Reply With Quote
Do i need Arc Fault breakers installed? pawirenut General Electrical Discussion 20 12-19-2012 08:32 PM
Arc Fault Breakers Trips Easyravy Residential Electrical Forum 8 03-26-2009 12:33 AM
Arc Fault breakers waco General Electrical Discussion 2 11-13-2008 06:17 AM
installing arc fault breakers. mikewardjr General Electrical Discussion 15 12-01-2007 11:48 AM
arc fault breakers justimaginethat General Electrical Discussion 1 09-05-2007 07:44 AM
