Insulation Resistance Test on a CU with RCDs - Electrician Talk - Professional Electrical Contractors Forum
Old 10-08-2012, 02:26 PM   #1
Default Insulation Resistance Test on a CU with RCDs
Hi All.
Insulation resistance test on CUs with RCDs.
Do the test at 250V initially to check anything connected, then disconnecting/bypassing any current/voltage using equipment on the circuits.
When testing each circuit separately, disconnecting the circuit under test from the MCB removes the RCD from the test!.
But on a global test at 500V L-E, L-N, N-E, how do you bypass/disconnect the RCD in a split load consumer unit?
Do you disconnect the tails from the incoming side of the RCD and connect to the outgoing side of the RCD, (same with the 2nd RCD on a split load)? Using the outgoing side of the RCD to connect the tails to the busbar?
Do you disconnect the tails from the incoming side of the RCD and connect to the busbar with ie: a croc clip.
Other option is to leave everything connected and test from the outgoing side of the RCD (RCD open) and test those RCD circuits globally and the same with the second RCD if split load?
Many Thanks
Excellent forum
bugaloo69 is offline   Reply With Quote
Insulation resistance tester(megger) nirvic23 PLCs, VFDs, Motors and Controls 17 07-30-2014 01:07 AM
Insulation Resistance Test camilleri UK Electrical Forum 10 10-19-2012 12:28 AM
Insulation resistance testing-won't hold test voltage Will_Evo Tools, Equipment and New Products 6 04-08-2011 01:29 AM
3 phase generator insulation test wbrancow Commercial Electrical Forum 3 08-07-2009 04:28 PM
