yestedays GPS install - Electrician Talk - Professional Electrical Contractors Forum
Old 05-30-2012, 05:09 PM   #1
crispy critter
green light's Avatar
Rewards Points: 1,026
Default yestedays GPS install
Heres some pics of a couple of gps antanas I mounted yesterday. This building is the terminal station for an undersea observatory. There are submarine cables that go from the station various locations offshore, and are connected to an array of test devices that measure almost any oceanic condition you can think of, and provide real time video of the Axial Seamount, wich is a undersea volcano about 300 miles off the coast of Oregon. The pictures that follow the gps pics are work I did last year for my previous employer. I figured since I was there Id take some pics to share. Its pretty cool stuff. Well here you go. Tear it up
Heres the view from the roof looking towards haystack rock and the pacific
this is rectifier and panel for the 500 vdc power supplies that provide power to the cables and array. notice the cooling lines that go into the rectifier.
battery charge controller, and tranny. You can see the incicator lights I installed for the high resistance ground system.
power supplies and stuff...
battery cabinet
I'm old enough to know better, but too young to care.
green light is offline   Reply With Quote
The Following 4 Users Say Thank You to green light For This Useful Post:
76nemo (05-31-2012), aDudeInPhx (05-30-2012), B4T (05-30-2012), erics37 (05-30-2012)
Old 05-30-2012, 05:17 PM   #2
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
Good looking work!
Been too long since I've been to Cannon Beach....
Pete
Old 05-30-2012, 05:22 PM   #3
Semi-Ret Electrician's Avatar
Rewards Points: 486
battery cabinet
Great work and view!
Old 05-30-2012, 05:24 PM   #4
crispy critter
Originally Posted by Pete m. View Post
Good looking work!
Pete
Thanks pete. There are actually two haystack rocks. This one is in Pacific City
Old 05-30-2012, 05:25 PM   #5
Whats the purpose of GPS antennas on a stationary building?
Bbsound is offline   Reply With Quote
Old 05-30-2012, 05:27 PM   #6
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
.... are connected to an array of test devices that measure almost any oceanic condition you can think of ...
I thought of this instantly...
póg mo thóin
The Following 2 Users Say Thank You to Celtic For This Useful Post:
erics37 (05-30-2012), nolabama (05-30-2012)
Old 05-30-2012, 05:40 PM   #7
Pete m.'s Avatar
Rewards Points: 172
Did not know that!! I've only been to Cannon Beach... used to live in Spanaway, WA.
Pete
Old 05-30-2012, 05:40 PM   #8
crispy critter
Not sure They say install and we give you money. I say O.K., install and recieve money Works for me.
The Following User Says Thank You to green light For This Useful Post:
BBQ (05-31-2012)
Old 05-30-2012, 06:05 PM   #9
I see them in TV studios to sync time.
jakeparr is offline   Reply With Quote
The Following User Says Thank You to jakeparr For This Useful Post:
green light (05-30-2012)
Old 05-30-2012, 06:14 PM   #10
CFL
Rewards Points: 940
Probably to make sure their equipment is working properly. They know their coordinates will always be the same. We have about a dozen antennas where I work.
CFL is offline   Reply With Quote
Old 05-30-2012, 06:18 PM   #11
That makes sense
The Following User Says Thank You to Bbsound For This Useful Post:
socalelect (05-30-2012)
Old 05-30-2012, 06:31 PM   #12
crispy critter
They are using them to sync time and time stamp transmissions
Semi-Ret Electrician (05-30-2012)
Old 05-30-2012, 09:43 PM   #13
erics37's Avatar
Rewards Points: 642
Nice looking stuff! How come you get the clean research lab work and I get stuck at the filthy fish plant and sewer plants?
The Following User Says Thank You to erics37 For This Useful Post:
socalelect (05-31-2012)
Old 05-30-2012, 10:28 PM   #14
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 842
That big red mushroom button without a protective cover brings back bad memories.
Cowboy words of wisdom.
Never approach a bull from the front, a horse from the rear, or a fool from any direction.
LARMGUY is online now   Reply With Quote
Old 05-30-2012, 10:53 PM   #15
erics37's Avatar
Rewards Points: 642
The Following 2 Users Say Thank You to erics37 For This Useful Post:
LARMGUY (05-30-2012), socalelect (05-31-2012)
Old 05-30-2012, 11:01 PM   #16
Rewards Points: 2,002
Dirty mind = dirty work.
The Following User Says Thank You to user4818 For This Useful Post:
Old 05-31-2012, 06:32 AM   #17
Senior Moment
drsparky's Avatar
Rewards Points: 334
We put GPS antennas on barns and poles, a lot of tractors are GPS controlled and need the reference timing signal loop. The driver just brings the tractor to the start of the row and the GPS takes over speed and steering, the driver then is freed to watch his monitors. Farming ain't Green Acres anymore.
Cat 5e install blinkers General Electrical Discussion 9 05-14-2012 11:04 PM
Hot Tub Install doubleoh7 NEC Code Forum 18 06-19-2011 04:34 PM
How could someone install this? gnxtc2 General Electrical Discussion 29 03-22-2011 11:05 PM
Hot Tub Install Roger123 NEC Code Forum 2 10-08-2010 09:32 PM
fan install help pls pls help mars6394 UK Electrical Forum 9 01-11-2010 06:46 AM
