Xfmr Lugs - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 2 Post By macmikeman
  • 1 Post By micromind
  • 2 Post By Southeast Power
  • 3 Post By varmit
  • 1 Post By brian john
  • 2 Post By splatz
  • 1 Post By frenchelectrican
  • 1 Post By lightman
Old 07-27-2017, 12:27 AM   #1
Rewards Points: 282
Default Xfmr Lugs
I am trying to find a method of connecting 11 individual 4/0 conductors (each phase) to the lugs of a pad-mount 1500 KVA xfmr. So far, I have had no luck finding something that will have sufficient clearance between the phases and still bolt up to the Lugs.
Have you run into this problem before?
Thanks,
Rick
subelect is offline   Reply With Quote
Old 07-27-2017, 01:03 AM   #2
Rewards Points: 18,301
That is a lot of conductors. Poco guys will run a single set into a 48" x 48" buried vault and use a bunch of sweethearts in there. For secondaries. If these are primary wires , call the transformer company and ask them what you should do.
Dash Dingo and circuitman1 like this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 07-27-2017, 01:08 AM   #3
Rewards Points: 21,898
Thanks,
Rick
1500 KVA transfomer ? humm .,, do you have some type of specs what you can get a hold of it ? I am pretty sure the secondary side it kinda staggered stack up that what I remember one before.
myself and couple other guys may know a trick with this set up once I know which way the secondary is comming out of the transfomer itself.,,
I cant remember who have the photo of the connection of the common 1500 KVA transformer but I am aware of few ways of secondary connectons is.
I know the last one I did have both 6 port connectors so I ran 6 each side on the secondary take off lugs.
I dont know how tight the room you have in there. but mine was not too bad.
subelect (07-27-2017)
Old 07-27-2017, 11:26 PM   #4
Dash Dingo's Avatar
Rewards Points: 318
The poco takes care of that around here. Is it a poco supplied transformer?
Dash Dingo is offline   Reply With Quote
Old 07-28-2017, 01:42 AM   #5
Rewards Points: 3,130
I've used back-to-back crimp lugs, they also make ones that have a 45º bend.
Old 07-28-2017, 07:42 AM   #6
Southeast Power's Avatar
Rewards Points: 8,728
I was thinking the same thing but he would need six holes per bus to pull that off.
Not unreasonable at all.
micromind and MechanicalDVR like this.
Old 07-28-2017, 07:55 AM   #7
Rewards Points: 1,750
If you only have 4 hole connection pads, you could probably stack crimp lugs with the bottom layer turned 180 degrees to the top layer.
The Following User Says Thank You to varmit For This Useful Post:
Southeast Power (07-28-2017)
Old 07-28-2017, 10:23 AM   #8
Rewards Points: 1,986
They also make a spacer that allows you to stack crimp/hypress lugs.
You never gave dimensions BUT
https://commerce.ilsco.com/e2wShoppi...221:3100012705
Old 07-28-2017, 02:01 PM   #9
That's what I was thinking too.
Usually, the bus is thick enough to accomodate at least one of the lugs turned inward.
This way you'll have 3 per hole and need 4 holes.
frenchelectrican likes this.
Old 07-28-2017, 07:04 PM   #10
Rewards Points: 1,334
If you look at the Blackburn Color Key catalog (and I am sure others) there are lugs that are made to stack nicely in cramped spaces.
The Following 2 Users Say Thank You to splatz For This Useful Post:
frenchelectrican (07-28-2017), telsa (07-28-2017)
Old 07-28-2017, 07:28 PM   #11
Rewards Points: 26,610
I must admit, 11 x 4/0 is astounding per 'spade.'
I can't fathom it.
That much secondary power usually goes off in bigger conductors to a (solo) distribution panel. ( Big Box )
The implication here is that you're piping 200A panels something crazy out of one titanic transformer... skipping the Big Box all together.
Weird.
Old 07-28-2017, 11:05 PM   #12
I can't fathom it.
Weird.
I have see that before Tesla.,,
I know I was kinda little suprised with that numbers of conductors on that size due normally I useally see it in 500kcm or larger .,
unless someone screw the pooch with undersized conducts .,, that is the only time I see when they ran bunch of 4/0's
micromind likes this.
Old 07-29-2017, 07:33 AM   #13
I can't fathom it.
Weird.
I would like to see what that riser looks like too.
Old 07-29-2017, 07:35 AM   #14
I like the comment " NEMA hole spacing for flexibility" doesn't mean you have to have a bolt in every hole.
Old 07-29-2017, 11:59 PM   #15
Rewards Points: 352
Our company used to use nema standard 2 hole lugs. We had a stock number for an aluminum extension plate 1/2 X 4 X however long you needed that was drilled out to the nema standard 2 hole pattern. You would bolt it onto the 2 hole transformer lug. Later on we changed to an aluminum bar with holes and set screws that would screw onto a threaded stud on the transformer. A stacking type lug is useful but with that many conductors I would expect you to run out of room. I don't ever remember having a failure on the 1/2 X 4 extension. We would do up to 1000MCM conductors this way.
lightman is offline   Reply With Quote
Old 07-30-2017, 02:07 AM   #16
Jlarson's Avatar
Rewards Points: 4,074
I've done the plate thing before.
Preferably I just run a few conductors out of the pad to one or more tap boxes then feed from them though.
Old 07-30-2017, 02:24 AM   #17
My Pocos dictate this sort of thing.
If it's their unit, they will land the secondaries, period.
The OP has me corn fused because his power level spells BIG while 4/0 says not-so-big.
Old 07-30-2017, 08:37 AM   #18
It never occurred to me that it was a POCO transformer, I just assumed it was private due to all of the excessive taps.
I was just thinking someone being asked how another 600 amps could be added.
Disconnect to lugs on sub panel fastlane General Electrical Discussion 5 07-22-2017 01:17 AM
Lugs / Termination temperatures 2825mdh1 General Electrical Discussion 10 09-30-2016 05:16 PM
480Y/277V Isolation XFMR eztorres General Electrical Discussion 2 05-24-2016 08:49 PM
Feed through lugs TRurak NEC Code Forum 10 04-18-2016 06:30 AM
GE THQL Breaker Lugs Splitting at Specified Torque Mr. Skookum General Electrical Discussion 16 03-11-2016 02:53 PM
