Yesterday's ATS.... - Page 10 - Electrician Talk - Professional Electrical Contractors Forum
Old 08-05-2013, 09:35 PM   #181
BBQ
Salty Member
BBQ's Avatar
Originally Posted by B4T View Post
I have a #4 running from bottom ground bar to ATS..
My house is green, but you still need to relocate the GEC to the ATS.
Old 08-05-2013, 09:39 PM   #182
Rewards Points: 256
I thought lipa didn't allow line and load wires to cross in that meter bypass pan. Does the #4 water ground and rod now go back to the service rated transfer switch? Also any old 3 wire dryer and ranges changed to 4-wire as that is no longer a main breaker panel?
123electric is offline   Reply With Quote
The Following User Says Thank You to 123electric For This Useful Post:
Old 08-05-2013, 09:40 PM   #183
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Nice job B . If It was my hand dealt, there would have probably been a gas meter right under that mess.
The Following User Says Thank You to Shockdoc For This Useful Post:
B4T (08-05-2013)
Old 08-05-2013, 09:42 PM   #184
BBQ
Salty Member
BBQ's Avatar
The code sections.
250.24 Grounding Service-Supplied Alternating-Current Systems.
(A) (1) General. The grounding electrode conductor connection shall be made at any accessible point from the load end of the service drop or service lateral to and including the terminal or bus to which the grounded service conductor is connected at the service disconnecting means
250.64(C) Continuous. Grounding electrode conductor(s) shall be installed in one continuous length without a splice or joint except as permitted in (1) and (2):
(1) Splicing shall be permitted only by irreversible compression-type connectors listed as grounding and bonding equipment or by the exothermic welding pro-cess.
(2) Sections of busbars shall be permitted to be connected together to form a grounding electrode conductor.
Old 08-05-2013, 09:42 PM   #185
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
I have never been call on that.. what is wrong with #4 jumper going to ATS..
Old 08-05-2013, 09:43 PM   #186
BBQ
Salty Member
BBQ's Avatar
The GEC has to be continuous or irreversibly spliced, see above.
The Following 2 Users Say Thank You to BBQ For This Useful Post:
ghostwriter (08-05-2013), Magnettica (08-05-2013)
Old 08-05-2013, 09:47 PM   #187
gold's Avatar
Rewards Points: 2,070
I guess technically we should be doing this shouldn't we. I have not been.
Define "Anger Management"
“Free at last, Free at last, Thank God almighty we are free at last.”
gold is offline   Reply With Quote
Old 08-05-2013, 09:49 PM   #188
B4T
B4T's Avatar
I understand what you are saying.. but I haven't come across a generator job yet where the GEC was crimped and run to ATS...
Old 08-05-2013, 10:10 PM   #189
Rewards Points: 133
I have done it on the 25+ generators I have done since Sandy. I carry crimps for #4 and #6 CU, and #2 AL. I think it is kind of silly, but what can you do.
Do it right, or do it twice...
jarhead0531 is offline   Reply With Quote
Old 08-05-2013, 10:40 PM   #190
Rewards Points: 3,208
I would not post a picture of a 10lb silver nugget here as the BS I would recieve for it not being gold.
Old 08-05-2013, 10:42 PM   #191
Our utilities do not allow crossing.
Old 08-05-2013, 10:49 PM   #192
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
That's because even some inspectors don't know what they're looking at! Checkout MH's Grounding and Bonding videos on Youtube! The Nexus ATS is service rated and therefore the grounding electrodes bond to the grounded neutral here, not in the old mb panel. The reason you cannot connect from one bonding block to another from panel to panel is because the electrode conductor must be continuous.
Replies based on NEC 2014
Old 08-06-2013, 03:45 AM   #193
B4T
B4T's Avatar
What crimping tool do you guys use.. my hydraulic crimper is not going to fit..
Old 08-06-2013, 03:56 AM   #194
Jlarson's Avatar
Rewards Points: 4,252
The little greenlee k111 or the T&B version hand crimpers are good for little stuff like 8, 6, 4 in panels
Yesterday's Gem TheBrushMan007 Business, Marketing, and Sales 10 09-12-2012 08:17 PM
Pictures: Yesterday's call out Roger123 General Electrical Discussion 29 05-03-2011 03:23 PM
Yesterday's Service Call 480sparky Residential Electrical Forum 18 08-16-2010 05:07 AM
