Zamac driving questions - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 05-02-2013, 02:57 AM   #21
christrician's Avatar
Rewards Points: 150
Originally Posted by Deep Cover
This...
Where did you get that I had one and it got stolen!! Those things were originally for baseboards heaters if I don't recall.
christrician is offline   Reply With Quote
Old 05-02-2013, 04:09 AM   #22
Rewards Points: 21,898
For myself I have homemade verison and that work very well but one time one guy forgot to bring it back so I used a old nutdriver for that purpose seems work ok to me.
Merci,
Marc
Old 05-02-2013, 02:35 PM   #23
220/221's Avatar
Rewards Points: 4,274
Originally Posted by Cow View Post
When I needed one, I cut 8" off the end of a ground rod and drilled a dimple in the end. And yes, I did still use the rod....
That's a LOT easier than using screws
The Following User Says Thank You to 220/221 For This Useful Post:
sbrn33 (05-02-2013)
Old 05-02-2013, 02:43 PM   #24
BBQ
Salty Member
BBQ's Avatar
What screw has as much holding power in a 1/4" hole?
christrician (05-02-2013)
Old 05-02-2013, 03:52 PM   #25
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
Here is allowable loading info.
Tap-con:
http://www.oldredheadsite.com/tapcon_perf01.asp
Zamac:
http://www.powers.com/pdfs/mechanical/02826.pdf
Pete
The Following User Says Thank You to Pete m. For This Useful Post:
FlatRateGator (05-02-2013)
Old 05-02-2013, 04:38 PM   #26
cdnelectrician's Avatar
Rewards Points: 1,018
I hate those things. Aluminum ALEX anchors and number 10 screws for me! There are certain situations where zamacs are handy though.
Old 05-02-2013, 10:31 PM   #27
"A" Inside Wireman LU 134
Rewards Points: 97
How about tapcons? The only people I see who use those damned beat off anchors are the elevator guys (and this is only because they don't know better).
Piping as long as I can...
pugz134 is offline   Reply With Quote
Old 05-03-2013, 05:48 AM   #28
BBQ
Salty Member
BBQ's Avatar
I hate tapcons. I have had too many either break on the way in or strip out.
They may be great with green concrete but they suck with old concrete or red brick.
The Following 5 Users Say Thank You to BBQ For This Useful Post:
220/221 (05-03-2013), Cow (05-03-2013), EBFD6 (05-03-2013), sbrn33 (05-03-2013), wendon (05-03-2013)
Old 05-03-2013, 08:17 AM   #29
Pete m.'s Avatar
Rewards Points: 172
I can definitely agree with this.
Pete
BBQ (05-03-2013)
Old 05-03-2013, 01:00 PM   #30
BEAMEUP's Avatar
Rewards Points: 26
yup I have one too, it was for baseboard heaters, but setting anchors is the second best use for it. Cadet makes them, but you can get them at the big box stores:
http://www.homedepot.com/p/F-Series-...0#.UYPtK7X-HwA
BEAMEUP is offline   Reply With Quote
The Following User Says Thank You to BEAMEUP For This Useful Post:
christrician (05-03-2013)
Old 05-03-2013, 06:43 PM   #31
Rewards Points: 150
Thanks so much man!!!!!
I was gonna have to settle for this!!!!
Zamac driving questions-image-3926132258.jpg   Zamac driving questions-image-1161363349.jpg
Old 05-03-2013, 07:20 PM   #32
sbrn33's Avatar
Rewards Points: 3,564
That looks like something my wife uses on her way to work.
The Following User Says Thank You to sbrn33 For This Useful Post:
christrician (05-04-2013)
Old 05-03-2013, 07:26 PM   #33
Jlarson's Avatar
Rewards Points: 4,252
Tapcons suck pretty hard in a lot of block too. They are pretty much a 1 trick pony, new, quality concrete. Pins are more versatile, especially in service work. I carry pins, drop ins, wedges, and sleeve anchors normally, I carry a few tapcons and plastics but rarely use them.
Old 05-03-2013, 07:29 PM   #34
BBQ
Salty Member
BBQ's Avatar
Same here, I could find a handful of tapcons in the truck along with other options.
About the only difference is I do also use a lot of plastic anchors for 1/2 & 3/4 EMT work.
Old 05-03-2013, 07:52 PM   #35
Jlarson's Avatar
I used to use a lot of plastics but I've moved to 1" long pins mainly so I could use 1/4" sds bits instead of the cheapie bits that come in anchor kits.
Old 05-03-2013, 07:59 PM   #36
BBQ
Salty Member
BBQ's Avatar
I use a 1/4" SDS, I toss the cheepie away.
sbrn33 (05-03-2013)
Old 05-03-2013, 08:05 PM   #37
Jlarson's Avatar
We get kits that have like a 9/32 bit.
Old 05-03-2013, 08:11 PM   #38
BBQ
Salty Member
BBQ's Avatar
Freaky.
I can pretty much get by with 1/4, 3/8, 1/2 & 5/8'
Old 05-03-2013, 08:14 PM   #39
Rewards Points: 150
I'm not knocking them, but I have never, ever used a plastic anchor. I don't know why. I go right by them in the anchor aisle but never pick them.
FlatRateGator is offline   Reply With Quote
Old 05-03-2013, 08:28 PM   #40
220/221's Avatar
I've used enough for both of us.
For me, it is often handy to be able to remove or loosen screws to get stuff level and lined up. Also, sometimes you need to hang something, get a conduit measurement and then remove it.
And then there is the "oh ****" moment when you realize something in in the wrong place.
I hate driving a van! 99cents Tools, Equipment and New Products 74 06-24-2013 08:33 PM
my van is driving me crazy NacBooster29 Off Topic (Non Trade) 4 01-22-2013 11:00 PM
Driving ohmontherange Off Topic (Non Trade) 4 12-25-2012 12:26 AM
zamac set tools...where??? heywood Tools, Equipment and New Products 13 09-24-2009 08:03 PM
What is everyone driving artisanelec Business, Marketing, and Sales 34 09-01-2008 05:43 PM
