Grandma's Iron - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree73Likes
Old 11-29-2018, 12:12 PM   #21
Small Potatoes
flyboy's Avatar
Rewards Points: 2,956
You me and most other guys over 40!
It's funny, I have my collection and my dad's collection of tools.
I look at mine and see stuff in there I bet today's apprentices would just laugh at.
Then I look at my dad's collection and see stuff that belongs in a museum.
Old 11-29-2018, 01:45 PM   #22
Rewards Points: 17,452
It's all good, tools are tools and in the right hands can be a great thing.
I have woodworking tools that go back to my Great Grandfather which are basically civil war era and they are still just as sharp and usable.
BTW I till use the Edison adapter to use a circuit tracer on a keyless fixture.
flyboy, MikeFL and armsjac like this.
Old 12-15-2018, 10:36 AM   #23
Rewards Points: 321
Great thread. I collect fixtures from this error including "Plugs" that screw into a socket. I display them with a Kohler light plant and explain what has been written here.
fdew is offline   Reply With Quote
Old 12-25-2018, 06:27 PM   #24
Rewards Points: 2,296
QUOTE - not sure if a gas light on the ceiling wouldn't set the ceiling on fire.
In Australia they made allowances for gas lighting,
So any room which had roof mounted gas lighting
the ceiling height would be two feet higher
to safely allow the heat to dissipate.
So instead of being 10 feet high it would be 12 foot.
Old 12-25-2018, 09:21 PM   #25
Rewards Points: 16,466
Originally Posted by 460 Delta View Post
Around here a Carter, live 3-way is called a Delco 3-way by old timers because they used it to power the house from the plant in a shed. A third wire would let you turn on a light in the shed from the kitchen or the shed.
I remember one farm I done rewireing there were a standard 120/240 volt single phase 60 amp main line then there were second set of conductors which it was 32 volts DC from old delco plant ( the latter verison switched over to 120 volts AC but used the same set of conductors ) from the shed where they kept the delco gaz generator set and main fuse box there. plus a set of dammed carter 3 wayers from the house to shed and barn .,,
Cleaned all that crap out and ran underground and the issue sloved and yes they did have generator on hand but it is a pto type to hook up to the transfer switch at the shed to lit up the whole farm area.
The farm house that was a boatload full of dammed KT in there.
MechanicalDVR, MikeFL and jelhill like this.
Old 12-25-2018, 11:28 PM   #26
MikeFL's Avatar
Rewards Points: 1,982
And it was more important to light the farm area than the house because it's the farm area that makes the money. You can light the house with a candle or an oil lamp.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 12-26-2018, 05:33 AM   #27
Elderly Member
jelhill's Avatar
Rewards Points: 1,088
Now, tell us how you feel.... don’t hold back!
jelhill is offline   Reply With Quote
Old 12-26-2018, 09:36 AM   #28
Every farm house I've worked in had K&T and some even had homemade add on nail and dowel..lol!
frenchelectrican and jelhill like this.
Old 12-26-2018, 03:05 PM   #29
Elderly Member
jelhill's Avatar
I remember one barn I worked on was full of BX... and it was rusty it would fall apart if you just touched it.
Old 12-26-2018, 03:14 PM   #30
I've touched plenty that the insulation would crack as soon as you touched it.
Old 12-26-2018, 06:06 PM   #31
Well if the orginal KT was not messed up it was easy shot but the issue is that over the years they get farmer special KT system that can bit your arse if you are not aware of it and they are pretty close to the ring circuit ( that is one crazy subject that I will talk about it later I been there pretty often when I was in France. )
But too many handydolts do a good job mess it up with KT and also when someone try to hook up extra lights on carter system that can get their attetion if they were aware of switching connection set up.
the other curpit with carter system ( especially with KT system ) is if you put in new panel and if you are not pay attetion to phase postion you will end up send 240 volts to luminaire socket.
jelhill likes this.
Old 12-26-2018, 06:21 PM   #32
You got that right, always fun to see what has been "repaired".
Old 12-26-2018, 06:34 PM   #33
My dad told me about an old farm house he and my uncle were rewiring. They pulled the main fuses to kill the power, and my dad went up into the attic. When he got into the attic there was a light on...
He checked and found Farmer Brown had hung a keyless tapped off the main Hydro lines coming in.
Kawicrash is offline   Reply With Quote
Old 12-26-2018, 06:45 PM   #34
And far from the first time that was done.
Old 12-26-2018, 07:24 PM   #35
Yuh espeally with some handydolts been upgrade the panel themselves and they call me about exploding light bulbs and I knew right away what the curpit was .,,
one handydolt somehow got little smart by wireing up two light sockets in series to work with " 240 " volt circuit and when they replace that luminaire the fun begins .,, ( with nice off color chatting in background .,, )
Old 12-26-2018, 07:30 PM   #36
One of my favorites is when they drive large nails in joists and wrap the conductors around them instead of using insulators and you find them by touching the nail heads in the insulation.
Old 12-26-2018, 09:00 PM   #37
Elderly Member
jelhill's Avatar
Man! I know that unsettling feeling! You turn off the main and there are circuits that are still hot!
Old 12-27-2018, 04:08 PM   #38
I have see that once a while with that and especially if you have split buss main system ( either fuse or circuit breakers ) that can raise the pluck factor up a bit.,,
jelhill likes this.
Old 12-27-2018, 05:37 PM   #39
Elderly Member
jelhill's Avatar
Oh yeah, the good ole K&T days. I loved the guys who thought they were doing good work by tacking down the conductors with romex or fence staples, and they would hammer them in so tight that they would break through the insulation. It was a fun day when you ran into a bunch of HOT romex staples!!!
Old 12-27-2018, 06:06 PM   #40
Switched's Avatar
Rewards Points: 8,752
@frenchelectrician, Handydolt is going to be my new go to for idiots!
frenchelectrican likes this.
What would you do & need current readings just the cowboy General Electrical Discussion 86 09-27-2018 03:16 PM
black iron pipe lamps & or fixtures RICK BOYD Lighting Design 7 02-25-2018 04:08 PM
