Zinsco Remediation - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 5 Post By brian john
  • 3 Post By ppsh
  • 2 Post By varmit
  • 1 Post By Bird dog
  • 1 Post By ppsh
  • 1 Post By telsa
Old 03-12-2017, 08:03 PM   #1
ppsh's Avatar
Rewards Points: 124
Default Zinsco Remediation
I have a 100a u/g fed Zinsco flush mount meter main and its due for replacement. Need to add a few circuits and running out of spaces. Really don't want to have to tear out the can, feeders don't have any slack, and I don't want to tear out/patch siding. Don't have the space needed for a CH or BR retrofit interior either.
There is enough length on the wires that feed the backfed 100a main, that I could put ilsco butt splices on that, and feed a new panel.
Planing on putting a 100a main breaker panel inside the garage in the stud bay to the side of it, running 1 1/4" emt between the panels and pulling #2s.
Compliant, any better ideas?
ppsh is offline   Reply With Quote
Old 03-12-2017, 08:20 PM   #2
Rewards Points: 1,972
Zinsco was trash from day one, much less 40-50 years later, replace it.
MechanicalDVR, Cow, drspec and 2 others like this.
Old 03-12-2017, 08:28 PM   #3
Magic Smoke Remover
Rewards Points: 1,966
Pics?
Old 03-12-2017, 10:55 PM   #4
ppsh's Avatar
Rewards Points: 124
Not sure if my first post was clear enough, but essentially what I would be doing is using the old panel as a j box for the splice to the new panel. I would just be taking the wires from the meter that fed the main breaker, moving those to a 2 port mechanical butt splice, and have it feed the new panel instead. I would be relocating all existing circuits to the new panel. No Zinsco breaker would be in use.
Old 03-12-2017, 11:25 PM   #5
Rewards Points: 1,742
That is the standard way to relocate a panel in my part of the world. You will need to fix the old panel cover to where it does not hinge open to expose the splice. Two bolts or screws will take care of this.
brian john and MechanicalDVR like this.
Old 03-12-2017, 11:36 PM   #6
Magic Smoke Remover
Why cant you remove the existing wires from the meter to the main completely instead of splicing? I've never seen a zinsco meter combo before.
Old 03-12-2017, 11:39 PM   #7
Magic Smoke Remover
And I agree with varmit. Don't forget the bonding bushing!
Old 03-12-2017, 11:59 PM   #8
ppsh's Avatar
Rewards Points: 124
You have to pull the meter to get to the load side terminals. Easier to just extend whats accessible .
Old 03-13-2017, 12:03 AM   #9
Rewards Points: 3,006
As others have said I'd run in new wires and not do the splices, I see no benefit to splicing.
Old 03-13-2017, 12:32 AM   #10
Magic Smoke Remover
OH! I see what's going on now
I would rather yank the meter than splice hot in a small can with no breaker ahead of me, but that may not be feasible where you are....
Old 03-13-2017, 12:41 AM   #11
Bird dog's Avatar
Rewards Points: 942
His profile says says "Lv".
Majewski likes this.
Old 03-13-2017, 12:51 AM   #12
ppsh's Avatar
Rewards Points: 124
Might be possible that I found other employment since 2014?
The Following User Says Thank You to ppsh For This Useful Post:
Bird dog (03-13-2017)
Old 03-13-2017, 12:55 AM   #13
Magic Smoke Remover
I figured at his post count, he's made it this far. Those that shouldn't be get shut down pretty quick!
We all act like residential is low volt anyway, you guys don't pull out recepts from the box hot and run new circuits without shutting down the whole house?
Old 03-13-2017, 01:27 AM   #14
Rewards Points: 26,558
99% of my trade experience has been commercial...
BUT.
Every time I have had to un-scramble residential branch circuits and loads the joint was a mess. Mr. DIY and Mr. handy man had fubared MWBC and much else.
So, my operating philosophy is to power down at least half the house, and break out my toner and wand. Then I never 'let the smoke out.' I can also work much, much faster.
Zinsco Panel MechanicalDVR Residential Electrical Forum 5 01-26-2017 02:39 AM
Aluminum Remediation Question David40 Residential Electrical Forum 25 09-05-2016 08:55 PM
Zinsco panel swap out grounding question Woodsman General Electrical Discussion 5 04-23-2016 01:40 AM
Zinsco Electek inc Services and Service Equipment 3 03-30-2016 08:50 AM
Zinsco with dual screws - no bus bar danickstr General Electrical Discussion 4 03-25-2016 05:27 PM
